Fuel tank leak
wdaniell.longport(at)gmai
PostPosted: Sun Jul 10, 2022 1:56 pm    Post subject: Fuel tank leak Reply with quote
So it appears i am another victim of cracked fuel tank.  I filled up, right up the neck a couple of days ago and no abnormalities.   Today i filled up and fuel was leaking significantly from the top tank shelf.
Does anyone by chance have a fuel tank that they want to get rid of?
I would also be interested in an unuseable one as i am toying with the idea of constructing an aluminum one.
Photographs of the tank pre instalation would also be useful.
Many thanks
Will
William Daniell
+1 786 878 0246
Fred Klein
PostPosted: Sun Jul 10, 2022 6:21 pm    Post subject: Fuel tank leak Reply with quote
ouch…you’ve my sympathies Will…good luck with replacing it…
Fred
On Jul 10, 2022, at 2:56 PM, William Daniell <wdaniell.longport(at)gmail.com (wdaniell.longport(at)gmail.com)> wrote:
barp99(at)gmail.com
PostPosted: Sun Jul 10, 2022 8:21 pm    Post subject: Fuel tank leak Reply with quote
Will,
Here is a sketch of my fuel tank with some dimensions, sorry about the
metric dimensions, all my rulers are metric, hope this helps.
Brian Phillips
Many thanks
Will
William Daniell
+1 786 878 0246
 Filesize:  583.6 KB
 Viewed:  10234 Time(s)
Area-51
PostPosted: Mon Jul 11, 2022 2:09 am    Post subject: Re: Fuel tank leak Reply with quote
This seems to be a common issue.. wondering if its cost effective to reproduce these fuel tanks in polyethylene blow molding?
spcialeffects
PostPosted: Mon Jul 11, 2022 9:51 am    Post subject: Re: Fuel tank leak Reply with quote
Sent you at email Will, hope it reaches you
Frank
n7188u
PostPosted: Mon Jul 11, 2022 10:23 am    Post subject: Re: Fuel tank leak Reply with quote
Sorry to hear Will. I hope the repair goes smoothly.
I think that the day I go through this I will make a fiberglass tank as done by one of our members in the US. I met him during SnF this year but can't remember his name. My LongEZ tank is epoxy glass construction and is 30 years old with no leaks. This member built a foam plug covered with duct tape for release and then covered with glass. Made a top and bottom and then joined together once the plug was removed. Also made some really nice aluminum reinforced sections to drill and tap to use screw fittings for the pickup at the bottom. Much better than the silly bosses our tanks have. He also adjusted the size so that the door sill would not need to be cut (or so is my understanding).
He did a nice job and he's happy with the outcome. Of course, getting a PE tank, if still available, is the fastest and less labor intensive route but then you run the risk of going through the same BS in the future.
BTW, make 100% sure it is the tank. My neighbor once swore he had a tank leak and it was hose/fitting related. But I am sure you checked for that.
Best of luck,
Chris
PostPosted: Mon Jul 11, 2022 1:07 pm    Post subject: Fuel tank leak Reply with quote
Chris
I am pretty sure its the tank...nothing else is leaking and it was firmly glued in place.
I have looked at the composite option but it appears that it won't work with ethanol blends....works with AVGAS tho.
William Daniell
LONGPORT
+1 786 878 0246
On Mon, Jul 11, 2022 at 2:25 PM n7188u <chmgarb(at)gmail.com (chmgarb(at)gmail.com)> wrote:
--> Europa-List message posted by: "n7188u" <chmgarb(at)gmail.com (chmgarb(at)gmail.com)>
Best of luck,
Chris
http://forums.matronics.com/viewtopic.php?p=507448#507448
="noreferrer" target="_blank">https://matronics.com/contribution
n7188u
PostPosted: Mon Jul 11, 2022 1:24 pm    Post subject: Re: Fuel tank leak Reply with quote
You bring up a good point Will. However, I would think that this day and age you can get epoxy that will resist gasoline. FG tanks are not uncommon in the boating world.
I did find this:
https://theepoxyexperts.com/shop/adhesives/chemical-and-water-resistant/max-gre/max-gre-96oz-epoxy-resin-gasoline-resistant-4-coating-glue-fiberglassing-carbon-fiber/
However, what a PITA to have to research all this and run the risk of it not working (and the danger of the tank falling apart and clogging the fuel system). Aluminum would certainly be safer but $$$ and possibly heavier.
let us know what you end up doing.
Chris
PostPosted: Mon Jul 11, 2022 1:52 pm    Post subject: Fuel tank leak Reply with quote
Chris thanks
yea... I have googled it and I saw an article by a glasair builder.  He tried with AVGAS and the composite was fine after a year....with ethanol it was already soft after a week!
Ill give these guys a ring...
I am guessing that the aluminium will be heavier and smaller (more difficult to include all the complex curves).  I have emailed Europa in the UK so we'll see if they respond.
Will
William Daniell
LONGPORT
+1 786 878 0246
On Mon, Jul 11, 2022 at 5:26 PM n7188u <chmgarb(at)gmail.com (chmgarb(at)gmail.com)> wrote:
I did find this:
Chris
http://forums.matronics.com/viewtopic.php?p=507451#507451
peterz(at)zutrasoft.com
PostPosted: Mon Jul 11, 2022 2:27 pm    Post subject: Fuel tank leak Reply with quote
ya, the canard-clan's use of E-Z Poxy with their slow hardner works great for alc-free mogas as per the tank I made for my HummelBird - 4 years ago and still nice and hard without any flaking.
I'm sure it would get soft with E95 tho.
PeteZ
PS-  if going the with a stock tank, get it re-flouronated by these guys that are in the supply chain for the auto industry tanks and shampoo bottles.  I did my stock tank and it came back with a severe frosted finish - so it must be doing something Smile   It sadly still has not seen mogas yet Sad
On Mon, Jul 11, 2022 at 5:58 PM William Daniell <wdaniell.longport(at)gmail.com (wdaniell.longport(at)gmail.com)> wrote:
Chris thanks
Will
William Daniell
LONGPORT
+1 786 878 0246
I did find this:
Chris
Plant.Locations.pdf
 Filename:  Plant.Locations.pdf
 Filesize:  63.57 KB
 Downloaded:  438 Time(s)
PostPosted: Mon Jul 11, 2022 3:06 pm    Post subject: Fuel tank leak Reply with quote
thanks pete.  I was actually looking for a "flourinator"!
William Daniell
LONGPORT
+1 786 878 0246
On Mon, Jul 11, 2022 at 6:29 PM Pete Zut <peterz(at)zutrasoft.com (peterz(at)zutrasoft.com)> wrote:
PeteZ
Chris thanks
Will
William Daniell
LONGPORT
+1 786 878 0246
I did find this:
Chris
PostPosted: Mon Jul 11, 2022 3:22 pm    Post subject: Fuel tank leak Reply with quote
When I did mine, I requested their full automotive level (to meet EPA)  fwiw.
PeteZ
On Mon, Jul 11, 2022 at 7:13 PM William Daniell <wdaniell.longport(at)gmail.com (wdaniell.longport(at)gmail.com)> wrote:
William Daniell
LONGPORT
+1 786 878 0246
PeteZ
Chris thanks
Will
William Daniell
LONGPORT
+1 786 878 0246
I did find this:
Chris
Area-51
PostPosted: Mon Jul 11, 2022 3:30 pm    Post subject: Re: Fuel tank leak Reply with quote
Have a look at epoxy materials and processes used for constructing motorcycle racing tanks; they are used to successfully contain 100% ethanol, methanol and blended fuel; basically the inside of the tank is treated with a long lasting (+10 years) membrane liquid before operationsl use.
PostPosted: Mon Jul 11, 2022 5:59 pm    Post subject: Fuel tank leak Reply with quote
Interesting
I will follow that up.
William Daniell
+1 786 878 0246
On Mon, Jul 11, 2022, 20:55 Wladimir Kummer <wladimirkummer(at)gmail.com>
wrote:
[quote] Hi William,
You may search for vynilester resins. Here in Brazil our fuel has 25% of
ethanol and lots of old car builders use Derakane (411-350) for their fuel
tanks with great success.
Best regards
Wladimir
[image: Mailtrack]
<https://mailtrack.io?utm_source=gmail&utm_medium=signature&utm_campaign=signaturevirality11&> Sender
notified by
Mailtrack
<https://mailtrack.io?utm_source=gmail&utm_medium=signature&utm_campaign=signaturevirality11&> 11/07/22
21:50:21
Em seg., 11 de jul. de 2022 às 18:54, William Daniell <
wdaniell.longport(at)gmail.com> escreveu:
> Chris thanks
> Will
> William Daniell
> LONGPORT
> +1 786 878 0246
>> I did find this:
Area-51
PostPosted: Tue Jul 12, 2022 1:30 am    Post subject: Re: Fuel tank leak Reply with quote
https://www.kbs-coatings.com/how-much-tank-sealer.html
 Filesize:  65.71 KB
 Viewed:  10154 Time(s)
elinorsha
PostPosted: Mon Aug 01, 2022 4:11 am    Post subject: Re: Fuel tank leak Reply with quote
I don't really like the cold, so I prefer the sunny days in California, where it's always warm. But I hear there are mountains in those places, have you tried climbing one of them and launching a drone. I just wonder if it will take off at an altitude where the air is rarefied. I've heard that to fly at that altitude you need propellers at least 44 inches in diameter for a 4-pound aircraft. This was calculated simply with a cm to inches converter for more accurate calculations.
