New instrument panel blank
MDDRVR
PostPosted: Wed Jun 08, 2022 7:45 am    Post subject: New instrument panel blank Reply with quote
I’m trying to find a source to replace the center instrument panel for both the front and rear cockpits. TheYakCollection.com appears to no longer have a functioning website. Are there any other sources?
Yakjumper
PostPosted: Wed Jun 08, 2022 8:48 am    Post subject: Re: New instrument panel blank Reply with quote
I made a new panel for my front cockpit in my Yak-52.
A new aluminium plate which goes over the old one (old one was good but had too many cutouts).
Made it to fit my instruments and a GRT GPS.
Is that what you are looking for ? Got the .ai or .dfx if needed. Std instrument cutouts can be found at the manufactures page to adjust to your setup.
Can UL the file, just let me know. I also have a spare new IP if someone needs it, but with cutout for the GRT GPS.
 Filesize:  292.5 KB
 Viewed:  11047 Time(s)
MDDRVR
PostPosted: Thu Jun 09, 2022 8:59 am    Post subject: Re: New instrument panel blank Reply with quote
My preference is a new factory blank. I'm putting in a Dynon HDX , UAvionics AV-30, and Avidyne IFD440 so I pretty much need a blank slate. Can you shoot what you have to me?
jwl2002(at)live.com
Stressmerchant
PostPosted: Fri Jun 17, 2022 2:40 am    Post subject: Re: New instrument panel blank Reply with quote
Could you upload the DXF? I'm considering an instrument panel upgrade, it would really help to be able to get an accurate layout.
Yakjumper
PostPosted: Fri Jun 17, 2022 2:53 am    Post subject: Re: New instrument panel blank Reply with quote
Here is the DXF for the front IP. I had a flat sheet cut out and placed it over the old IP.
Made it myself, so its not perfect, but free to share. Hope its useful.
Picture shows my new overlay panel with a GRT gps instead of the russian horizont.
 Filesize:  1.07 MB
 Viewed:  10973 Time(s)
Panel Yak 52.dxf
 Filename:  Panel Yak 52.dxf
 Filesize:  357.38 KB
 Downloaded:  815 Time(s)
fishmouth500
PostPosted: Sun Jun 19, 2022 9:17 am    Post subject: New instrument panel blank Reply with quote
https://www.ebay.com/itm/175320450806?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=7TSHK9gSTri&sssrc=2349624&ssuid=7TSHK9gSTri&var=&widget_ver=artemis&media=COPY
On Fri, Jun 17, 2022 at 3:57 AM Yakjumper <tobias(at)irgendwo.eu (tobias(at)irgendwo.eu)> wrote:
--> Yak-List message posted by: "Yakjumper" <tobias(at)irgendwo.eu>
Here are DXF and EPS (in one zip) for the front IP. I had a flat sheet cut out and placed it over the old IP.
http://forums.matronics.com/viewtopic.php?p=507221#507221
http://forums.matronics.com//files/ippanel_new_446.jpeg
http://forums.matronics.com//files/panel_yak_52_172.dxf
igator?Yak-List
/a>
bution
www.theyakcollection.com
619 933-2571
MDDRVR
PostPosted: Sat Jun 25, 2022 11:21 am    Post subject: Re: New instrument panel blank Reply with quote
Thank you!
fishmouth500
PostPosted: Sun Jun 26, 2022 2:49 pm    Post subject: Re: New instrument panel blank Reply with quote
Hey John, TYC has closed down but I’m selling the inventory on eBay. I have 1 52 blank front panel left
Also have 1 yak 50 ( all includes brackets & knobs)
3 CJ blanks and 2 Yak 55 all with hardware.
Cheers
MDDRVR
PostPosted: Mon Jun 27, 2022 4:02 pm    Post subject: Re: New instrument panel blank Reply with quote
Thanks!
