Radio altimeter
alec(at)alecmyers.com
PostPosted: Sat Dec 10, 2022 7:18 am    Post subject: Radio altimeter Reply with quote
Here’s little project that might fire someone’s imagination.
I bought a radio altimeter module from Ainstein (US-D1: https://ainstein.ai/drone-makers-drone-service-providers/us-d1/) and paired it with a PIC microcontroller-driven display, to make a radio altimeter to help my students learn to judge their height above ground when learning to land.
First iteration was with a four digit display height readout, but nobody has time to be looking at that while landing, so now I have three LED’s and a buzzer: red shows above 25’, amber is 4’-25’ and green is 3’ and below. The buzzer sounds intermittently below 25’ and continuously at 3’. The switch disables the buzzer, in case it gets irritating.
Because I’m in a TC aircraft and not OBAM, the antenna is attached with 3M mate-n-lok to the inside of a plastic inspection hatch on the belly (radiation transparent) and the whole thing is powered from the 5v output of a USB port (or USB battery power-pack).
I have noticed that the antenna emits enough unwanted RF on a frequency of 125.00MHz to open the COM squelch and give a lot of noise in the headsets on that frequency, which is unfortunate as 125.00MHz is the tower frequency of a nearby airport, but other than that it works well.
Here’s a picture of the display unit, the box is about 3 inches long:
 Filesize:  22.47 KB
 Viewed:  2832 Time(s)
 Filesize:  26.75 KB
PostPosted: Sat Dec 10, 2022 7:21 am    Post subject: Radio altimeter Reply with quote
Sorry - my bad - the antenna is secured with 3m "dual lock” tape - it’s like a more robust version of Velcro. It’s great for securing things in an airplane in a temporary fashion. If anyone hasn’t tried it, I recommend it!
<IMG_2561.jpeg>
<IMG_2560.jpeg>
david(at)carter.net
PostPosted: Sat Dec 10, 2022 8:22 am    Post subject: Radio altimeter Reply with quote
Very similar in concept to this product -
https://landingheight.com/shop/
I have their earlier non-certifed version in my RV-7A.
https://www.enginebridge.com/product/landing-height-controller-copy/
On Sat, Dec 10, 2022 at 8:21 AM Alec Myers <alec(at)alecmyers.com (alec(at)alecmyers.com)> wrote:
--> AeroElectric-List message posted by: Alec Myers <alec(at)alecmyers.com (alec(at)alecmyers.com)>
On Dec 10, 2022, at 9:52 AM, Alec Myers <alec(at)alecmyers.com (alec(at)alecmyers.com)> wrote:
<IMG_2561.jpeg>
<IMG_2560.jpeg>
="noreferrer" target="_blank">https://matronics.com/contribution
David Carter
david(at)carter.net (david(at)carter.net)
Eric Page
PostPosted: Sun Dec 11, 2022 8:15 am    Post subject: Re: Radio altimeter Reply with quote
If anyone is interested in developing a similar system, the Benewake LiDAR unit used in this product is available separately:
http://en.benewake.com/product/detail/5c345cc2e5b3a844c472329a.html
Another company called LightWare make similar sensors at hobbyist prices:
https://lightwarelidar.com/
