PFolbrecht(at)starkinvest Guest
Posted: Fri Jul 28, 2006 5:54 am Post subject: Elevator TE Problem |
I sent this to Van’s yesterday and then realized that they, along with everyone else in the world and everyone else’s brother, is up at OSH this week.
Hello,
9A builder #1176 here. Starting TE on right elevator. The stiffeners prevent the TE from going in all the way – it sticks out about 1/16” past the skins. Options:
<![if !supportLists]>1) <![endif]>Trim the stiffeners. Since they’re (obviously) installed, I can’t see how I can realistically do this without damaging the skin.
<![if !supportLists]>2) <![endif]>Install the TE wedge sticking out 1/16” and leave it like that. There would be enough room from the rivets to the LE of the wedge for structural soundness.
<![if !supportLists]>3) <![endif]>Install the TE wedge as-is and file/trim it afterwards.
None of these options is terribly inviting. Which is the best?
jsflyrv(at)verizon.net Guest
Posted: Fri Jul 28, 2006 6:46 am Post subject: Elevator TE Problem |
Folbrecht, Paul wrote:
| Quote: | I sent this to Van’s yesterday and then realized that they, along with
this week.
Hello,
1) Trim the stiffeners. Since they’re (obviously) installed, I can’t
2) Install the TE wedge sticking out 1/16” and leave it like that.
3) Install the TE wedge as-is and file/trim it afterwards.
I don't know how close to the end of the stiffeners the rivets are, but
in some cases you can slip a thin strip
of alum. between the stiffener and the skin to protect the skin and use
a die grinder or dremel tool to cut the
ends of the stiffeners off.
Jerry
dennis.glaeser(at)eds.com Guest
Posted: Fri Jul 28, 2006 6:55 am Post subject: Elevator TE Problem |
I had a similar problem on my 7A rudder, only at the other end
(stiffeners interfered with the spar). I slipped a thin piece of
aluminum between the skin and the stiffener and used my dremel tool with
a cutoff wheel - very carefully!!
A fourth option is to trim the TE wedge locally to clear the stiffeners
- mark the locations and 'deburr' away the TE wedge with your
scotchbright wheel to clear the stiffeners.
Dennis Glaeser
7A - Finishing Kit
prevent the TE from going in all the way - it sticks out about 1/16"
1) Trim the stiffeners. Since they're (obviously) installed, I can't see
2) Install the TE wedge sticking out 1/16" and leave it like that. There
evmeg(at)snowcrest.net Guest
Posted: Fri Jul 28, 2006 7:23 am Post subject: Elevator TE Problem |
its been a while since I did mine but I am pretty sure they all stick out a bit....
Evan
Posted: Mon Jul 31, 2006 6:19 am Post subject: Elevator TE Problem |
Jerry & Dennis,
I did make it to OSH on Saturday (I'm in Milwaukee and would have gone
the whole week if I could have), and talked to Van's, who recommended
leaving it as is. I looked at the 9A demonstrator... and sure enuf the
TE wedge on the elevators protrudes 1/16" or so just like mine.
So that's what I did.
Time: 07:46:31 AM PST US
| Quote: | I sent this to Vans yesterday and then realized that they, along with
everyone else in the world and everyone elses brother, is up at OSH
this week.
Hello,
prevent the TE from going in all the way it sticks out about 1/16
1) Trim the stiffeners. Since theyre (obviously) installed, I cant see
| Quote: | how I can realistically do this without damaging the skin.
2) Install the TE wedge sticking out 1/16 and leave it like that.
in some cases you can slip a thin strip of alum. between the stiffener
and the skin to protect the skin and use a die grinder or dremel tool to
cut the ends of the stiffeners off.
Jerry
________________________________ Message 9
_____________________________________
Time: 07:55:22 AM PST US
--> <dennis.glaeser(at)eds.com>
Dennis Glaeser
7A - Finishing Kit
