hivanhaecker(at)gmail.com Guest
Posted: Sun Feb 26, 2023 10:35 am Post subject: Intermittent Charging |
Something is amiss with my charging system. Upon initial start, normal charging voltage occurs. A few minutes into flight, the voltage has dropped to battery only. Upon landing, it’s back up to normal charging voltage. This has occurred on the last three flights. I can’t find any obvious loose connections and a voltage check with a VOM in flight shows the shipboard volt meter is accurate. So I suppose it is either an alternator or external regulator (ford type) problem. Is there a way in flight to determine which is the culprit? Maybe check the output voltage from the field terminal to the alternator while in flight? Any advice would be appreciated.Ivan Haecker
chaskuss(at)yahoo.com Guest
Posted: Sun Feb 26, 2023 11:19 am Post subject: Intermittent Charging |
You can bypass the voltage regulator to force the alternator generate full output. I suggest you start by reading:
https://www.freeasestudyguides.com/alternator-full-field-test.html
On Sunday, February 26, 2023, 01:44:38 PM EST, H. Ivan Haecker <hivanhaecker(at)gmail.com> wrote:
Radioflyer
Posted: Sun Feb 26, 2023 1:42 pm Post subject: Re: Intermittent Charging |
I think the first thing I would do is to connect a temporary extension wire from the field wire going directly into the alternator into the cabin/cockpit so that you can measure the field Volts. If the field Volts are not normal or go too low, then its not the alternator. Bob N. discusses this in his book (diag. Z-23) and advises putting a 1k Ohm resistor in this line to limit any shorting potential.
Ceengland
Posted: Sun Feb 26, 2023 1:53 pm Post subject: Intermittent Charging |
On 2/26/2023 12:35 PM, H. Ivan Haecker wrote:
| Quote: | Something is amiss with my charging system. Upon initial start, normal
Ivan Haecker
Does it instantly drop from 14+V charge voltage to battery voltage, or
does it decay slowly from charge voltage to battery voltage? (Instant
drop might indicate a loose connection, though I'd expect an
intermittent connection issue to come and go within the same flight.
Have you checked your alternator belt for proper tension?
www.avast.com
_________________ Charlie |
Posted: Sun Feb 26, 2023 3:02 pm Post subject: Intermittent Charging |
I can’t say whether it is an instant drop or not. I’ve never been watching the volt meter when it happens. I did however observe it fluctuating one time. The gauge showed about 13v and was moving jerkily for a few seconds and then went to battery voltage and stayed there. It went back to 14+ at some point but it didn’t notice it until I was on the ground.
I did tighten the belt before the last flight yesterday thinking it was slightly loose, but that made no difference.
I’m back to thinking it must be an intermittent connection that I just haven’t found....
Ivan Haecker
On Sun, Feb 26, 2023 at 3:55 PM Charlie England <ceengland7(at)gmail.com (ceengland7(at)gmail.com)> wrote:
| Quote: | --> AeroElectric-List message posted by: Charlie England <ceengland7(at)gmail.com (ceengland7(at)gmail.com)>
> Ivan Haecker
www.avast.com
FORUMS -
WIKI -
b Site -
-Matt Dralle, List Admin.
="noreferrer" target="_blank">https://matronics.com/contribution
Posted: Sun Feb 26, 2023 3:07 pm Post subject: Intermittent Charging |
I just saw the response from ”Radioflyer” and will try that in a couple of days when the weather improves (and recheck the connections again).
Ivan Haecker
On Sun, Feb 26, 2023 at 4:00 PM Radioflyer <skyeyecorp(at)airpost.net (skyeyecorp(at)airpost.net)> wrote:
| Quote: | --> AeroElectric-List message posted by: "Radioflyer" <skyeyecorp(at)airpost.net (skyeyecorp(at)airpost.net)>
http://forums.matronics.com/viewtopic.php?p=510283#510283
FORUMS -
WIKI -
b Site -
Posted: Mon Feb 27, 2023 4:55 am Post subject: Intermittent Charging |
As a first step, I would remove all the ground wires. Clean the connections and test the ring terminals physical connection to their wires by pulling on them. A poor ground often causes the symptoms you describe.
On Sunday, February 26, 2023 at 06:15:08 PM EST, H. Ivan Haecker <hivanhaecker(at)gmail.com> wrote:
Ivan Haecker
FORUMS -
WIKI -
b Site -
Posted: Tue Feb 28, 2023 6:32 am Post subject: Intermittent Charging |
At 12:35 PM 2/26/2023, you wrote:
| Quote: | | Something is amiss with my charging system. Upon initial start, normal charging voltage occurs. A few minutes into flight, the voltage has dropped to battery only. Upon landing, it’s back up to normal charging voltage. This has occurred on the last three flights. I can’t find any obvious loose connections and a voltage check with a VOM in flight shows the shipboard volt meter is accurate. So I suppose it is either an alternator or external regulator (ford type) problem. Is there a way in flight to determine which is the culprit? Maybe check the output voltage from the field terminal to the alternator while in flight? Any advice would be appreciated. |
There is . . .
Bring a temporary connection from the alternator
or regulator's field terminal into the cockpit
and measure regulator's output voltage during
normal/abnormal ops.
Voltage should be on the order of 1-4 volts
in normal, hi-rpm operations and never
zero.
Alternatively, fabricate a test fixture thusly . . .
https://tinyurl.com/2z2ww9gl
Disconnect alternator from the ship's regulator
and make a temporary installation of this
test fixture to the alternator. This creates
a system that comes up with engine start and
is not controllable from the cockpit, but it
bypasses a lot of potential system trouble
spots.
Given your description of the intermittent
behavior, I'd bet that it's the alternator
but 'divide and conquer' will help you
deduce the facts.
out of that stuff?"
Posted: Tue Feb 28, 2023 11:21 am Post subject: Intermittent Charging |
Another test flight today produced some interesting results. I fabricated a tap into the field wire that runs from the regulator to the alternator. I placed a 1k resistor in the tap wire and ran the wire to an analog VOM in the cockpit. A ground wire from the VOM was ran to the forest of tabs behind the panel (where the regulator is grounded). At idle rpm, the panel mounted volt meter reads ~ 14.5V and the VOM test circuit reads about 8 volts. As power reaches about 1900 rpm, the panel volt meter begins to fall off toward battery voltage and the tapped field voltage on the analog VOM begins to fall off toward 3-4 volts. The same situation was observed in flight. Does this indicate a regulator problem or an alternator problem?
I suppose my next test should be the one the Bob proposed this morning, but I will have to obtain another regulator to do that test.
Ivan Haecker
On Tue, Feb 28, 2023 at 9:04 AM Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
There is . . .
zero.
spots.
deduce the facts.
out of that stuff?"
edwclg
Posted: Tue Feb 28, 2023 11:49 am Post subject: Intermittent Charging |
I had a similar problem last year and it was two broken stator wires. Wires were intermittently touching causing, on again off again.Ed
On Tue, Feb 28, 2023 at 2:24 PM H. Ivan Haecker <hivanhaecker(at)gmail.com (hivanhaecker(at)gmail.com)> wrote:
| Quote: | Another test flight today produced some interesting results. I fabricated a tap into the field wire that runs from the regulator to the alternator. I placed a 1k resistor in the tap wire and ran the wire to an analog VOM in the cockpit. A ground wire from the VOM was ran to the forest of tabs behind the panel (where the regulator is grounded). At idle rpm, the panel mounted volt meter reads ~ 14.5V and the VOM test circuit reads about 8 volts. As power reaches about 1900 rpm, the panel volt meter begins to fall off toward battery voltage and the tapped field voltage on the analog VOM begins to fall off toward 3-4 volts. The same situation was observed in flight. Does this indicate a regulator problem or an alternator problem?
Ivan Haecker
There is . . .
zero.
spots.
deduce the facts.
out of that stuff?"
Posted: Tue Feb 28, 2023 6:52 pm Post subject: Intermittent Charging |
At 01:20 PM 2/28/2023, you wrote:
| Quote: | | Another test flight today produced some interesting results. I fabricated a tap into the field wire that runs from the regulator to the alternator. I placed a 1k resistor in the tap wire and ran the wire to an analog VOM in the cockpit. A ground wire from the VOM was ran to the forest of tabs behind the panel (where the regulator is grounded). At idle rpm, the panel mounted volt meter reads ~ 14.5V and the VOM test circuit reads about 8 volts. As power reaches about 1900 rpm, the panel volt meter begins to fall off toward battery voltage and the tapped field voltage on the analog VOM begins to fall off toward 3-4 volts. The same situation was observed in flight. Does this indicate a regulator problem or an alternator problem? |
No . . . the voltage readings you're seeing are a bit
polluted as a consequence of the tiny current draw
by the analog voltameter. They are, nonetheless, significant.
At low RPM the alternator may not be able to bring the
bus up to normal set-point. It's not uncommon to see
field voltages on the order of 10 volts or more at
ramp idle.
At in-flight RPMs, the regulator REDUCES field
voltage so as to keep the alternator's output at
the designed output voltage. At cruise RPM
and light loads, I've see voltages on the order
of 1 volt at the field.
This is what I would expect.
You state that as RPM goes up, panel voltmeter
shows a bus voltage reduction down to battery
voltage? Something on the order of 12.5 volts?
But the field voltage goes down also?
What kind of regulator do you have. What airplane
are we talking about?
out of that stuff?"
user9253
Joined: 28 Mar 2008 Posts: 1968 Location: Riley TWP Michigan
Posted: Tue Feb 28, 2023 7:19 pm Post subject: Re: Intermittent Charging |
Repeat the test, but instead of measuring field voltage, measure field current while monitoring electrical system voltage.
_________________ Joe Gores |
Posted: Tue Feb 28, 2023 7:21 pm Post subject: Intermittent Charging |
Yes, as the engine rpm goes up, field voltage begins to go down and the panel voltmeter goes down to battery voltage (12.5v). At idle, the field voltage goes up and the panel voltage in turn rises back to ~14.5v. The plane is an rv-4 which I’ve been flying for 31 yrs. The regulator is a NAPA ford type (VR 440) that has been in service for 7 yrs. The alternator is an Auto Zone #14184 (I think 30 amp or so), and it has been in service 14 yrs. Also I have lately noticed a whine in the radio audio that changes with rpm. I don’t know if that is related to my problem or not.
Ivan Haecker
On Tue, Feb 28, 2023 at 8:54 PM Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
ramp idle.
out of that stuff?"
Posted: Tue Feb 28, 2023 7:54 pm Post subject: Intermittent Charging |
That would have to wait as I don’t have an ammeter in my plane. But it might be worthwhile to get one as a diagnostic tool. It would have to something “portable” as I have no room in my panel.
Ivan Haecker
On Tue, Feb 28, 2023 at 9:34 PM user9253 <fransew(at)gmail.com (fransew(at)gmail.com)> wrote:
| Quote: | --> AeroElectric-List message posted by: "user9253" <fransew(at)gmail.com (fransew(at)gmail.com)>
Joe Gores
http://forums.matronics.com/viewtopic.php?p=510303#510303
FORUMS -
WIKI -
b Site -
user9253
Posted: Tue Feb 28, 2023 8:06 pm Post subject: Re: Intermittent Charging |
Alternator whine? Measure the AC voltage on the main bus.
If alternator output has an AC component of 1 volt or more, then a diode is bad.
Some mechanics say 1/2 volt AC or more means a bad diode.
user9253
Posted: Tue Feb 28, 2023 8:09 pm Post subject: Re: Intermittent Charging |
Most digital multimeters have an ammeter function.
Posted: Tue Feb 28, 2023 9:23 pm Post subject: Intermittent Charging |
Joe,
I never noticed the ammeter function before. Probably because I’m electrically challenged. I’ll try it tomorrow and check for ac voltage as well. Thanks
Ivan Haecker
On Tue, Feb 28, 2023 at 10:11 PM user9253 <fransew(at)gmail.com (fransew(at)gmail.com)> wrote:
Joe Gores
http://forums.matronics.com/viewtopic.php?p=510307#510307
FORUMS -
WIKI -
b Site -
Ceengland
Posted: Wed Mar 01, 2023 6:05 am Post subject: Intermittent Charging |
If you're electrically challenged, be sure you know how to use the amps function before trying it. (Don't want you to have a dead meter, in addition to your alternator problem.)
On Tue, Feb 28, 2023 at 11:25 PM H. Ivan Haecker <hivanhaecker(at)gmail.com (hivanhaecker(at)gmail.com)> wrote:
| Quote: | Joe,
Ivan Haecker
user9253
Posted: Wed Mar 01, 2023 8:12 am Post subject: Intermittent Charging |
At 09:20 PM 2/28/2023, you wrote:
| Quote: | | Yes, as the engine rpm goes up, field voltage begins to go down and the panel voltmeter goes down to battery voltage (12.5v). At idle, the field voltage goes up and the panel voltage in turn rises back to ~14.5v. The plane is an rv-4 which I’ve been flying for 31 yrs. The regulator is a NAPA ford type (VR 440) that has been in service for 7 yrs. The alternator is an Auto Zone #14184 (I think 30 amp or so), |
that's a 35 amp alternator which was Van's
first pick many, many moons ago. 14184 is
the Lester number for a Denso part that
was used on a constellation of automobiles.
https://tinyurl.com/2zxwvabs
| Quote: | | and it has been in service 14 yrs. |
You got your money's worth out of that one!
| Quote: | Also I have lately noticed a whine in the radio audio that
changes with rpm. I don’t know if that is related to my problem or not. |
May very well be . . . loss of performance in
one or more phases of the alternator causes
a profound increase in the AC ripple voltage
riding on the DC output . . . it also manifests
in a degraded output capability.
The increased ripple voltage is often manifest
by a sudden presence of alternator whine
in an audio system.
The numbers you cited for regulator behavior
seem reasonable . . . I'd vote for an alternator
replacement. Many parts stores can run your
alternator on a test bench while being
able to offer an off-the-shelf replacement.
That '14184' is the key to a drop-in
replacement.
out of that stuff?"
