What did you do with your Europa this week 1/24 - 1/31
freddythek10(at)gmail.com
PostPosted: Mon Jan 24, 2022 5:42 pm    Post subject: What did you do with your Europa this week 1/24 - 1/31 Reply with quote
Syncing a GoPro 10 to my iPhone13…enthralled by youtube instructional videos…an amazing little camera…fabricating nonintrusive attach points (at) top of vertical fin, top & bottom of port wingtip, plus some spots within the cockpit.
peterz(at)zutrasoft.com
PostPosted: Mon Jan 24, 2022 6:42 pm    Post subject: What did you do with your Europa this week 1/24 - 1/31 Reply with quote
Sweet! Please do share all that upcoming footage! Smile
PeteZ
rogersheridan(at)mac.com
PostPosted: Tue Jan 25, 2022 7:57 am    Post subject: What did you do with your Europa this week 1/24 - 1/31 Reply with quote
Feeling brave I put on my drysuit & headed to France for a couple of days.
Took a while to de-ice before departure but the ignitech modules worked really well using battery energised ignition.
I plan to fit the Ecclestone carb heat manifold (https://ecclestonaviation.co.uk/product-category/carb-heats/?v=79cba1185463) & seek advice for best design of drip tray to use.
I have the curved Rotax drip trays & they will not fit when the carbs move aft.
Did someone cut and extend the curved drip tray?
[img]cid:DC4F7580-EF98-4CF7-8106-1EC760E85D21[/img]
 Filesize:  130.77 KB
 Viewed:  3383 Time(s)
ward.t(at)xtra.co.nz
PostPosted: Tue Jan 25, 2022 10:39 am    Post subject: What did you do with your Europa this week 1/24 - 1/31 Reply with quote
Hi Roger,Brave man in the middle of winter!
I have the Skydrive Carburettor heat manifolds fitted which look very similar.
Yes, if I remember correctly, it is a tight fit for the Rotax drip trays and I did have to get them extended to cover the carburettor bottom. Good aluminium welder did the job.
Had to alter the tray edges also to avoid exhaust pipes and through age had to repair some cracks later on.
Sent from my iPadTim Ward
12 Waiwetu Street,
Fendalton,
Christchurch, 8052
New Zealand.
021 0640221
 Filesize:  130.77 KB
 Viewed:  3378 Time(s)
