alan.twigg775(at)gmail.co Guest
Posted: Tue Mar 22, 2022 9:11 am Post subject: What did you do with you EUROPA |
Finally got most of my sensors to talk to the new Kanardia Daqu/Digi. Great improvement from my old generation Flydat and it is in my eye-line. 30 minutes flying plus soaring up 500 ft, Winter vario also works.
Roll on Summer soaring.
Alan Twigg
Motorglider Wings G-GIWT
Kit 463.
peterz(at)zutrasoft.com Guest
Posted: Tue Mar 22, 2022 9:29 am Post subject: What did you do with you EUROPA |
awesome!
Please keep the soaring pireps coming! Inspiration for us long wing builders.
Still chasing down my intermittent resonance.
Question for folks: what typical pull values are folks seeing for their gearbox dog friction measurement? I'm near the low limit of 22ft-lbs.
Pete
On Tue., Mar. 22, 2022, 1:19 p.m. Alan Twigg, <alan.twigg775(at)gmail.com (alan.twigg775(at)gmail.com)> wrote:
| Quote: | --> Europa-List message posted by: Alan Twigg <alan.twigg775(at)gmail.com (alan.twigg775(at)gmail.com)>
Alan Twigg
Kit 463.
pa-List" rel="noreferrer noreferrer" target="_blank">http://www.matronics.com/Navigator?Europa-List
="noreferrer noreferrer" target="_blank">https://matronics.com/contribution
rparigoris
Posted: Tue Mar 22, 2022 2:15 pm Post subject: Re: What did you do with you EUROPA |
Hi Pete On our 914 circa 2005 which is new and only run at factory, I pulled the gearbox to inspect things and purged oil system and got oil pressure. Engine was at room temp with Mobil 1 10w30 oil. It also has a B&C SD20S alternator on the vacuum pad which definitely adds to friction. I measured January 284.4 inch lbs., or 17.8 foot lbs.
Maximum allowable friction is 1,328 inch lbs., or 83 foot lbs., so I was just about 22% allowable. Ron P.
Posted: Tue Mar 22, 2022 2:45 pm Post subject: What did you do with you EUROPA |
My bad I wasn't clear enough.... I was speaking of the locked-crankshaft dog-clutch friction test as per the pic of the Line maintenance manual attached.
I am very near the minimum torque spec (22-51.6ft-lbs), with a freshly serviced (by the local authorized rotax center) box.... discouraging.
I was wondering what other folks are seeing typically.... ie - near the bottom as well? Or nicely centered in the range (and (at) how many hours).
Cheers and thanks!
PeteZ
C-GNPZ
912ULS
[img]cid:ii_l12q319e0[/img]
On Tue, Mar 22, 2022 at 5:23 PM rparigoris <rparigor(at)hotmail.com (rparigor(at)hotmail.com)> wrote:
| Quote: | --> Europa-List message posted by: "rparigoris" <rparigor(at)hotmail.com (rparigor(at)hotmail.com)>
http://forums.matronics.com/viewtopic.php?p=506370#506370
="noreferrer" target="_blank">https://matronics.com/contribution
142.77 KB |
3072 Time(s) |
h&jeuropa
Posted: Thu Mar 24, 2022 5:04 am Post subject: Re: What did you do with you EUROPA |
Pete,
I looked at the last couple years of inspections and found that our 914 shows about 35 ft lbs. We measure with a cheap fish scale so accuracy is not real high but reasonable.
Jim & Heather
