andymeyer
Posted: Fri May 06, 2022 1:17 pm Post subject: Too many Circuit breakers.... |
I'm doing a panel upgrade in my Long EZ and have a lot of breakers - I shouldn't need this many. I do prefer breakers as I can disable items - especially when working on one system or another, but there's not a ton of space in a Long EZ panel.
Right now, I'm counting 16 breakers - way too many... What can I group, and are some things better left to a fuse? Garmin and Avidyne say not to group, but there's quite a few breakers here!
Accessory (USB charger, etc...)
ADS-B - Stratux
ALTernator (LR3D)
Autopilot (GMC507 + 2 servos)
Audio (GM345)
AV-30E (Backup attitude, plus full time traffic display)
ELT (ACK-E04)
Engine Monitor (Home built)
GAD29C
GDU470
GMU11
IFD540 - COMM
IFD540 - GNS
Ignition 1 (Lightspeed Plasma 3)
Ignition 2 (Lightspeed Plasma 3)
Transponder (AXP-322)
Ceengland
Posted: Fri May 06, 2022 1:48 pm Post subject: Too many Circuit breakers.... |
On Fri, May 6, 2022 at 4:21 PM andymeyer <meyerkc135(at)gmail.com (meyerkc135(at)gmail.com)> wrote:
| Quote: | --> AeroElectric-List message posted by: "andymeyer" <meyerkc135(at)gmail.com (meyerkc135(at)gmail.com)>
ADS-B - Stratux
ALTernator (LR3D)
Audio (GM345)
ELT (ACK-E04)
GAD29C
GDU470
GMU11
IFD540 - COMM
IFD540 - GNS
| Â
By 'group', do you mean putting multiple items on one protection device? The only answer is the additional devices you don't mind losing if something on the same circuit trips the circuit protection.
My strong preference is a big ATC fuse bus(es) mounted somewhere out of the way, so I don't have to make that call, and more importantly, I'm never tempted to play with them in the air. A fuse legend and a little plastic fuse puller is all that's needed to disable an individual circuit, though I rarely find the need to do that during maintenance. The only thing on that list that I'd put on a breaker is the alternator field supply.
FWIW,
_________________ Charlie |
Posted: Sat May 07, 2022 7:26 am Post subject: Too many Circuit breakers.... |
Generally a no-no in the big iron bird factories
| Quote: | | My strong preference is a big ATC fuse bus(es) mounted somewhere out of the way, so I don't have to make that call, and more importantly, I'm never tempted to play with them in the air. A fuse legend and a little plastic fuse puller is all that's needed to disable an individual circuit, though I rarely find the need to do that during maintenance. |
Hear hear! See http://aeroelectric.com/articles/fusvsbkr.html
http://aeroelectric.com/articles/fuseorcb.html
99.99% of all breakers and fuses go to the bone yard when
the airplane is scrapped NEVER having been called upon
to save the wire it feeds. Yet much cost of ownership
and valuable panel space is dedicated to breaker-farms.
Do yourself a favor and tuck a fat fuse-block away
with protection on EVERY dedicated feeder . . . make
the block big enough to have some spares for future
expansion.
| Quote: | | The only thing on that list that I'd put on a breaker is the alternator field supply. |
But even this is not necessary if you have something
other than crowbar ov management.
out of that stuff?"
Posted: Sat May 07, 2022 8:32 am Post subject: Re: Too many Circuit breakers.... |
I will add my vote for fuses to those of Bob and Charlie.
A whole fuse block with fuses might cost less than one breaker.
Circuit breakers are mechanical devices that can fail either open or closed.
I tested a circuit breaker on the bench prior to installation. It smoked instead of opening. I decided not to install a circuit breaker.
Fuses never fail to open when overloaded.
Fuses don't need to be installed on the instrument panel.
Fuses weigh less than breakers.
Each electrical load should have its own unique fuse. If it blows, only one load is lost. And you will know which circuit has the fault.
Never reset a circuit breaker or replace a fuse while airborne. Do troubleshooting when safely on the ground.
A wise man once said, "That tripped breaker or blown fuse just prevented smoke and fire. Do you want to give the fire a second chance?"
_________________ Joe Gores |
andymeyer
Posted: Sat May 07, 2022 11:54 am Post subject: Re: Too many Circuit breakers.... |
Alright - looks like I might have some breakers to sell.
What's an ideal fuse block model for the ATC fuses. Any good brand or model suggested? I'm scared of some of the stuff I see.
| nuckolls.bob(at)aeroelect wrote: |
Do I read this as: Since I've got the LR3D I don't need a breaker for the alternator even though BandC calls for one? Just put a fuse where they call for breakers?
My ignitions - 2 Lightspeeds - What's the best protection for the wires running from the panel to the back seat? I still need switches to turn them on or off, might I be better off with a W31 Breaker switch and that be it, or is the complexity of the W31 a risk? Part of me would like to be able to reset it if the engine goes quiet and I'm out of other options. Though 2 dying at once seems highly improbable.
Radio Master (Currently a W31 breaker switch) - people seem to be moving away from avionics masters - is that really the best case these days? Let the Garmin and Avidyne stuff suffer the brown-out during start and reboot? Or go around twisting knobs off and on? I'd like to be able to get rid of as much load during start. Normally, only things I have is LED Nav lights and the engine monitor. (Engine monitor only needs ~4 volts to run)
And Autopilot disable - Do I install a switch to pull power from it, or trust the interface and electrons to behave?
Thanks Charlie, Bob and Joe!
Ceengland
Posted: Sat May 07, 2022 12:52 pm Post subject: Too many Circuit breakers.... |
A lot of us are using Bussmann 15600-X-20 ATC Fuse Panels, like this:
https://www.amazon.com/Bussmann-15600-12-20-Fuse-Block-Assembly/dp/B001PYQP0E/ref=pd_lpo_2?pd_rd_i=B001PYQP0E&psc=1
The 'X' denotes the number of fuses in the block. From 4 (or maybe 2) up
to at least 18 fuses per block.
https://www.ebay.com/itm/284540458393?epid=1585402948&hash=item423feed599:g:T8AAAOSwLnBX2~T4
Bussmann also makes one with the wire exit on the bottom, but it
requires a dedicated crimper for the terminals. The 15600 has standard
1/4" blades for output terminals, so a regular PIDG crimper works for
the mating connectors.
I've not used any of them, but I'd expect any of the well known marine
vendors using ATC style fuses would be fine, too.
On 5/7/2022 2:54 PM, andymeyer wrote:
Posted: Sat May 07, 2022 2:54 pm Post subject: Re: Too many Circuit breakers.... |
I don't like those Busman fuse blocks. They don't grip the fuses as tightly as I would like. And the wires stick out to the sides which takes too much space. Look for a fuse block that has the wires exiting from the back side.
Read this thread http://forums.matronics.com/viewtopic.php?t=16762261
Pay attention to what Stein posts. He owns a well respected avionics shop.
Ceengland
Posted: Sat May 07, 2022 5:02 pm Post subject: Too many Circuit breakers.... |
On 5/7/2022 5:54 PM, user9253 wrote:
Joe Gores
Hi Joe,
Your mileage obviously varies, from mine & a lot of others.Â
I've got 3 of them in my RV-7 project, and a couple in my flying RV-6.
Maybe I'm a wimp, but I can't pull a fuse without using the
purpose-built puller or a pair of pliers. A lot of guys are using them
in flying experimentals, mounted with the fuses facing down, for
hundreds of hours without losing any fuses.
Maybe you got a bad one, or one that someone else had abused?
andymeyer
Posted: Sat May 07, 2022 7:19 pm Post subject: Re: Too many Circuit breakers.... |
Alright - I'm down to 7 breakers, plus 4 W31's...
Any thoughts on the Avionics Master? - Yes? No? Either way?
Breakers:
Alternator
Ignition 1
Ignition 2
Engine Instruments (This is home built so I want to be able to reset if needed)
Transponder (in case I need to go quiet, formation, etc... It's remote only - breaker is a fast switch)
Audio (In case I get a loud squeal or otherwise, I can get it out of the system)
Autopilot (In case it misbehaves)
W31's are switches/breakers for the following - (been in their for the same function for ~20 years) All could be switches and if the W31's give up the ghost, they will become switches / fuses:
Pitot Heat
Nav lights
Landing Light
Boost Pump
Thanks for helping me with the simplification - I'm liking this a lot better and gaining a lot of comfort!
Andy
Posted: Sun May 08, 2022 3:29 am Post subject: Re: Too many Circuit breakers.... |
Charlie, Maybe my Busman fuse block was defective or maybe I am too much of a perfectionist. But the fuses did not require much force to pull out. The spring contacts only gripped the fuse at one location. I made my own fuse block using contacts similar to spade connectors which grip the fuse on two edges. See Mouser part number 534-3522. I have to use a tool to pull a fuse out.
4.65 KB |
17231 Time(s) |
Posted: Sun May 08, 2022 4:16 am Post subject: Re: Too many Circuit breakers.... |
Andy, read this http://www.aeroelectric.com/articles/avmaster.pdf
An avionics master switch is an unnecessary failure point. If it fails, all avionics are lost. If not installed, it can not fail.
There are no voltage spikes that can damage avionics during engine starting.
There is a voltage sag during starting that might cause avionics to reboot. But voltage sag while cranking the engine will not damage avionics.
Some pilots argue that they don't want to wear out individual avionics switches, so they install an avionics master switch. Actually, switches need to be exercised to wear away corrosion. Switches are designed to be operated tens of thousands of times. How many times will you operate avionics switches during your lifetime?
My airplane does not have an avionics master switch. I leave all avionics turned on during engine start. I have started my plane hundreds of times over the past 11 years. All avionics still work fine.
Ceengland
Posted: Sun May 08, 2022 5:04 am Post subject: Too many Circuit breakers.... |
On Sun, May 8, 2022 at 7:42 AM user9253 <fransew(at)gmail.com (fransew(at)gmail.com)> wrote:
| Quote: | --> AeroElectric-List message posted by: "user9253" <fransew(at)gmail.com (fransew(at)gmail.com)>
Joe Gores
| This is what the Bussmann looks like inside. (I 'modded' one to have two buses in one block.)
Â
89.28 KB |
17219 Time(s) |
Ceengland
Posted: Sun May 08, 2022 5:36 am Post subject: Too many Circuit breakers.... |
On Sat, May 7, 2022 at 11:10 PM andymeyer <meyerkc135(at)gmail.com (meyerkc135(at)gmail.com)> wrote:
Breakers:
Alternator
Ignition 1
Ignition 2
Pitot Heat
Nav lights
Landing Light
Boost Pump
Andy | My philosophy on stuff that keeps the engine running is that it should be independent of any a/c bus, just like conventional carb/mags engines are. What does the electronic engine mfgr say about how to supply power to the ignitions? There's one full bore controller mfgr (that I'd never consider using) that advises stuff that's truly scary, but most tell you to run the ignition supply directly from the battery, ahead of any master contactor, etc. If you do that, in my mind fusible links (at the battery) are by far the most bullet-proof system to protect the wire with no chance of a 'nuisance trip'.
If we ignore the fact that you already have the CBs, nothing on that list would have a breaker in my plane, except the alternator field, and that only because I'm using crowbar style overvoltage protection. Almost anything that needs to be switched can be controlled with a switch that will be cheaper, lighter, and likely more reliable than a CB; especially a combo switch/breaker.Â
For me, any decision about an avionics master would be driven by operational convenience, and whether I need the ability to load-shed, in a failed alternator situation. In the totally electrically dependent plane I'm building, I have dual identical alternators, so load shedding isn't an issue. I therefore have an engine master, that controls the bus that powers the engine, and an airframe bus, that powers the rest of the plane. I suppose we could call the airframe bus an 'avionics bus', but it's really everything except the stuff that keeps the engine running. There's a bus-tie switch that can power the engine bus from the airframe bus, as backup if something in the engine master circuit fails.
If you need to shed loads for alternator-out, then putting all non-essential stuff on a separate switched bus would make sense.
There's also the issue of 'brownout' and rebooting at engine start. If that's an inconvenience, you can pick between letting everything boot at master-on and use a brownout booster, or using an avionics master & powering the avionics after engine start. I only had one thing (an EFIS) in my current flying a/c that rebooted at engine start, so I made a brownout booster using a little $5 'boost' regulator, wired to the supply and to a diode-isolated power input on the EFIS.Â
I do have an 'essential' bus in the flying a/c that can be left powered up if I need to turn off the master to conserve battery energy (the flying a/c has only one alternator). The essential bus makes it basically a one step operation to shed nonessential loads, instead of having to individually turn off stuff, which could be overlooked in a stressed environment.
andymeyer
Posted: Sun May 08, 2022 7:59 pm Post subject: Re: Too many Circuit breakers.... |
Alright...
Down to 4 breakers which may turn into switches... Engine Monitor, Transponder, Audio panel (remote) and the autopilot. Those are things I feel I must be able to shut down hard.
My engine monitor so I can reset the thing - didn't design a reset input into the PCBA, though that may come with the next board turn. Just ordered the PCBA's 2 weeks ago.
My essential bus will be the following - uAvionix AV30 (basic EFIS), GPS Navigator, and the engine monitor.
Battery bus will be the two Lightspeed ignitions - switch, no breaker, just fuse links.
Keeping the Avionics bus - bad habits are hard to break.
Because the Avidyne IFD has dual power inputs that are diode or'd, I'll feed one side from the Avionics and the other from the Essential bus. Other items don't so I'll put two schottky diodes in to prevent backfeeding. Or, what 20A schottky diode is recommended that can support my whole essential bus? Can't see where I can buy the AEC9001-1.
One ignition will have a 3 position switch - middle position will go to a small standby battery for power in case the world is coming undone. Totally isolated then except for that switch.
Normal flight - ESS bus off, master on. Electrical stuff goes weird - ESS on and Master off. Engine quits, IGN1 to middle position.
Charlie, What's your brown-out booster look like?
Getting real close! Thanks!
Andy
Posted: Mon May 09, 2022 3:54 am Post subject: Too many Circuit breakers.... |
At 02:54 PM 5/7/2022, you wrote:
| Quote: | --> AeroElectric-List message posted by: "andymeyer" <meyerkc135(at)gmail.com>
Do I read this as: Since I've got the LR3D I don't need a breaker for the alternator even though BandC calls for one? Just put a fuse where they call for breakers? |
NO! The B&C products FEATURE crowbar ov
management . . . a system that expects
to open the alternator field feeder
during an ov condition. That protection
CAN be a fuse but then you have no
convenient way to reset in case of a rare
but not zero probability of a nuisance
trip.
This is why you see a breaker in the field
supply feeder in all of the z-figures
when a B&C alternator controller -OR-
crowbar ov module is incorporated. This
is recommended whether or not you choose
to use fuse blocks.
| Quote: | | My ignitions - 2 Lightspeeds - What's the best protection for the wires running from the panel to the back seat? I still need switches to turn them on or off, might I be better off with a W31 Breaker switch and that be it, or is the complexity of the W31 a risk? Part of me would like to be able to reset it if the engine goes quiet and I'm out of other options. Though 2 dying at once seems highly improbable. |
You have pretty much answered your own
question. Review architecture and series
of events that ended up trashing a nice
LanceAir IVP a few years ago.
http://aeroelectric.com/Reference_Docs/Accidents/N811HB_Feb2008_LA-IVp/
My post of last night suggests reviewing
an accident that was probably a result
of poor electrical system architecture.
Being able to reset blown protection in flight
is WAayyy down on the list of priorities
for pilots. Electro-whizzies go belly-up
for many MORE reasons than a fault that opens
a breaker. When a breaker does open, it indicates
(1) a DESIGN problem (see youtube narrative on
P51 replica crash) or (2) something is broke (and
resetting the breaker is not going to fix it).
Judicious exercise of failure mode effects analysis
leads to failure tolerant selection of appliances
and architecture powering those appliances thus
mitigating design issues. This leaves only
a gross overload events for which a re-setable
feeder protection is of no value.
Besides, if something stops working in flight,
one is well advised to get on the ground before
trading your pilot's hat for a mechanic's hat.
| Quote: | | Radio Master (Currently a W31 breaker switch) - people seem to be moving away from avionics masters - is that really the best case these days? |
I was at Cessna circa 1965 when the avionics
master was conceived . . . for the wrong reasons.
Nonetheless, the concept flourished in virtually
all GA aircraft in spite of no demonstrable risks
to avionics and in spite of environmental qualification
testing requiring that avionics be immune to
normal and expected electrical stresses in
the ship's power generation system.
| Quote: | | Let the Garmin and Avidyne stuff suffer the brown-out during start and reboot? Or go around twisting knobs off and on? I'd like to be able to get rid of as much load during start. Normally, only things I have is LED Nav lights and the engine monitor. (Engine monitor only needs ~4 volts to run) |
Load shedding for the purposes of relieving
stress on battery during start is a thing of
yesteryear. A panel full of radios in a 1965
C172 was a significant load on a soggy
battery suffering the abuse of starter motor
adapted from farm tractors.
Today's avionics draw a small fraction of that
energy. Batteries are more robust. Starters
get the fan fired up much faster. Load shedding
for start assist is an idea that has pretty
much evaporated.
out of that stuff?"
Ceengland
Posted: Mon May 09, 2022 5:37 am Post subject: Too many Circuit breakers.... |
snipped
[quote] [quote]Let the Garmin and Avidyne stuff suffer the brown-out during start and reboot? Or go around twisting knobs off and on? I'd like to be able to get rid of as much load during start
Posted: Mon May 09, 2022 8:00 am Post subject: Too many Circuit breakers.... |
| Quote: | | Because the Avidyne IFD has dual power inputs that are diode or'd, I'll feed one side from the Avionics and the other from the Essential bus. Other items don't so I'll put two schottky diodes in to prevent backfeeding. |
Are you exploiting any of the z-figures? Two
diodes should never be needed.
It would be exceedingly useful if you would sketch
your distribution plan and share it on the
List. It's that ol' "Picture worth 10,000
words thingy".
| Quote: | | Or, what 20A schottky diode is recommended that can support my whole essential bus? Can't see where I can buy the AEC9001-1. |
Essential or endurance bus? And do you KNOW
what the total load on that bus is?
The 9001 was discontinued because it was a bad
idea. Over the years we got wrapped tightly around
the 'save energy' axle . . . and Schottky
diodes planted the seed of some poor decisions.
For the past 25 years or so, I've showcased
the bridge rectifier assembly as a ready-off-the-
shelf solution to diode isolation in our
distribution systems. Inexpensive, dozens
of sources, easy wiring (fast-ons), easy
mounting (one screw in the middle), zero
risk for shorting (no insulators required).
Down side? A few tenths of a volt greater
voltage drop. Okay, what are the OBSERVABLE
benefits for eliminating that extra drop?
ZERO
So what is the return on investment for fiddling
with that gold-plated solution to lowering
voltage drop? I suggest its on a par with
going lithium just to save weight. There are
no benefits to either (1) saving of a few tenths
of a volt -or- (2) a few pounds in an airplane.
Both are more expensive and fussier to
implement/maintain with performance improvements
difficult to measure and impossible to demonstrate.
| Quote: | One ignition will have a 3 position switch - middle position will go to a small standby
battery for power in case the world is coming undone. |
Do you not plan to maintain the ship's battery
in an airworthy condition? I.e. periodic cap-checks
to maintain design goals? If not, then what is
your game plan for maintaining a SECOND battery
Over the years, we've studied the occasional dark-n-stormy-
night narrative from one of aviation journals. A common
characteristic of those stories is that they seldom,
if ever, describe shortcomings in either selection of
hardware or preventative maintenance that would have
kept that event from occurring. They ALWAYS conjure
up a litany of advice and cautions for how to deal
with that situation should it happen AGAIN to you!
Failure tolerant design and maintenance strives to
prevent any failure from becoming a dark-n-stormy
night story over beers . . . or an obituary.
out of that stuff?"
Posted: Mon May 09, 2022 10:08 am Post subject: Too many Circuit breakers.... |
These days, with EFIS equipment, it's more about inconvenience than load shedding. Some EFIS products take 2-3 minutes to boot and self-calibrate, and I've seen them 'lock up' during engine start. If they reboot due to brownout at engine start, that 3 minutes feels like half the planned flight time.  If they lock up, then you typically have to power down the whole panel to get them to restart. |
Brown-out mitigation is indicated for sure
out of that stuff?"
Posted: Mon May 09, 2022 10:11 am Post subject: Too many Circuit breakers.... |
| Quote: | These days, with EFIS equipment, it's more about inconvenience than load shedding. Some EFIS products take 2-3 minutes to boot and self-calibrate, and I've seen them 'lock up' during engine start. If they reboot due to brownout at engine start, that 3 minutes feels like half the planned flight time.  If they lock up, then you typically have to power down the whole panel to get them to restart. |
If I were qualifying an electro-whizzy for TC
aircraft, DO160 power input tests have to demonstrate
timely fault free recovery under various
power input conditions. I would not be able to
put such devices on a TC aircraft.
out of that stuff?"
