Clarify Z101
bcone1381
PostPosted: Thu Oct 20, 2022 10:23 am    Post subject: Clarify Z101 Reply with quote
1) Clarify for me why the Z101 Alternator Field portion of the Master Switch circuit that runs from the Main Bus Bolt to the Master Switch circuit calls for a fusible link between the bus bolt and the 5A CB.
2) Clarify for me how the Aux Feed (Brown Out) bus is used. Is its normal use limited to pre flight activities? Is it normally off or on during flight? Are items on the bus like the #1 COMM radio powered normally from the Main Bus with the AUX Bus power use temporary during start and clearance delivery activities?
3) Does your Electronics International CGR-30P Engine Monitor stay on line during engine start, or will it reboot?
Brooks Cone
Bearhawk Patrol Kit Build
Eric Page
PostPosted: Thu Oct 20, 2022 11:55 am    Post subject: Re: Clarify Z101 Reply with quote
The wire from the bolt (probably located next to the battery, either on the firewall or in the aft cabin area) to the ALT FLD circuit breaker (on the instrument panel) would otherwise be unprotected against a short to ground. Since fuses and CBs are not used in series, the fusible link wire provides protection against a dead short while easily carrying normal field current and being essentially immune to nuisance trips or vibration effects.
The AUX BUS/AUX ALT switch is normally off during flight, and the AUX BUS is fed via the diode bridge (colored pink, labeled "W10," just above and to the right of the battery contactor). If the BATTERY CONTACTOR fails open, that feed is lost, so the AUX BUS/AUX ALT switch is moved to the center "AUX BUS" position, closing the AUX BUS ALTERNATE FEED relay and feeding the AUS BUS from the fat wire tie point on the hot side of the BATTERY CONTACTOR. If the main alternator or regulator fails, (as Bob would say, finish your cup of coffee, fold your newspaper, then...) move the switch to the upper position to close the AUX BUS alternate feed relay and activate the auxiliary alternator.
The AUX BUS switch can be closed to activate the relay during preflight activities if needed, then once the MASTER switch is on, turn the AUX BUS switch off.
The AUX BUS will not inherently prevent any susceptible avionics from rebooting during engine start. That protection must be built in (low minimum input voltage) or be added via an inline energy storage device (backup battery or capacitor bank) or via a DC-to-DC boost converter (as shown in green, below the MAIN POWER DISTRIBUTION BUS).
If the airplane is intended for IFR flight then you'll probably opt for a backup battery to maintain instrumentation under all circumstances. All other options that we've considered on the AE-List work only as start-induced-brownout protection.
It will probably be fine. According to the specifications shown here...
https://iflyei.com/product/cgr-30p-premium/#CGR-30P-Specifications
...the power requirements are 7.5-30V. Something is wrong if your bus voltage is dropping below 7.5V during start.
Ceengland
PostPosted: Thu Oct 20, 2022 1:03 pm    Post subject: Clarify Z101 Reply with quote
Brooks Cone
For #1, it's to protect the wire between the bus and the breaker. The
bus has enough current available to 'light up' the wire; because it's
tied directly to the bus, protection is needed.
www.avast.com
PostPosted: Thu Oct 20, 2022 1:23 pm    Post subject: Re: Clarify Z101 Reply with quote
If the battery contactor fails open during flight (unlikely), how will the pilot know it?
Joe Gores
Eric Page
PostPosted: Thu Oct 20, 2022 1:58 pm    Post subject: Re: Clarify Z101 Reply with quote
Haha! Good point, Joe. I was looking at the AUX ALT B lead (connected to the hot side of the contactor), since that was the switch involved in the OP's question. Obviously the MAIN ALT will keep everything powered even if the contactor fails open, and the failure will only be evident once the engine is shut down.
bcone1381
PostPosted: Thu Oct 20, 2022 6:22 pm    Post subject: Re: Clarify Z101 Reply with quote
I am building a Bearhawk Patrol...similar to a Husky or Supercub. Its VFR, with merely a Garmin G5, Engine Monitoring System, Surefly ignition, and Bendix Mechanical FI.
I have done my load analysis, drawn most schematics for individual circuits and now am selecting the parts of Z101 that will make up my electrical system. I'm keeping this simple. I will be satisfied with a Main bus and Battery Bus and will not install the CD/Aux/BO bus components.
I request help deciding whether to include the Engine Bus.
Each Ignition demands only 1.4A. I will install a 16ah battery, 40A main alternator, and SD-8 Aux Alt. The Surefly ignition manual says to wire the ignition module directly to the battery terminal. It seems prudent to me to connect the second ignition wire to the BATT side of the Battery Contractor. The aux fuel pump will be on the main bus.
Does this seem logical? Building the Engine bus components seems more suited for a complex higher load installation.
But I fear leaving out these four extra components of the engine bus architecture will compromise the system, but I cant see how without multiple failure modes. What am I missing?
Brooks Cone
PostPosted: Fri Oct 21, 2022 1:31 am    Post subject: Re: Clarify Z101 Reply with quote
The simpler the electrical system is, the less chance of pilot error.
I would wire one ignition to the either the battery terminal or to the battery side of the battery contactor.
Wire the second ignition to the main power bus.
In the unlikely event that the battery contactor or battery itself fails, there are two alternators that can power the second ignition.
Joe Gores
wsimpso1
PostPosted: Fri Oct 21, 2022 4:53 am    Post subject: Re: Clarify Z101 Reply with quote
Answering the OP questions in order:
1) The CB is usually part of the crowbar over voltage protection for the alternator. If it is fed by a long wire, it can be shorted without tripping the downstream CB. we usually find it appropriate to protect the plane from burning with a fuse or fusible link. Makes me wonder if the CB should be closer to the battery...
2) Brownout preventer keeps the volatile memory alive through engine start. Cranking usually draws circuits to 10 Volts or below, which usually causes electronics to reboot. These gadgets keep the navigator alive through cranking so you can program routes, etc before engine start. Evaluate the need based upon your use, programming, etc.
3) Don't know that gadget, but others already have responded
Ceengland
PostPosted: Fri Oct 21, 2022 6:37 am    Post subject: Clarify Z101 Reply with quote
By design, the alt field breaker needs to be pilot-accessible while in
flight, in consideration of a potential 'nuisance trip' (reset *one*
time if it trips in flight). Having it closer to the battery would mean
having the battery close to the instrument panel....
www.avast.com
PostPosted: Fri Oct 21, 2022 8:03 am    Post subject: Clarify Z101 Reply with quote
in vast majority of instances, he wouldn't until
dropping to taxi rpms after landing whereupon
the bus voltage might drop.
out of that stuff?"
PostPosted: Fri Oct 21, 2022 8:06 am    Post subject: Clarify Z101 Reply with quote
At 04:58 PM 10/20/2022, you wrote:
--> AeroElectric-List message posted by: "Eric Page" <edpav8r(at)yahoo.com>
Correct! The Beech Bonanzas and Barons do
NOT link battery master to the alternator
switch(es). In fact, alternator-only ops
are not prohibited in the flight manuals.
out of that stuff?"
bcone1381
PostPosted: Fri Oct 21, 2022 1:25 pm    Post subject: Re: Clarify Z101 Reply with quote
Regarding my 3 Original question in post 1....
1) I understand now why we fuselink the ALT FLD wire at the main bus. Thank you for helping me understand.
2) I understand now why the B.O. Bus exists, and how it is powered, and how it is to be used during the preflight, under normal circumstances, and after a Main Alternator fails. I also now understand how the Brown Out preventer helps keep voltage up during engine start. Thanks again for helping me.
3) I learned from another user that this engine monitor I have chosen stays on line during engine starts without a brown out preventer circuit.
 Filesize:  168.87 KB
 Viewed:  10310 Time(s)
Brooks Cone
johnbright
PostPosted: Sat Oct 22, 2022 4:07 am    Post subject: Re: Clarify Z101 Reply with quote
The installation manual says it works between 7.5 and 30V.
 Filesize:  132.98 KB
 Viewed:  10286 Time(s)
John Bright, RV-6A
Single battery, wound-field alternator on main bus, MZ-30 PM generator on engine/essential bus.
N1921R links
wsimpso1
PostPosted: Sat Oct 22, 2022 4:22 am    Post subject: Re: Clarify Z101 Reply with quote
When the pilot pulls the throttle to idle, voltage drop from 14 might be noticed.
A further point is to review the failure modes and their effects. Looking at things that way may be enlightening. With the battery contactor failed open and wired per legacy designs, if the pilot (for whatever reason) attempts a reset of the alternator, the airplane goes dark and the alternator will not be re-energized. Why would a pilot do that? It is an instructional tool used by some instructors and some pilots check alternator function this way. Not saying it is right, but it is out there. Seems to be pretty low likelihood...
With the designs we find dear to us from AeroElectric Connection, we have alternate methods of repowering the fields of our main and aux alternators. Z-12 has E-Bus Alternate Field switch, Z-14 has always hot buses, etc. Failure tolerant design changes the rare failed contactor from a full blown emergency into a ramp failure, and a simple repair.
Billski
bcone1381
PostPosted: Sat Oct 22, 2022 2:33 pm    Post subject: Re: Clarify Z101 Reply with quote
Awesome, Thanks for hunting that down John! Feedback I'm getting fro a supercub owner agrees that it stays on line during start.
Brooks Cone
