Which Oil Pressure Switch?
Goto page 1, 2, 3  Next
supik
PostPosted: Sun Apr 16, 2023 12:32 pm    Post subject: Which Oil Pressure Switch? Reply with quote
Which Oil Press Switch model P/N is used in this scheme?
http://www.aeroelectric.com/PPS/Engine/Gaging/Oil_P_Warn.pdf
Igor
RV10 in progress
supik
PostPosted: Sun Apr 16, 2023 1:16 pm    Post subject: Re: Which Oil Pressure Switch? Reply with quote
It looks I found it:
https://store.vansaircraft.com/oil-pressure-switch-ie-spdt-pres-15-sw.html
Igor
RV10 in progress
Mudfly
PostPosted: Mon Apr 17, 2023 6:14 am    Post subject: Re: Which Oil Pressure Switch? Reply with quote
Hello Igor,
I'm currently researching ways to activate my hobbs meter. Probably not
a big deal, but I would prefer something other than using a feed from
the oil pressure. Much like the electrical failure points discussed on this
list, I see the extra oil fittings as possible failure points. I know that's
primarily used but was wondering with modern avionics could there be another way to activate the hobbs?
Also, are you using a analog or LCD meter? I originally planned the
Honeywell, 2 pin LCD unit. However, I realized the unit would only display
the digits when it was activated by oil pressure or other device used to
complete the circuit. I would like to see the digits when battery is
switched on.
I switched to the 3 pin LCD unit. Honeywell LM-HH3AS-H21. The pins are
positive, negative and enable. https://www.digikey.com/en/products/detail/honeywell-sensing-and-productivity-solutions/LM-HH3AS-H21/5069695
It will be powered off the main power bus when battery is switched on.
I now just need to figure out how to power the enable portion..other
than oil pressure. I found an activation switch that uses pitot pressure,
but it does not activate until 27 mph. Don't love that either:)
https://www.edmo.com/product/AEROMETER/hourmeter-airspeed-switch-stc-aerometer
Any ideas from the group?
Shawn
neal.george(at)gmail.com
PostPosted: Mon Apr 17, 2023 12:16 pm    Post subject: Which Oil Pressure Switch? Reply with quote
Shawn -
Have you considered a vacuum switch in the intake manifold? Activates when the engine starts, no threat or mess if it leaks.
Neal
Shawn
kenryan
PostPosted: Mon Apr 17, 2023 12:18 pm    Post subject: Which Oil Pressure Switch? Reply with quote
I wonder if there is a vibration sensor that would be appropriate? I know that Sterling has added that feature to their B2B chargers.
On Mon, Apr 17, 2023 at 6:18 AM Mudfly <shawntedwards(at)hotmail.com (shawntedwards(at)hotmail.com)> wrote:
--> AeroElectric-List message posted by: "Mudfly" <shawntedwards(at)hotmail.com (shawntedwards(at)hotmail.com)>
Hello Igor,
switched on.
Shawn
http://forums.matronics.com/viewtopic.php?p=510642#510642
="noreferrer" target="_blank">https://matronics.com/contribution
Ceengland
PostPosted: Mon Apr 17, 2023 12:29 pm    Post subject: Which Oil Pressure Switch? Reply with quote
On 4/17/2023 3:15 PM, Neal George wrote:
Shawn -
Neal
Shawn
FWIW, my ancient 1st-gen Dynon D10-EMS doesn't start the clock until the
plane is moving. No idea what the threshold is or how it's measured, but
it seems likely that it's airspeed dependent since the D10 doesn't talk
to any other instruments in the a/c.
www.avast.com
rv8iator
PostPosted: Tue Apr 18, 2023 11:19 pm    Post subject: Which Oil Pressure Switch? Reply with quote
There is a self powered vibration sensing stand alone Hobbs meter.  I have on, after 20 years it still continues to count hours.
I think ENM makes one and frugo.fr as well.
Chris Stone
RV-8
Shawn
C. Stone (RV8iator)
Mudfly
PostPosted: Thu Apr 20, 2023 6:52 am    Post subject: Re: Which Oil Pressure Switch? Reply with quote
Several good ideas.
This company https://enmco.com/, suggested by Chris, has several
options. Just need to sort through them.
Thanks.
Shawn
PostPosted: Thu Apr 20, 2023 10:14 am    Post subject: Which Oil Pressure Switch? Reply with quote
At 03:15 PM 4/17/2023, you wrote:
--> AeroElectric-List message posted by: Neal George <neal.george(at)gmail.com>
Shawn -
Most of cruising flight is at high
manifold pressure if not max (throttle
wide open) depending on altitude.
Hence, no significant vacuum to operate
a switch.
Any automotive oil pressure switch is
suited to task. We used to sell a
Standard pressure switch off my
website . . .was about $10 as I recall.
You can generally pick one with threads
that exactly match the engine's oil
pressure port without adapters hence
very low risk of leaks when joint is
made up with proper application of
Teflon tape.
These switches are generally suited
only for sensing 'active' oil pressure.
I.e., they close at 4-10 psi. Fine
for your Hobbs system.
One could drive the HOBBS through
a voltage sensitive switch that
runs the meter if the bus is above
13.5 volts (alternator delivering power).
Similarly, driving directly
from the engine bus of an electrically
dependent engine would work (engine
wouldn't be running if bus is cold).
Yeah, there are a few instances when
the HOBBS might power up with the
engine not running, but the errors
generated would be small and in the
right direction thus changing oil
or cleaning plugs a bit early.
There is a cute little engine hour-meter
that runs based on sensing ignition
system activity.
https://tinyurl.com/mtw27jc3
I've installed these on gas driven
generators with good results. They
sense ignition activity by means
of a flying pigtail wrapped around
the plug wire. These could also
be made to work by sensing activity
on a magneto -lead.
If you've got an electronic tachometer,
the signal used to drive the tach could
be easily conditioned to become an
activity switch for the hour meter.
Lots of ways to 'skin' this cat . . .
(o o)
===========o00o=(_)=o00o=========
< Go ahead, make my day . . . >
< show me where I'm wrong. >
In the interest of creative evolution
of the-best-we-know-how-to-do based
on physics and good practice.
Mudfly
PostPosted: Fri Apr 21, 2023 4:56 am    Post subject: Re: Which Oil Pressure Switch? Reply with quote
Thanks Bob.
I like these two ideas you mentioned in your post.
1. "One could drive the HOBBS through
13.5 volts (alternator delivering power)."
2. "If you've got an electronic tachometer,
I'm using a 3 wire (+,-, and enable pins) LCD meter and
would like the numbers to display when battery is
switched on, but not start the timer. I'm having trouble
finding a wire diagram for my unit, but guess the enable
pin goes to ground. I will need to do some more
homework to see if I can make the options you mentioned work.
I'm using garmin stuff so possibly there's a way to
make either option 1 or 2 above work. If not, I may have to resort back
to using the oil pressure switch.
Thanks again,
Shawn
PostPosted: Fri Apr 21, 2023 5:52 am    Post subject: Which Oil Pressure Switch? Reply with quote
Teflon tape.
Follow up:
I've received a couple of notes from
learned List readers that Teflon tape
as a thread sealant comes with some
risks.
I remember writing paragraphs in Cessna
field service documents describing the
'proper application' of Teflon tape
on certain fluid fittings. If the
tape's wrappings extend too far down
the taper, there is risk that some
shreds created by the mating forces
will be dropped into the fluid stream.
Not a good thing. Back in '66 we
were specific on the care taken to leave
two threads of the fitting clear of
tape such that ALL products of
installation were contained in
the joint.
To be sure, there are less risky
products out there for sealing
of NPT (tapered pipe) threads and
on the advice of our experienced
readers, I would agree. Get some
'better' dope if you can . . .
but skillfully applied Teflon works
too.
(o o)
Ceengland
PostPosted: Fri Apr 21, 2023 6:06 am    Post subject: Which Oil Pressure Switch? Reply with quote
On Fri, Apr 21, 2023 at 8:57 AM Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
  Teflon tape.
    Follow up:
    risks.
   (snipped)
    too.
The concern with tape is that even if it's applied to the threads properly, upon removal of the device some of it can remain in the female threads, and get pushed into the passageway when the device is re-installed.
I don't know whether that's a valid concern, but I use teflon dope so I don't have to find out. Wink
Virus-free.www.avast.com[url=#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2][/url]
Eric Page
PostPosted: Fri Apr 21, 2023 6:13 am    Post subject: Re: Which Oil Pressure Switch? Reply with quote
I found this, and several other fittings like it, when disassembling the header tank plumbing on my second-hand Kitfox project. The first builder had used Teflon tape in their assembly without proper care.
 Filesize:  83.26 KB
 Viewed:  37754 Time(s)
PostPosted: Fri Apr 21, 2023 7:35 am    Post subject: Which Oil Pressure Switch? Reply with quote
At 07:56 AM 4/21/2023, you wrote:
--> AeroElectric-List message posted by: "Mudfly" <shawntedwards(at)hotmail.com>
Thanks Bob.
I can sketch this circuit out
for you. Is there an installation
document for the make/model of
your hour meter?
Curious: What kind of ignition
system do you have?
(o o)
Mudfly
PostPosted: Fri Apr 21, 2023 12:58 pm    Post subject: Re: Which Oil Pressure Switch? Reply with quote
[quote="nuckolls.bob(at)aeroelect"]At 07:56 AM 4/21/2023, you wrote:
[quote]--> AeroElectric-List message posted by: "Mudfly" <shawntedwards>
Thanks Bob.
13.5 volts (alternator delivering power)." [/quote]
your hour meter?
system do you have?
(o o)
<Go>
on physics and good practice.[/quote]
It's a Honeywell LM-HH3AS-H21. The only document I have been able
to find is the data sheet on this page.
My current electrical diagram has the unit powered off the Main Power
Bus so it should illuminate the LCD numbers when the battery is
switched on. I need to find a home for wire from the enable pin.
My planned ignition system is a SureFly on the left and a Slick mag
on the right. I'm working on a post for the list for a small can of worms
I've opened with that system.
Shawn
 Filesize:  42 KB
 Viewed:  37744 Time(s)
 Filesize:  22.56 KB
 Filesize:  26.91 KB
Eric Page
PostPosted: Fri Apr 21, 2023 9:52 pm    Post subject: Re: Which Oil Pressure Switch? Reply with quote
Mudfly wrote:
I'm having trouble finding a wire diagram for my unit, but guess the enable pin goes to ground.
Here are the installation instructions for the unit you mentioned. Wiring data is on the first page. The enable pin is active high.
https://tinyurl.com/386autu8+
Mudfly
PostPosted: Sat Apr 22, 2023 3:22 am    Post subject: Re: Which Oil Pressure Switch? Reply with quote
[quote="Eric Page"][quote="Mudfly"]I'm having trouble finding a wire diagram for my unit, but guess the enable pin goes to ground.[/quote]
https://tinyurl.com/386autu8+[/quote]
Thanks Eric
PostPosted: Sat Apr 22, 2023 7:24 pm    Post subject: Which Oil Pressure Switch? Reply with quote
system do you have?
looked all over the data sheet and couldn't
find a callout for enable pin functionality . . .
for a Honeywell product, I find that surprising.
Anywho, I suppose your assertion of active
pull-down is correct.
Actually, no big deal. Given that you have
a magneto, let's consider an ignition activity
detector tie to the Slick p-lead.
I did a sketch for a reader about a quarter
century back. I'll see if I can dig it up
or duplicate it. Probably have all the needed
parts to dedicate to the cause. Watch
this space.
(o o)
PostPosted: Sun Apr 23, 2023 9:48 am    Post subject: Which Oil Pressure Switch? Reply with quote
[quote="Eric Page"]
very good. thanks!
(o o)
PostPosted: Wed Apr 26, 2023 8:59 am    Post subject: Which Oil Pressure Switch? Reply with quote
Shawn,
Could you set this hourmeter up on the bench
and measure the current draw on the enable
pin in the pull-up configuration? I think
I have a simple solution using p-lead
signal from a mag to drive the enable pin
but having that current value would facilitate
optimization of the components.
(o o)
Page 1 of 3
