I think I found the leak!
dmac7
PostPosted: Thu Aug 18, 2022 9:05 pm    Post subject: I think I found the leak! Reply with quote
In 2018 while my Mono was waiting for me to get it airworthy, the fuel tank dumped the very stale gas, and it smelled very bad btw.
The other day I think I found the leak, starboard side, rear wall of tank near center hump.
One could seal it from the outside but maybe that is a non durable idea?
Thoughts anyone?
dmac7
PostPosted: Fri Aug 19, 2022 10:57 am    Post subject: Re: I think I found the leak! Reply with quote
A photo of the suspect area
 Filesize:  346.46 KB
 Viewed:  3529 Time(s)
ward.t(at)xtra.co.nz
PostPosted: Fri Aug 19, 2022 12:07 pm    Post subject: I think I found the leak! Reply with quote
Just confirm it is not leaking from the fuel vent outlet and fuel intake to the tank? Then dripping down to the floor on the starboard side. Have had a builder here who didn’t allow enough room for the intake boss to move and cracked the intake boss.Cheers, Tim
Sent from my iPadTim Ward
12 Waiwetu Street,
Fendalton,
Christchurch, 8052
New Zealand.
021 0640221
On 20/08/2022, at 7:03 AM, dmac7 <dmac7(at)outlook.com> wrote:
--> Europa-List message posted by: "dmac7" <dmac7(at)outlook.com>
http://forums.matronics.com/viewtopic.php?p=507712#507712
http://forums.matronics.com//files/pxl_20220818_033636401night2088_482.jpg
====================================================; - MATRONICS WEB FORUM====================================================; - NEW MATRONICS LIST WIKI -
_====================================================bsp; - List Contribution Web Site -
_   &n======================================================
dmac7
PostPosted: Sat Aug 20, 2022 11:00 am    Post subject: Re: I think I found the leak! Reply with quote
Thanks for commenting Tim, much appreciated. The leak was low on the tank as evidently it emptied the tank.
Perhaps I should put a few gallons of water in the tank view the leak in action?
I was hoping the leak was as simple as sight gauge connection leak or that sort of thing but I think the photo shows the crack down low behind the rudder cable back wall of tank.
Could one paste something like Pro Seal on outside of crack and have a fix?
The Dave Disney fix with a removable lid where one can gain access to the interior seems the best solution I've seen for a durable repair. A most intelligent idea in my opinion.
Dave Disney
PostPosted: Sun Aug 21, 2022 7:20 am    Post subject: Re: I think I found the leak! Reply with quote
Hi dmac,
Take a good look at the thread below, I've been there, done that and got the 'T' shirt!!
The only way I could find the leak in my tank was by cutting the access panels. Believe me, I tried all ways including water with black food colouring added, nothing showed where the leak was.
http://forums.matronics.com/viewtopic.php?t=16779326&sid=74a471ce5b26390ad78da7690ddc6ba1
Dave Disney
