Suspending the fuselage for removal of the main gear
jeffbudner
PostPosted: Thu Mar 17, 2022 10:03 am    Post subject: Suspending the fuselage for removal of the main gear Reply with quote
Hi All, I have a need to remove the main gear of my TR-1. In searching the archives, I found one thread that suggests supporting the plane at the wing roots. I've also considered strapping the fuselage and lifting with a hoist, assuming I can rent one that has a long enough arm. Are there other options that I haven't considered?
Thanks much,
Jeff Budner
KIS TR-1 # 099
craneplanes
PostPosted: Thu Mar 17, 2022 10:20 am    Post subject: Suspending the fuselage for removal of the main gear Reply with quote
[img]cid:17f99127267207cf5f01[/img]
I did the following:
- traced the airfoil shape from the wing tip on a 2x8 board
- cut out the airfoil shape
- used that as a template to cut 3 more 2x8 boards for a total of 4 (2 under each wing)
- put foam pool noodles on the boards where they’ll be in contact with the bottom of the wings
- built vertical supports out of 2x4’s
- lifted the 2x8’s with an engine hoist and lift straps and attached to the vertical supports with long screws (see photo)
- repeat for other side
-Doug Crane
KIS TR-4 N302KM
On Thu, Mar 17, 2022 at 13:04 jeffbudner <jeffbudner(at)gmail.com (jeffbudner(at)gmail.com)> wrote:
--> KIS-List message posted by: "jeffbudner" <jeffbudner(at)gmail.com (jeffbudner(at)gmail.com)>
Thanks much,
Jeff Budner
KIS TR-1 # 099
http://forums.matronics.com/viewtopic.php?p=506333#506333
List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?KIS-List
="noreferrer" target="_blank">https://matronics.com/contribution
 Filesize:  1.3 MB
 Viewed:  8834 Time(s)
jeffbudner
PostPosted: Thu Mar 17, 2022 11:06 am    Post subject: Re: Suspending the fuselage for removal of the main gear Reply with quote
Thanks Doug, for the good idea and posting a pic, that makes for a good model to follow.
Jeff Budner
KIS TR-1 # 099
