What did you do with your Europa this week, 1/17 - 1/24
h&jeuropa
PostPosted: Mon Jan 17, 2022 1:44 pm    Post subject: What did you do with your Europa this week, 1/17 - 1/24 Reply with quote
Starting thread for this week.
Jim
ward.t(at)xtra.co.nz
PostPosted: Mon Jan 17, 2022 10:23 pm    Post subject: What did you do with your Europa this week, 1/17 - 1/24 Reply with quote
Ok Jim, went for a local flight today around Banks Peninsula (Google) then over the Canterbury Plains back to Rangiora. Landed at a 600m strip to see an old friend. Hot temperatures for Canterbury so a little thermal turbulence. Cuppa at the:
[img]cid:97977B1A-F221-4DC8-8750-C58C56F07564[/img]
Club rooms, a bit of gossip, then back to hangar to secure probably my SkyEcho ADS-B unit which came adrift during some easterly sea breeze turbulence over the peninsula. Also re glued one of my DL07 door shoot bolt guides that had become detached, thanks to inspecting them yesterday.
Off for a bigger flight next week to the North Island.
Sent from my iPadTim Ward
12 Waiwetu Street,
Fendalton,
Christchurch, 8052
New Zealand.
021 0640221
On 18/01/2022, at 10:52 AM, h&amp;jeuropa <butcher43(at)att.net> wrote:
--> Europa-List message posted by: "h&amp;jeuropa" <butcher43(at)att.net>
Jim
http://forums.matronics.com/viewtopic.php?p=505709#505709
= Archive Search & Download, 7-Day Browse, Chat, FAQ,
 Filesize:  47.83 KB
 Viewed:  4487 Time(s)
erichdtrombley(at)juno.co
PostPosted: Tue Jan 18, 2022 5:49 pm    Post subject: What did you do with your Europa this week, 1/17 - 1/24 Reply with quote
Work continues on the panel upgrade. Finished the wiring harness and powered up the G5 and GPS175.
No smoke which is always a good sign. However, it appear that the G5 isn’t seeing the GAD29 (ARINC 429) as it is grayed out on the setup page. So, the G5 and GPS175 aren’t communicating.
Funny thing is, I am not getting any errors on the CAN bus. The GAD29 has a flashing green light which means it is communicating with the G5 on the CAN bus.
Any suggestions as to what the issue is or a fix are welcome.
Erich Trombley
N28ET
Classic mono 914
____________________________________________________________
Sponsored by https://www.newser.com/?utm_source=part&utm_medium=uol&utm_campaign=rss_taglines_more
Plaintiff in Landmark Lawsuit Is Running for Office
http://thirdpartyoffers.juno.com/TGL3131/61e76db710c396db539a6st03vuc1
Indonesia Chooses Name for Its New Capital
http://thirdpartyoffers.juno.com/TGL3131/61e76db72f9b66db539a6st03vuc2
Giant Swing in Polls Doesn't Bode Well for Democrats
http://thirdpartyoffers.juno.com/TGL3131/61e76db74e5b56db539a6st03vuc3
 Filesize:  546.95 KB
 Viewed:  4472 Time(s)
n7188u
PostPosted: Wed Jan 19, 2022 7:57 pm    Post subject: Re: What did you do with your Europa this week, 1/17 - 1/24 Reply with quote
Got my new engine installed and started. So far so good.
I added an MGL Vega EMS-1 with dual EGT and CHT and it has the ability to use the new electronic oil pressure so it is nice addition to my simple panel.
Finishing installing the cold air plenum now and hope to be back in the air next weekend or shortly after.
Chris
peterz(at)zutrasoft.com
PostPosted: Wed Jan 19, 2022 8:08 pm    Post subject: What did you do with your Europa this week, 1/17 - 1/24 Reply with quote
Sounds yummy! Any gps .kml log file to share? Smile
PeteZ
12 Waiwetu Street,
Fendalton,
Christchurch, 8052
New Zealand.
021 0640221
Jim
 Filesize:  47.83 KB
 Viewed:  4449 Time(s)
h&jeuropa
PostPosted: Mon Jan 24, 2022 2:16 pm    Post subject: Re: What did you do with your Europa this week, 1/17 - 1/24 Reply with quote
Went to the airport so Finn could run in the snow. Not much chance for flying!
Jim
 Filesize:  126.22 KB
 Viewed:  4414 Time(s)
