Europa tail wheel tow bar
rehn(at)rockisland.com
PostPosted: Sat Jul 10, 2021 8:03 pm    Post subject: Europa tail wheel tow bar Reply with quote
Looking for tow bars that work well for Europa.
Thanks!
Jerry
ward.t(at)xtra.co.nz
PostPosted: Sat Jul 10, 2021 10:29 pm    Post subject: Europa tail wheel tow bar Reply with quote
Jerry,
I had a design I made, built for me and a number of Europa builders here. Stainless steel.
Simply attaches to the tail wheel axle bolt and closed up by a plastic tie.
Works very well, easy to carry although I don’t normally take it with me as manoeuvring the aircraft on the ground is relatively straightforward
davidjoyce(at)doctors.org
PostPosted: Sun Jul 11, 2021 1:43 am    Post subject: Europa tail wheel tow bar Reply with quote
Jerry, The clear best answer for me is one made of rope - light weight, drop it in the back without risk of damaging fibreglass, no great matter if you forget to take it off when departing. Make it yourself from thickish rope (about 15mm diameter - just right to fill gaps between big washers on tailwheel axel and not to cut into hands when pulling on it), if you can spice, if not ask a sailing friend. Two small loops with splices to fit on wheel; cross over splice about 8 ins back, about 3 or 4 ft loop to get hold of and pull on, all splices covered with heat shrink. Will send a photo when next visiting plane. David Joyce, GXSDJ
On 2021-07-11 05:03, Jerry Rehn wrote:
--> Europa-List message posted by: Jerry Rehn <rehn(at)rockisland.com (rehn(at)rockisland.com)>Looking for tow bars that work well for Europa.Topa-List" target="_blank" rel="noopener noreferrer">http://www.matronic;--> http://w========================
budyerly@msn.com
PostPosted: Sun Jul 11, 2021 6:00 am    Post subject: Europa tail wheel tow bar Reply with quote
Jerry,
I find the Aircraft Spruce sold Ground Support Towbar for Scott Tailwheels to be fine for around the hangar push pull ops.
Otherwise, the lightweight ski rope with a piece of hose for a handgrip is great for XC use.
Best Regards,
Bud Yerly
PostPosted: Sun Jul 11, 2021 2:15 pm    Post subject: Europa tail wheel tow bar Reply with quote
Thanks for all the great info!!
Jerry
[quote] On Jul 11, 2021, at 7:05 AM, Bud Yerly <budyerly(at)msn.com> wrote:
Jerry,
Best Regards,
Bud Yerly
alan.twigg775(at)gmail.co
PostPosted: Mon Jul 12, 2021 3:03 am    Post subject: Europa tail wheel tow bar Reply with quote
This is what I use.
Alan Twigg G-GIWT
Thanks!
Jerry
 Filesize:  93.12 KB
 Viewed:  4043 Time(s)
