Fuel Boost Pump ON Annunciator
Mudfly
PostPosted: Tue May 23, 2023 4:09 am    Post subject: Fuel Boost Pump ON Annunciator Reply with quote
Hello group,
I want to wire an LED annunciator light that illuminates when the fuel boost
pump switch is selected on. I was planning on making this an "idiot"
light that just indicates the switch is on, not that the pump is actually
working. I can verify pump operation other ways.
My plan is to wire the light directly from the boost pump switch. Input side
of the switch will be feed from fuse panel. Output side will have two wires,
one to the boost pump and other to LED light.
Seems simple but, as usual, I'm sure there may be other issues I'm missing.
Here's the annunciator I will be using. https://www.steinair.com/product/green-led-indicator-light-12v/
I have also attached a diagram to show my plan. Sorry it's an attachment.
I can't seem to convert the file to an attachable picture.
Shawn
Fuel Boost Annunciator.pdf
 Filename:  Fuel Boost Annunciator.pdf
 Filesize:  13.51 KB
 Downloaded:  347 Time(s)
PostPosted: Fri May 26, 2023 5:59 am    Post subject: Fuel Boost Pump ON Annunciator Reply with quote
At 07:09 AM 5/23/2023, you wrote:
--> AeroElectric-List message posted by: "Mudfly" <shawntedwards(at)hotmail.com>
Hello group,
That would work just fine.
(o o)
===========o00o=(_)=o00o=========
< Go ahead, make my day . . . >
< show me where I'm wrong. >
In the interest of creative evolution
of the-best-we-know-how-to-do based
on physics and good practice.
ranchlaseigneurie(at)hotm
PostPosted: Fri May 26, 2023 7:26 am    Post subject: Fuel Boost Pump ON Annunciator Reply with quote
Hello
add a T after the pump add a little pressure switch to it and connect your LED to the switch. If your pump is realy working your LED will come on.... otherwise ...?
Gille St Pierre
AVIATION BSL
From: owner-aeroelectric-list-server(at)matronics.com <owner-aeroelectric-list-server(at)matronics.com> on behalf of Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com>
Sent: May 26, 2023 9:58 AM
To: aeroelectric-list(at)matronics.com <aeroelectric-list(at)matronics.com>
Subject: Re: Fuel Boost Pump ON Annunciator
Hello group,
  (o o)
bob.verwey(at)gmail.com
PostPosted: Fri May 26, 2023 8:03 am    Post subject: Fuel Boost Pump ON Annunciator Reply with quote
Gille you dont think the pressure sw should be NC in line with dark cockpit philosophy?
On Fri, 26 May 2023, 17:29 Gilles St-Pierre, <ranchlaseigneurie(at)hotmail.com (ranchlaseigneurie(at)hotmail.com)> wrote:
Hello
Gille St Pierre
AVIATION BSL
From: owner-aeroelectric-list-server(at)matronics.com (owner-aeroelectric-list-server(at)matronics.com) <owner-aeroelectric-list-server(at)matronics.com (owner-aeroelectric-list-server(at)matronics.com)> on behalf of Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)>
To: aeroelectric-list(at)matronics.com (aeroelectric-list(at)matronics.com) <aeroelectric-list(at)matronics.com (aeroelectric-list(at)matronics.com)>
--> AeroElectric-List message posted by: "Mudfly" <shawntedwards(at)hotmail.com (shawntedwards(at)hotmail.com)>
Hello group,
                  (o o)
