Rowland_Carson
Joined: 04 Jul 2008 Posts: 155 Location: Cheltenham, England
Posted: Fri Oct 28, 2022 5:38 am Post subject: size of aircraft data plate |
I’ve been trying to find if there is a minimum size for the aircraft data plate mentioned (almost as an aside) in CAA CAP523. I’ve had a poke around the ANO but cannot see anything relevant.
Does anyone know if there is requirement for the data plate (or the writing upon it) to be any particular size? Obviously I don’t want to fit anything bigger, heavier or more expensive than really necessary!
in friendship
Rowland
Kelvin Weston
Joined: 14 Apr 2010 Posts: 90 Location: Hampshire, UK
Rowland_Carson
Posted: Fri Oct 28, 2022 8:37 am Post subject: size of aircraft data plate |
Kelvin - there doesn’t seem to be a link to that page on the LAA website any more; I am not sure what would happen if one tried to order. I’d been aware of it for some time. The original version showed a calendar date for “PtF issued” (not permit to test) which meant the aircraft would have had to have a temporary data plate during the test period, as the permit issue date would not yet be known!
Anyway the dimensions there are a useful guide to what seems to be acceptable.
in friendship
Rowland
Paul M 383
Joined: 19 Mar 2012 Posts: 102 Location: United Kingdom
Hello Rowland,
The ANO 2016 (https://www.legislation.gov.uk/uksi/2016/765/contents/made) Schedule 4 Part 2 (https://www.legislation.gov.uk/uksi/2016/765/schedule/4/part/2/made) has exactly the same text as CAP 523 ("The nationality and registration marks must also be inscribed on a fire-proof metal plate affixed in a prominent position...") except the CAP quotes ANO 2000 ... only 16 years out of date [rolls eyes].
The only other reference I found is in LAA TL 2.11 (http://www.lightaircraftassociation.co.uk/engineering/technical_leaflets.html) which states (page 2) "Another vital and indeed legally required item is a fireproof metal plate (usually stainless steel) engraved or stamped with the aircraft nationality and registration marks, e.g. G-ALAA. The Air Navigation Order (ANO) states that this plate is to be "affixed in a prominent position on the fuselage". We interpret this to mean it could be positioned inside or outside the aircraft, preferably in or near the cockpit, as long as it is easily found when looked for. The ANO used to require also the name and address of the registered owner to be included on the plate. A change in the ANO has dispensed with that requirement, which now means that the plate does not need changing with every change of ownership. Suitable plates are available from the LAA, see paragraph 4 of this Technical Leaflet."
Which is a long and convoluted way of saying your guess is as good as ours (although why the description of what is *not* required?!)
NB The LAA-supplied plates (if still available) contain more info than is required - no name and address required - so I made mine out of 2 or 3 mm SS ~40 x 100 mm (1.5" x 4" if you're reading in black and white) and affixed (rivetted) it to the baggage bay rear bulkhead, TDC just above the D panel.
HTH,
Paul M
G-PLPM
XS Mono 912ULS
dglauser(at)gmail.com Guest
Posted: Fri Oct 28, 2022 8:51 am Post subject: size of aircraft data plate |
Aircraft Spruce sells what they purport to be a data plate for experimental LSA aircraft. https://www.aircraftspruce.com/catalog/pspages/dataplate09-04683.php
dg
On Fri, Oct 28, 2022 at 9:39 AM Paul Mansfield <europaul383(at)hotmail.com (europaul383(at)hotmail.com)> wrote:
[quote]--> Europa-List message posted by: Paul Mansfield <europaul383(at)hotmail.com (europaul383(at)hotmail.com)>
Hello Rowland,
HTH,
Paul M
G-PLPM
XS Mono 912ULS
alan.twigg775(at)gmail.co Guest
Posted: Fri Oct 28, 2022 9:28 am Post subject: size of aircraft data plate |
LAA discontinued the plate
Alan
| Quote: | On 28 Oct 2022, at 17:36, Rowland Carson <rowlandcarson(at)gmail.com> wrote:
in friendship
Rowland
> On 2022-10-28, at 17:02, Kelvin Weston <kelv(at)kdweston.biz> wrote:
> Hi Rowland
> Here is an old link to the Data Plate offered by the LAA:
> http://www.lightaircraftassociation.co.uk/engineering/aircraft_id_plate.html
> Not sure if they are still available but it may give an idea of size.
> Regards
> Kelv Weston
> Kit 497
> http://forums.matronics.com/viewtopic.php?p=508177#508177
Rowland_Carson
Posted: Fri Oct 28, 2022 12:50 pm Post subject: size of aircraft data plate |
On 2022-10-28, at 17:50, David Glauser <dglauser(at)gmail.com (dglauser(at)gmail.com)> wrote:
David - thanks for the link. I note that Aircraft Spruce quote their data plate as made from 1/2-inch thick material!
in friendship
Rowland
| Rowland Carson ... that's Rowland with a 'w' ...| <rowlandcarson(at)gmail.com (rowlandcarson(at)gmail.com)> http://www.rowlandcarson.org.uk| Skype, Twitter: rowland_carson Facebook: Rowland Carson
BobD
Joined: 05 Jan 2016 Posts: 117 Location: Sheffield UK
Posted: Sat Oct 29, 2022 2:11 am Post subject: Re: size of aircraft data plate |
Rowland,
The attached example (from another aircraft I built and sold recently) is 60mm x 30mm. I located it on the Control Panel in a prominent position (which helped me remember the correct call sign when making radio calls !). It is made from steel, and cost less than £12.00. It came from
https://www.signomatic.co.uk/
I believe it satisfies the requirements of CAP 523
The reason I still have this is that I was unsatisfied with the colouring of the letters. They replaced it without any problem.
171.26 KB |
7667 Time(s) |
_________________ Bob Dawson
Europa XS TG || 912 ULS || G-NHRJ || Dynon Skyview || PilotAware || SmartAss3 |
Rowland_Carson
Posted: Sat Oct 29, 2022 2:22 am Post subject: size of aircraft data plate |
Thanks!
| Quote: | On 2022-10-29, at 11:11, BobD <rjdawson14(at)gmail.com> wrote:
Rowland,
Bob Dawson
http://forums.matronics.com/viewtopic.php?p=508185#508185
http://forums.matronics.com//files/2022_10_29_105159_191.jpg
