paul.the.aviator(at)gmail Guest
Posted: Wed Apr 19, 2023 7:37 am Post subject: Tri-gear nose wheel O ring size & NGO5 dimensions. |
Hello everyone,
My kit was missing the BS214 O ring and NG05 friction plate. I'm at the point of giving up trying to get them from Europa and making them. I need to know the thickness of the nylon friction plate, the size of the hole and the O ring thickness.
My guess is 1/8" thickness of the material with a 1 1/8" hole and a 1" ID O ring , 1/8 thick.
If anyone can help I'd appreciate the information.
Thanks, Paul
budyerly@msn.com
Posted: Wed Apr 19, 2023 9:40 am Post subject: Tri-gear nose wheel O ring size & NGO5 dimensions. |
Not quite Paul.
NG05 is 3.00 IN OD, 1.0 IN ID, PIN HOLE 1/4 IN Centered between ID , and OD edges or 0.5 inches from the edge. ABS plastic. I would machine from FRP G10 of 1/8 inch thick. Easy to do on a drill press. Buy the FRP, 3" Hole saw has to be 3" ID so I use a 3 1/8 OD instrument hole saw. CLOSE ENOUGH
Monoman
Posted: Wed Apr 19, 2023 10:55 pm Post subject: Tri-gear nose wheel O ring size & NGO5 dimensions. |
Hello Paul
I was at Swifts on Tues and picked up that very item.
I know that they have several more in stock as I saw them.
If you phone the Swift number and ask for Tom Hesp (Rebecca is away at present) you should be able to get it by return.
Quote: | On 19 Apr 2023, at 16:41, Paul McAllister <paul.the.aviator(at)gmail.com> wrote:
Hello everyone,
Thanks, Paul
Posted: Thu Apr 20, 2023 1:21 pm Post subject: Tri-gear nose wheel O ring size & NGO5 dimensions. |
Thanks Mike!
On Thu, Apr 20, 2023 at 1:57 AM Mike <mike(at)nyumba.co.uk (mike(at)nyumba.co.uk)> wrote:
Quote: | --> Europa-List message posted by: Mike <mike(at)nyumba.co.uk (mike(at)nyumba.co.uk)>
Hello Paul
> On 19 Apr 2023, at 16:41, Paul McAllister <paul.the.aviator(at)gmail.com (paul.the.aviator(at)gmail.com)> wrote:
> Hello everyone,
> Thanks, Paul
FORUMS -
WIKI -
b Site -
-Matt Dralle, List Admin.
="noreferrer" target="_blank">https://matronics.com/contribution
