Compressor troubleshooting before replacing
PostPosted: Sun Nov 28, 2021 5:11 pm    Post subject: Compressor troubleshooting before replacing Reply with quote
The compressor stopped building up pressure last two flights.
Engine has 600+ hours - fairly certain it is the original compressor.
There are no leaks in the system while the airplane is parked.
There is a manual lever bypass (Cessna throttle cable style) which will audibly discharge when in bypass mode but will not charge in the "charge" mode as it used to.
Anything easy I can check before replacing it?
Clouddog
PostPosted: Sun Nov 28, 2021 5:25 pm    Post subject: Compressor troubleshooting before replacing Reply with quote
Try cleaning the valve housed in the banjo fitting on the compressor.
On Sun, Nov 28, 2021, 19:15 1906 <zmadwolf(at)gmail.com (zmadwolf(at)gmail.com)> wrote:
--> Yak-List message posted by: "1906" <zmadwolf(at)gmail.com (zmadwolf(at)gmail.com)>
http://forums.matronics.com/viewtopic.php?p=504970#504970
List" rel="noreferrer noreferrer" target="_blank">http://www.matronics.com/Navigator?Yak-List
="noreferrer noreferrer" target="_blank">https://matronics.com/contribution
dsavarese0812(at)bellsout
PostPosted: Mon Nov 29, 2021 4:08 am    Post subject: Compressor troubleshooting before replacing Reply with quote
It could very well be the “dischargeâ€� position on snot bottle arm that is no longer fully closing when you place the cable knob in the “chargeâ€� position. Happens frequently BTW. To test this, tape a finger from a latex or nitrile glove over the discharge tube. Make certain the cable is pushed or pulled to the fully closed or “chargeâ€� position and start the engine.
If the snot bottle is fully closing, nothing will happen to the glove. If the glove blows up and pops quickly, the compressor is working and the cable is not fully closing the snot bottle discharge arm, which prevents the air system from recharging.
Assuming the glove finger does not pop, open the snot bottle drain with the cable ie: discharge position. With the engine still running, If the glove finger does not blow up and pop, the problem could be either the compressor output check valve; the compressor itself or the shear coupling between the accessory drive and the compressor being sheared, assuming the engine is an M14. If it’s Housai engine, it has no shear coupling.
Any questions, please ask.
Dennis
PostPosted: Mon Nov 29, 2021 4:10 am    Post subject: Compressor troubleshooting before replacing Reply with quote
If you do clean the valve as Greg suggested, be sure to use all new crush washers when reinstalling. Dennis
On Nov 29, 2021, at 7:08 AM, Anthony Savarese <dsavarese0812(at)bellsouth.net> wrote:
Dennis
Stratyaks
PostPosted: Mon Nov 29, 2021 5:15 am    Post subject: Re: Compressor troubleshooting before replacing Reply with quote
Our Yak-52 has a fine gauze strainer off the four-way union where the compressor output goes into the aircraft. It is opposite the pop-off valve in the main line to the air bottles. I took ours apart for the first time (maybe ever!) and it was full of nastiness.
 Filesize:  331.74 KB
 Viewed:  10801 Time(s)
rocknpilot(at)hotmail.com
PostPosted: Mon Nov 29, 2021 5:37 am    Post subject: Compressor troubleshooting before replacing Reply with quote
Dennis - Question on this topic:
I suspect my bottle is also not fully closing. I am noticing periods of flight where the air does not recharge, then after cycling the snot valve handle, air builds up again - albeit it slowly. Yet when I land and shut down, there is always a healthy audible release when I open the valve. Is it possible for the bottle to leak slightly, but still give a good "hiss' at shutdown? Or is it an "all-or-nothing" kind of situation?
Also, my air gauge rarely reaches pop-off max pressure. Never on short flights and not as often as it used to on 30+ minute flights.
And...it may be the "everything is going wrong" state of mind paranoia, but starting seems to deplete more air supply than before. Even when I crank up with max air, I end up taxi'ing out with a half tank after only a single starting attempt. When a group of us taxied out at OSH, I was borderline-abort due to alarmingly-low air with a long way to taxi / turn / brake / stop / runup.
And as long as I have your attention, I have recently developed an audible air loss when I use the brake-lock at start-up. And by "audible," I don't mean a hiss, I mean a leak that actually has tone...like a lengthy "sigh." (Seems to emanate from behind me in the rear cockpit. Is that the equalizing valve in the floor of the rear cockpit? I did a rebuild on it about 8-9 years ago.)
Thank You for ALL, Sir!
Rico Jaeger
715.529.7426
1992 Yakovlev Yak 52    ^/---//-X
N21YK                                 //
Hangar #21 / AUW
1941 Ryan PT-22 "Recruit"   ^/---//-X
N (TBD)                                      //
Hangar #35 / AUW
From: owner-yak-list-server(at)matronics.com <owner-yak-list-server(at)matronics.com> on behalf of Anthony Savarese <dsavarese0812(at)bellsouth.net>
Sent: Monday, November 29, 2021 6:09 AM
To: yak-list(at)matronics.com <yak-list(at)matronics.com>
Subject: Re: Yak-List: Compressor troubleshooting before replacing
Dennis
jlpartington(at)reagan.co
PostPosted: Mon Nov 29, 2021 6:29 am    Post subject: Compressor troubleshooting before replacing Reply with quote
There are many one way valves in the CJ system. Doug had rebuild kits and that was time well spent for me.
Also, while flying I turn off the main air valve and see how fast the pump runs up to pop off pressure. If it is not fast, there is a leak
Pooh
PostPosted: Mon Nov 29, 2021 6:39 am    Post subject: Compressor troubleshooting before replacing Reply with quote
That’s an excellent tip!
(As long as we remember to open it again in the pattern!)
Thank you!
Rico Jaeger
915 S 11th Ave
Wausau, WI 54401
715. 529.7426
Yak 52 / N21YK. ^/---//-X
Hangar 21 / AUW. //
Ryan PT-22. ^/---//-X
Hangar 35 / AUW. //
EAA #345804
Warbird #13705
From: owner-yak-list-server(at)matronics.com <owner-yak-list-server(at)matronics.com> on behalf of jlpartington(at)reagan.com <jlpartington(at)reagan.com>
Sent: Monday, November 29, 2021 8:29 AM
Subject: RE: Re: Compressor troubleshooting before replacing
Pooh
rickkelleyfly(at)gmail.co
PostPosted: Mon Nov 29, 2021 7:10 am    Post subject: Compressor troubleshooting before replacing Reply with quote
If it did any kind of backfiring while starting I would bet you shared the Cupler
On Nov 29, 2021, at 6:14 AM, Anthony Savarese <dsavarese0812(at)bellsouth.net> wrote:
It could very well be the “discharge� position on snot bottle arm that is no longer fully closing when you place the cable knob in the “charge� position. Happens frequently BTW. To test this, tape a finger from a latex or nitrile glove over the discharge tube. Make certain the cable is pushed or pulled to the fully closed or “charge� position and start the engine.
Dennis
PostPosted: Mon Nov 29, 2021 7:14 am    Post subject: Compressor troubleshooting before replacing Reply with quote
True, but self correcting IF your are paying attention
PostPosted: Mon Nov 29, 2021 5:37 pm    Post subject: Compressor troubleshooting before replacing Reply with quote
The "filter" you are speaking of is totally junk.  It's useless. Might
as well not even have one like that on the airplane.
A. Dennis Savarese
334-546-8182
www.yak-52.comTha
http://forums.matronics.com/viewtopic.php?p=504976#504976
http://forums.matronics.com//files/air_system_gauze_151.jpg
PostPosted: Mon Nov 29, 2021 5:38 pm    Post subject: Compressor troubleshooting before replacing Reply with quote
Rico,
When was the last time you removed the snot bottle from the firewall and
cleaned and flushed it completely with avgas out of all three orifices?
You'll be amazed how much junk you'll get out of it.  See if that
doesn't help.
A. Dennis Savarese
334-546-8182
www.yak-52.com
situation?
Rico Jaeger
715.529.7426
N21YK                                 //
Hangar #21 / AUW
N (TBD)                                      //
Hangar #35 / AUW
*Sent:* Monday, November 29, 2021 6:09 AM
*To:* yak-list(at)matronics.com <yak-list(at)matronics.com>
*Subject:* Re: Compressor troubleshooting before replacing
Dennis
> Dennis
> Sent from my iPhone
>> compressor.
>> FORUMS -
>> WIKI -
>> b Site -
PostPosted: Mon Nov 29, 2021 5:39 pm    Post subject: Compressor troubleshooting before replacing Reply with quote
You're right.  But testing with the glove finger will give you a pretty
good idea of whether the compressor is pumping air or not.
A. Dennis Savarese
334-546-8182
www.yak-52.com
the Cupler
> Dennis
> Sent from my iPhone
>> compressor.
>> FORUMS -
>> WIKI -
>> b Site -
PostPosted: Mon Nov 29, 2021 7:04 pm    Post subject: Compressor troubleshooting before replacing Reply with quote
Will do! Thank you Dr Dennis!
Rico Jaeger
915 S 11th Ave
Wausau, WI 54401
715. 529.7426
Hangar 21 / AUW. //
Hangar 35 / AUW. //
EAA #345804
Warbird #13705
From: owner-yak-list-server(at)matronics.com <owner-yak-list-server(at)matronics.com> on behalf of A. Dennis Savarese <dsavarese0812(at)bellsouth.net>
Sent: Monday, November 29, 2021 7:38 PM
--> Yak-List message posted by: "A. Dennis Savarese" <dsavarese0812(at)bellsouth.net>
Rico,
doesn't help.
A. Dennis Savarese
334-546-8182
www.yak-52.com
> situation?
> Rico Jaeger
> 715.529.7426
> N21YK                                 //
> Hangar #21 / AUW
> N (TBD)                                      //
> Hangar #35 / AUW
> *From:* owner-yak-list-server(at)matronics.com
> *Subject:* Re: Yak-List: Compressor troubleshooting before replacing
> Dennis
> Sent from my iPhone
>> Dennis
>> Sent from my iPhone
>>>     --> Yak-List message posted by: "1906" <zmadwolf(at)gmail.com>
>>>     compressor.
>>>     Read this topic online here:
>>>     FORUMS -
>>>     WIKI -
>>>     b Site -
Stratyaks
PostPosted: Tue Nov 30, 2021 1:52 am    Post subject: Re: Compressor troubleshooting before replacing Reply with quote
A. Dennis Savarese
334-546-8182
www.yak-52.comTha
I agree Dennis but I didn't call it a filter, that is way overstating its effectiveness. Nor did I suggest it was any good at its job, I merely meant it is a potential blockage point - as I found for myself.
PostPosted: Tue Nov 30, 2021 5:34 am    Post subject: Compressor troubleshooting before replacing Reply with quote
I know you didn't call it a filter. I did, in quotes. Being sarcastic. That so called filter should have been placed at the external air fill port to trap junk that might be injected into the air system before it goes to the emergency and main air system.
In it's present position, just below the pressure relief valve, junk that is forced into the air system when filling from the external air fill port has to pass through 2 check valves, which is ridiculous because many times that junk causes one or both of those two check valves to leak. If the junk were captured before it ever got to the check valves, there would be less check valve failures.
The type of air filter that should be installed below the pressure relief valve is one that has screens, felt filters and desiccant to remove moisture from the system. Just like the one Doug Sapp sold for the CJ's and was adapted to the Yak 52's by placing it in same position as the original "filter". Now THAT was a filter!
Dennis
On Tuesday, November 30, 2021, 04:55:00 AM EST, Stratyaks <john.bailey(at)russianradials.com> wrote:
--> Yak-List message posted by: "Stratyaks" <john.bailey(at)russianradials.com (john.bailey(at)russianradials.com)>
A. Dennis Savarese
www.yak-52.comTha
http://forums.matronics.com/viewtopic.php?p=505064#505064
sp; - The Yak-List Email Forum -
http://forums.matronbsp; - NEW MATRONICS LIST WIKI -
; -Matt Draltps://matronics.com/contribution" rel="nofollow" target="_blank">https:======
