MT04 Engine mounts
paul.the.aviator(at)gmail
PostPosted: Sat Feb 11, 2023 12:59 pm    Post subject: MT04 Engine mounts Reply with quote
Hi, is anyone aware of a US supplier for the MT04 engine mounts or is Europa the only source. - Paul
budyerly@msn.com
PostPosted: Sat Feb 11, 2023 1:46 pm    Post subject: MT04 Engine mounts Reply with quote
Paul,
Esteban from Columbia is coming to the states and needs a trailer. Do you have a buyer?
Bud Yerly
Get Outlook for Android
From: owner-europa-list-server(at)matronics.com <owner-europa-list-server(at)matronics.com> on behalf of Paul McAllister <paul.the.aviator(at)gmail.com>
Sent: Saturday, February 11, 2023 3:58:38 PM
To: europa-list(at)matronics.com <europa-list(at)matronics.com>
Subject: MT04 Engine mounts
peterz(at)zutrasoft.com
PostPosted: Sat Feb 11, 2023 1:53 pm    Post subject: MT04 Engine mounts Reply with quote
[img]cid:9CB3AEF7-9591-4D90-929C-26C792175AF5[/img]Lord Engine Mount # J-3608-1
aircraftspruce.com
Softer tho, so you need to adjust with a shorter spacer
PeteZ
On Feb 11, 2023, at 4:05 PM, Paul McAllister <paul.the.aviator(at)gmail.com> wrote:
 Filesize:  182.58 KB
 Viewed:  4165 Time(s)
budyerly@msn.com
PostPosted: Sat Feb 11, 2023 2:02 pm    Post subject: MT04 Engine mounts Reply with quote
Re the motor mounts:
Engine Rubber Isolation Mounts:
1.            Europa Rotax Mount MT04 hard mount.
Alternate isolation mount:
1.            A/C Spruce Part# 08-00662 but not sure of how firm the rubber is.
MFR Model # SET OF 8  About $50 plus shipping/tax
2.            Lockwood 860-690 is really expensive $30 each.  Just a Lord Mount J3608-1
Bud Yerly
From: owner-europa-list-server(at)matronics.com <owner-europa-list-server(at)matronics.com> On Behalf Of Paul McAllister
Sent: Saturday, February 11, 2023 3:59 PM
Subject: Europa-List: MT04 Engine mounts
PostPosted: Sat Feb 11, 2023 2:40 pm    Post subject: MT04 Engine mounts Reply with quote
Hi Bud,
My trailer is available.
Paul
On Sat, Feb 11, 2023 at 3:47 PM Bud Yerly <budyerly(at)msn.com (budyerly(at)msn.com)> wrote:
Paul,
Bud Yerly
From: owner-europa-list-server(at)matronics.com (owner-europa-list-server(at)matronics.com) <owner-europa-list-server(at)matronics.com (owner-europa-list-server(at)matronics.com)> on behalf of Paul McAllister <paul.the.aviator(at)gmail.com (paul.the.aviator(at)gmail.com)>
To: europa-list(at)matronics.com (europa-list(at)matronics.com) <europa-list(at)matronics.com (europa-list(at)matronics.com)>
budyerly@msn.com
PostPosted: Sat Feb 11, 2023 2:52 pm    Post subject: MT04 Engine mounts Reply with quote
Paul,
Esteban Restreto, wanted my trailer and missed out as I sold it .
He bought a Classic Europa in Wisconsin and you are up there lets get you to together. He needs a good mechanical trailer to get the Europa mono back down to Miami where he lives.
I figure this is a win win for both of you. He was willing to pay $1000 for mine with the ramp and winch with spare tires. Mine was roadworthy. He is ready to drive north now. If you have to work on it you guys work it out.
Can I have him email you direct.
His phone is 786 858-9326
His email: maquienvio(at)gmail.com (maquienvio(at)gmail.com)
Bud Yerly
Custom Flight Creations
Sent: Saturday, February 11, 2023 5:40 PM
Subject: Re: MT04 Engine mounts
Hi Bud,
Paul
Paul,
Bud Yerly
PostPosted: Sat Feb 11, 2023 2:55 pm    Post subject: MT04 Engine mounts Reply with quote
I love my lords….waaaay quieter than the old europa rubbers,
PeteZ
On Feb 11, 2023, at 5:08 PM, Bud Yerly <budyerly(at)msn.com> wrote:
 <![endif]--> Clean DocumentEmail false false false EN-US X-NONE X-NONE <![endif]--> <![endif]-->(at)font-face { font-family: "Cambria Math"; } (at)font-face { font-family: Calibri; } p.MsoNormal, li.MsoNormal, div.MsoNormal { margin: 0in; font-size: 11pt; font-family: Calibri, sans-serif; } a:link, span.MsoHyperlink { color: rgb(5, 99, 193); text-decoration: underline; } a:visited, span.MsoHyperlinkFollowed { color: rgb(149, 79, 114); text-decoration: underline; } p.msonormal0, li.msonormal0, div.msonormal0 { margin-right: 0in; margin-left: 0in; font-size: 11pt; font-family: Calibri, sans-serif; } span.EmailStyle18 { font-family: Calibri, sans-serif; color: windowtext; } .MsoChpDefault { font-family: Calibri, sans-serif; } (at)page WordSection1 { size: 8.5in 11in; margin: 1in; } div.WordSection1 { page: WordSection1; }/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri",sans-serif; mso-ascii-font-family:Calibri; mso-hansi-font-family:Calibri; mso-bidi-font-family:"Times New Roman";} <![endif]--> <![endif]--> <![endif]-->
Bud Yerly
wdaniell.longport(at)gmai
PostPosted: Tue Feb 14, 2023 11:40 am    Post subject: MT04 Engine mounts Reply with quote
Pete
How much did you shorten the spacers?
Will
William Daniell
LONGPORT
+1 786 878 0246
On Sat, Feb 11, 2023 at 5:57 PM Pete <peterz(at)zutrasoft.com (peterz(at)zutrasoft.com)> wrote:
PeteZ
On Feb 11, 2023, at 5:08 PM, Bud Yerly <budyerly(at)msn.com (budyerly(at)msn.com)> wrote:
Bud Yerly
From: owner-europa-list-server(at)matronics.com (owner-europa-list-server(at)matronics.com) <owner-europa-list-server(at)matronics.com (owner-europa-list-server(at)matronics.com)> On Behalf Of Paul McAllister
PostPosted: Wed Feb 15, 2023 3:43 am    Post subject: MT04 Engine mounts Reply with quote
Hi William,
Had to reduce the spacer lengths to 1.500” to deal with the very large startup and shutdown movements of the high compression 912ULS.  That said I believe Erich with his lower compression 914 got away with 1.592” which I found to be *really* quiet and smooth - except with my 912ULS it would bang around during startup and shutdown (when I had the heavy and gear-box abusing warpdrive, I may be able to lengthen them with my now super-light E-prop).
PeteZ
On Tue, Feb 14, 2023 at 2:47 PM William Daniell <wdaniell.longport(at)gmail.com (wdaniell.longport(at)gmail.com)> wrote:
Pete
Will
William Daniell
LONGPORT
+1 786 878 0246
PeteZ
Bud Yerly
