Molex connector needed for my Insight GEM 602
chaskuss(at)yahoo.com
PostPosted: Sat May 28, 2022 8:53 am    Post subject: Molex connector needed for my Insight GEM 602 Reply with quote
I need to buy the Molex connector for my Insight GEM 602. It is a 15/30 pin edge connector with a 0.100" pitch between contacts. It also has a notch in the card to prevent the connector being installed backwards. Any idea what the part number I need is and where I could buy it? There is no info regarding this in the documentation I received with the unit. It also appears that this series [4338 ??] of connector has been deemed obsolete by Molex.
Charlie Kuss
PS I tried to attach a photo of the rear of the unit, but this forum does not allow jpg attachments.
Ceengland
PostPosted: Sat May 28, 2022 12:43 pm    Post subject: Molex connector needed for my Insight GEM 602 Reply with quote
On 5/28/2022 3:07 PM, Robert L. Nuckolls, III wrote:
At 11:15 AM 5/28/2022, you wrote:
--> AeroElectric-List message posted by: Charles Kuss <chaskuss(at)yahoo.com> (chaskuss(at)yahoo.com)
  Check out the Molex data page on my website:
https://tinyurl.com/7t6jjsc
  Data there includes descriptions and photos
  of the 4338 series connectors and pins. Yeah,
  been out of production for a long time.
  Over the years I've had some luck finding
  connectors at surplus electronics shops
  but those opportunities are growing really
  skinny too.
  I do have a few pieces of work-around left
  over from the last few times I had your
  problem. You'll see some pictures on the website
  where a builder cut two larger connectors and
  spliced them together with JB Weld to achieve
  the proper pin-count.
  Sorry, not gold plated. Not crimped either . . . ran
  out of those pins about 15 years ago. However,
  I've used this technique at least twice to get
  one of these vintage radios up and running. You're
  welcome to a 1-1/2 12-pin connectors (pictured)
  to take a whack at this fix. Keeping half of
  a connector on hand will allow me to offer this
  fix at least one more time.
Ebay is always worth a look.
Molex edge connector
My permanent solution, for experimental applications, is a soldering iron, some milspec wire, and a subD connector.
Wink
Charlie
Charlie
