Forest of tabs - corrosion question
heedh23
PostPosted: Tue Sep 06, 2022 2:43 pm    Post subject: Forest of tabs - corrosion question Reply with quote
Recently on one of the Vans facebook groups, there was a picture of a homemade forest of tabs that another builder made for their electrical system. This led to a discussion on whether the aluminum rivets holding the tabs onto the copper plate would corrode, whether brass rivets were necessary, etc.
My question is this - if aluminum "sacrifices" itself when in contact with copper due to galvanic corrosion, why doesn't the aluminum sheet/structure that contacts a forest of tabs corrode? Is it the presumed lack of an electrolyte? Is it a requirement to use some magic unobtanium alloy of copper?
Thanks in advance for the education.
-Ed
PostPosted: Wed Sep 07, 2022 8:44 pm    Post subject: Forest of tabs - corrosion question Reply with quote
At 05:43 PM 9/6/2022, you wrote:
--> AeroElectric-List message posted by: "heedh23" <heedh23(at)msn.com>
Excellent question . . .
The original design I crafted for B&C's products
SOLDERED strips of tabs to the base plate. This
preserves electrical integrity between bus plate
and tabs.
At the time it was designed the target mounting
surfaces were stainless and composite
firewalls.
This assembly can be mounted on an aluminum surface
that stays dry.
Riveted assemblies are not recommended.
out of that stuff?"
 Filesize:  201.78 KB
 Viewed:  4659 Time(s)
Ceengland
PostPosted: Thu Sep 08, 2022 5:14 am    Post subject: Forest of tabs - corrosion question Reply with quote
-Ed
As Bob & others said, riveting is far from optimal for electrical
connections. It's pretty simple to just 'flow solder' the tabs to the
plate by using a propane torch under the plate while adding solder to
the tab/plate intersection.
www.avast.com
Eric Page
PostPosted: Thu Sep 08, 2022 6:32 am    Post subject: Re: Forest of tabs - corrosion question Reply with quote
I built mine by setting a brass plate on top of a burner on my gas cooktop. Then I smeared solder paste on the bottom of several 6-way quick-connect tabs and placed them where I wanted them on the plate. Finally, I turned the burner on low and waited for the solder paste to reflow. Photo attached.
If you do it this way, turn the hood fan on high (there's some smoke) and have some sort of heatproof tool handy to nudge the tabs into the desired position as the assembly cools, as they'll move a bit when the paste melts.
I got the brass plate for cheap on eBay and cut it to size. Here's one seller...
http://www.ebay.com/itm/293905310788
The quick-connect tabs are in stock at Digi-Key in 4-way, 6-way and 10-way versions...
4-way: https://www.digikey.com/short/q3pjw0cw
6-way: https://www.digikey.com/short/83hdh0j2
10-way: https://www.digikey.com/short/5br0n7fv
Solder paste is available pretty cheaply on eBay (or you can just feed normal solder wire into the joints once the plate is hot). Here are a couple of U.S. sellers in the $7 range...
http://www.ebay.com/itm/384953664130
http://www.ebay.com/itm/313843925100
Be careful that you don't accidentally buy paste flux; eBay sellers frequently mix up search terms in their listing titles and the packaging is very similar.
Finally, I got brass hardware at Home Depot for mounting it to the firewall and securing the negative cable on the engine side.
1/4-20 x 3" bolt: https://www.homedepot.com/p/204274747
1/4-20 hex nuts: https://www.homedepot.com/p/204274130
1/4" flat washers: https://www.homedepot.com/p/204780701
1/4" stainless lock washers: https://www.homedepot.com/p/204276509
DIY 48-way forest-of-tabs made from 1/8" brass plate and soldered 6-way quick-connect tabs. The through-bolt is secured with washers and two jammed nuts (brass all-metal lock nuts are apparently unobtanium). A stainless rivet will prevent rotation.
 Filesize:  123.42 KB
 Viewed:  4636 Time(s)
yellowduckduo(at)gmail.co
PostPosted: Thu Sep 08, 2022 7:24 am    Post subject: Forest of tabs - corrosion question Reply with quote
Steel pop rivets and solder on the tabs.
No corrosion at tabs or on aluminum where it is bolted to structure
after 17 years in an open T hangar.
Ken
On 08-Sep.-22 9:14 a.m., Charlie England wrote:
<ceengland7(at)gmail.com>
> -Ed
PostPosted: Thu Sep 08, 2022 8:26 am    Post subject: Forest of tabs - corrosion question Reply with quote
At 10:23 AM 9/8/2022, you wrote:
--> AeroElectric-List message posted by: C&K <yellowduckduo(at)gmail.com>
No corrosion at tabs or on aluminum where it is bolted to structure after 17 years in an open T hangar.
Ken
Good data point. "Fixtured" with rivets
before soldering. Thanks!
out of that stuff?"
