daaza22
Posted: Tue Jan 04, 2022 8:57 am Post subject: Classic Radiator set up help |
Hi Everybody....
I am at the firewall forward stage of my Europa classic build , and its going ok.
But could do with a little help with the radiator hose placement . If anybody as photos of the routing of the hoses I would be grateful . I think I see how it goes but a little reassurance would be nice .
Cheers Darren
stranfaer(at)btinternet.c Guest
Posted: Tue Jan 04, 2022 10:16 am Post subject: Classic Radiator set up help |
p{margin:0}
few pics
152.04 KB |
9549 Time(s) |
154.66 KB |
9549 Time(s) |
131.47 KB |
9549 Time(s) |
daaza22
Posted: Tue Jan 04, 2022 10:35 am Post subject: Re: Classic Radiator set up help |
Hi stranfaer ?
thanks for the photos ,show me what I wanted to know .
Cheers Darren
Area-51
Posted: Wed Jan 05, 2022 4:27 am Post subject: Re: Classic Radiator set up help |
The lower hoses interconnect left and right cores; it runs under the front gearbox bearing flange. Use high quality hose clamps and retention them when everything is at operating temperature and the motor is switched off.
The cores will support themselves with the lower cowl removed; the oil cooler may need zip ties until the cowl is refitted; i’ve found supporting the lower cowl on an upturned chair while refitting the oil cooler to it to be very helpful.
daaza22
Posted: Wed Jan 05, 2022 8:28 am Post subject: Re: Classic Radiator set up help |
thats sounds like good advise with the chair.
cheers
tennant
Posted: Thu Jan 06, 2022 11:48 pm Post subject: Re: Classic Radiator set up help |
Hi Darran,
Depending on how old your motor is you may wish to consider mounting the right radiator as far outboard as you can as replacement fuel pumps are longer than the older model and it will have to be replaced at some time.
_________________ Barry Tennant
D-EHBT
At EDLM - Germany |
daaza22
Posted: Fri Jan 07, 2022 1:58 am Post subject: Re: Classic Radiator set up help |
Thanks Tennent
I think my engine as the longer fuel pump. But thanks for the pointing it out to me , I am always grateful for advise . I will add a photo later. I did find it a bit of a struggle fitting the Starboard radiator due fuel pump and the exhaust bend , which does seem very close ..
anyway thanks for now
Area-51
Posted: Fri Jan 07, 2022 3:53 am Post subject: Re: Classic Radiator set up help |
The earlier model fuel pumps have pressed together bodies; later are screwed together and have an oil drain on the underside of the pushrod body; attached picture is of later model fitted. The pictures above show the earlier style pump.
2.67 MB |
9454 Time(s) |
peterz(at)zutrasoft.com Guest
Posted: Fri Jan 07, 2022 4:46 am Post subject: Classic Radiator set up help |
Fwiw, updating my fuel pump required getting the rad intake welded to modify its angle to clear.
PeteZ
| Quote: | On Jan 7, 2022, at 5:07 AM, daaza22 <royledarren(at)gmail.com> wrote:
Thanks Tennent
http://forums.matronics.com/viewtopic.php?p=505610#505610
budyerly@msn.com
Posted: Fri Jan 07, 2022 9:09 am Post subject: Classic Radiator set up help |
Same for me Pete on 96EG. No way around it for already built aircraft.
It is a game of fractions of an inch.
Bud Yerly
daaza22
Posted: Fri Jan 07, 2022 10:21 am Post subject: Re: Classic Radiator set up help |
Here a couple of photos . is the gap from the exhaust ok?
2.4 MB |
9429 Time(s) |
2.4 MB |
9429 Time(s) |
daaza22
Posted: Fri Jan 07, 2022 10:22 am Post subject: Re: Classic Radiator set up help |
2.88 MB |
9428 Time(s) |
2.4 MB |
9428 Time(s) |
daaza22
Posted: Fri Jan 07, 2022 10:25 am Post subject: Re: Classic Radiator set up help |
sorry about the mess up with adding the photos
Posted: Fri Jan 07, 2022 10:52 am Post subject: Classic Radiator set up help |
wrt to the pics, all I can say is i have more clearance in my classic.
also, keep in mind that the engine will move forward slightly with a loaded prop.
cheers,
PeteZ
On Fri, Jan 7, 2022 at 1:30 PM daaza22 <royledarren(at)gmail.com (royledarren(at)gmail.com)> wrote:
