Naca Duct Size
daaza22
PostPosted: Wed Dec 15, 2021 10:54 am    Post subject: Naca Duct Size Reply with quote
Hi everybody..
I am at the stage of fitting the firewall forward parts on my "Classic" build.
My question is what size should the Naca Duct for the cold air plenum be ?
Cheers Darren
ward.t(at)xtra.co.nz
PostPosted: Wed Dec 15, 2021 12:32 pm    Post subject: Naca Duct Size Reply with quote
Hi Darren,Measurements not given in the Mod 43 so I made my Naca Duct dimensions approximately 100mm x 25mm. I also centred it on the top cowl, looks better and not in the way of the coolant cap. See photo.
[img]cid:E3497D2F-6BD3-4801-B9E5-7FA35ACD8601-L0-001[/img]
Sent from my iPadTim Ward
12 Waiwetu Street,
Fendalton,
Christchurch, 8052
New Zealand.
021 0640221
On 16/12/2021, at 8:02 AM, daaza22 <royledarren(at)gmail.com> wrote:
--> Europa-List message posted by: "daaza22" <royledarren(at)gmail.com>
Hi everybody..
Cheers Darren
http://forums.matronics.com/viewtopic.php?p=505269#505269
_-= Same great content also available via the Web Forums!
_===============================================
 Filesize:  1.88 MB
 Viewed:  4282 Time(s)
daaza22
PostPosted: Wed Dec 15, 2021 1:31 pm    Post subject: Re: Naca Duct Size Reply with quote
Thanks for the reply and photo .
sorry to be a pain but could you confirm
25mm for the narrow end
100mm for widest part
100mm long . ?
Darren
PostPosted: Wed Dec 15, 2021 1:47 pm    Post subject: Naca Duct Size Reply with quote
Darren,That is the opening into the plenum chamber approximately. If you are not in a hurry I can measure it exactly next time at the hanger. The length is really up to you, however a gentle entrance to direct the airflow would be better. Not too much pressure build up. See photo.
12 Waiwetu Street,
Fendalton,
Christchurch, 8052
New Zealand.
021 0640221
100mm long . ?
Darren
http://forums.matronics.com/viewtopic.php?p=505272#505272
PostPosted: Wed Dec 15, 2021 9:58 pm    Post subject: Naca Duct Size Reply with quote
Hi Darren,Have visited the hangar to take some measurements of the Naca Duct.
The opening is 120mm x 34mm.
The length of the duct is 230mm.
Duct width starts at 20mm to 120mm.
Centred from the Spinner.
Hope that helps, good luck.
12 Waiwetu Street,
Fendalton,
Christchurch, 8052
New Zealand.
021 0640221
12 Waiwetu Street,
Fendalton,
Christchurch, 8052
New Zealand.
021 0640221
100mm long . ?
Darren
==========================bsp; - The Europa-List Email ====================================================; - MATRONICS WEB FORUMS -
John Wighton
PostPosted: Thu Dec 16, 2021 12:44 am    Post subject: Re: Naca Duct Size Reply with quote
I have a 912ULS cowling (XS version) NACA duct mould tool if anyone wishes to use it. UK based.
Also a complete set of untouched cowlings (XS), with intake moulding tool.
Some firewall forward parts as well (lower air scoop alloy parts, seals, etc).
And an oil cooler, unused (nib as they say).
john(at)wighton.net
John Wighton
Europa XS trigear G-IPOD
daaza22
PostPosted: Thu Dec 16, 2021 10:52 am    Post subject: Re: Naca Duct Size Reply with quote
thanks all for your help .
I will mark the Naca duct out tomorrow with the sizes suggested .
Also John ,the tool you mention , is that a mould ?
Darren
