Z 16 Charging question
wdaniell.longport(at)gmai
PostPosted: Sun Oct 17, 2021 3:56 pm    Post subject: Z 16 Charging question Reply with quote
I have a Rotax 912 with a Z16 and Dynon Skyview
The ammeter sometimes ( defined as once every 25 flights)  goes off the chart to 60a. I get the red X over the instrument.  Then it comes back and goes down to normal and sits there at whatever loads I have on the system.  I have always assumed that this was a Dynon bug.
My Dynon has a shunt installed between the generator and the bus which measures the entire load normally rock steady at 7A or 8A when using the autopilot.  I also have an independant  hall effect sensor measuring amps on the fat wire to the battery.
Today I noticed on climb out that the hall effect sensor was showing battery charge oscillating from +1.7A to +2.5A - normally it is steady.  I switched off the alternator and the hall effect sensor showed steady -7A in agreement with the load shown on my dynon (7A).  (I turned around and landed immediately.)   Voltage is steady.
I checked the alternator as per https://pointsforpilots.blogspot.com/2012/12/testing-rotax-912914-generator-and.html.   All within limits.
So my next steps are to change the regulator, which involves taking out the crowbar because the BandC had one internally,  (I had already bought a BandC voltage regulator some time ago) and the battery which is pretty much due for a change.
Any other thoughts?
William Daniell
LONGPORT
+1 786 878 0246
user9253
PostPosted: Mon Oct 18, 2021 3:32 am    Post subject: Re: Z 16 Charging question Reply with quote
There is no way that a faulty regulator can make a Rotax dynamo put out 60 amps.
It is only capable of 20 amps or so. There must be a bad connection somewhere.
Joe Gores
PostPosted: Mon Oct 18, 2021 4:25 am    Post subject: Z 16 Charging question Reply with quote
JoeThanks.  Yes ...the first time it happened it caused a bit of worry until i realised i had no smoke in the cockpit...and everything was working normally.   And once id calmed down i came to the same conclusion.  I have to fault find that.
But what do you think of the fluctuating battery charging level?   Is that normal?   Or might it be the instrument?
Will
William Daniell
+1 786 878 0246
On Mon, Oct 18, 2021, 07:36 user9253 <fransew(at)gmail.com (fransew(at)gmail.com)> wrote:
--> AeroElectric-List message posted by: "user9253" <fransew(at)gmail.com (fransew(at)gmail.com)>
Joe Gores
http://forums.matronics.com/viewtopic.php?p=503553#503553
Electric-List" rel="noreferrer noreferrer" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
FORUMS -
eferrer noreferrer" target="_blank">http://forums.matronics.com
WIKI -
errer noreferrer" target="_blank">http://wiki.matronics.com
b Site -
          -Matt Dralle, List Admin.
rel="noreferrer noreferrer" target="_blank">http://www.matronics.com/contribution
user9253
PostPosted: Mon Oct 18, 2021 7:45 am    Post subject: Re: Z 16 Charging question Reply with quote
It is unlikely that the Skyview is at fault. The vast majority of electrical problems are
caused by bad connections. Take every related connection apart and reassemble.
Joe Gores
PostPosted: Mon Oct 18, 2021 8:15 am    Post subject: Z 16 Charging question Reply with quote
....sadly I think you're right.
William Daniell
LONGPORT
+1 786 878 0246
On Mon, Oct 18, 2021 at 11:50 AM user9253 <fransew(at)gmail.com (fransew(at)gmail.com)> wrote:
Joe Gores
http://forums.matronics.com/viewtopic.php?p=503558#503558
FORUMS -
WIKI -
b Site -
PostPosted: Mon Nov 01, 2021 6:30 am    Post subject: Z 16 Charging question Reply with quote
Update:
I installed a bandc AVC 1 voltage regulator.  This has integral overvoltage protection and an internal relay simplifying the installation.  I changed the voltage pick up location from the shunt to the bus.
Voltage, bus amps and battery charging amps are stable.
Interestingly the headset howl which I suppressed by turning down mic gain has also gone away and I can turn the mic gain up to 50%.
William Daniell
LONGPORT
+1 786 878 0246
On Sun, Oct 17, 2021 at 7:55 PM William Daniell <wdaniell.longport(at)gmail.com (wdaniell.longport(at)gmail.com)> wrote:
Any other thoughts?
William Daniell
LONGPORT
+1 786 878 0246
