frank3 Guest
Posted: Mon Jul 05, 2021 12:49 pm Post subject: Melted battery contractor ground wire |
I flipped the battery switch that activates the contractor this AM and melted the ground wire.
I'm deep in the process of wiring my RV7 (most of the wiring completed), using a legacy schematic with EBUS architecture. Wiring to the battery contractor is standard--wire from contactor to switch (2-10) with ground to field of tabs at firewall.
I have used a lawn tractor battery numerous times to energize the system when testing components as they're installed. All has worked well until this AM.
I'd appreciate input to help me resolve what the issue might be.
Thanks much in advance.
frank3 Guest
Posted: Mon Jul 05, 2021 1:36 pm Post subject: Re: Melted battery contractor ground wire |
It might be pertinent to mention I did not hear the typical "clank" from the battery contractor when I flipped the switch.
user9253
Joined: 28 Mar 2008 Posts: 1940 Location: Riley TWP Michigan
Posted: Mon Jul 05, 2021 3:21 pm Post subject: Re: Melted battery contractor ground wire |
Have you made any wiring changes to the battery contactor recently?
It seems that the melted wire is connected to positive someplace.
One possibility is a shorted contactor coil, but unlikely.
_________________ Joe Gores |
frank3 Guest
Posted: Tue Jul 06, 2021 4:50 am Post subject: Re: Melted battery contractor ground wire |
I haven't made any changes to the battery contactor recently.
user9253
Posted: Tue Jul 06, 2021 6:17 am Post subject: Re: Melted battery contractor ground wire |
Remove the wire from the small terminal of the battery contactor.
Measure the resistance between that small contactor terminal and the large contactor terminal that connects to battery positive.
I expect it to be about 20 ohms. If less than 5 ohms, the contactor coil is shorted.
frank3 Guest
Posted: Tue Jul 06, 2021 9:39 am Post subject: Re: Melted battery contractor ground wire |
Thanks Joe. Did that this AM. No resistance at all. Shorted contactor as you suggest.
The burnt ground wire was in a loose bundle--run together but haven't tied them together. I assume there's possible damage to other wires in the bundle? If there's no damage to the insulation of the other wires then they're good to go?
frank3 Guest
Posted: Tue Jul 06, 2021 10:20 am Post subject: Re: Melted battery contractor ground wire |
This experience makes me wonder why no circuit protection for the contactor activator switch circuit in any of the architectures.
Maybe it's because a short in the contactor is unlikely, as Joe says, but isn't that the assumption behind all circuits that do have circuit protection built in?
jluckey(at)pacbell.net Guest
Posted: Tue Jul 06, 2021 12:16 pm Post subject: Melted battery contractor ground wire |
Hello Frank,
You are asking good questions.
What typically happens is the coil burns up and causes an open circuit, but in your case it appears to have failed closed.
It will be interesting to conduct a post-mortem on it to determine how it created such a hard fault.
Questions:
1. Can you post a picture of the master solenoid/contactor?
2. What size wire runs from the solenoid to the master switch?
-Jeff
On Tuesday, July 6, 2021, 11:27:49 AM PDT, frank3 <frank3phyl(at)comcast.net> wrote:
--> AeroElectric-List message posted by: "frank3" <frank3phyl(at)comcast.net (frank3phyl(at)comcast.net)>
Frank McDonald
Kitfox S7 - sold
RV7 in progress
Acworth, GA
http://forums.matronics.com/viewtopic.php?p=502723#502723
http://www.m=====================
http://wiki.matron========================
frank3 Guest
Posted: Tue Jul 06, 2021 4:25 pm Post subject: Re: Melted battery contractor ground wire |
Jeff
What pic would be most revealing for you? Installed on the firewall? Removed on the bench? Other?
Posted: Tue Jul 06, 2021 4:49 pm Post subject: Melted battery contractor ground wire |
I'd like to see it as installed, for starters.
-Jeff
On Tuesday, July 6, 2021, 5:32:06 PM PDT, frank3 <frank3phyl(at)comcast.net> wrote:
Jeff
Frank McDonald
Kitfox S7 - sold
RV7 in progress
Acworth, GA
http://forums.matronics.com/viewtopic.php?p=502729#502729
http://forums.matronics.comp; - NEW MATRONICS LIST WIKI -
http://www.matronics.com/contribution====================
DougW
Posted: Tue Jul 06, 2021 6:09 pm Post subject: Melted battery contractor ground wire |
Frank,
The only way you are going to melt that wire is likely with a direct short
between positive and negative battery voltages. Most likely candidates for
that occurrence is a mis-wired switch or contactor.
I would disconnect the wire from the switch where it attaches to the 'field
of tabs' and rewire from the switch to the contactor. Do a continuity test
from the contactor terminal to the now disconnected connector at the field
of tabs. In the switch 'ON' position, you should have very little
resistance, and high resistance in the 'OFF' position. If both of those are
TRUE, then that wiring should be OK. If they are not both TRUE, then you
need to examine the wiring to the switch more closely.
Another possibility is that you have the positive and negative terminals of
the contactor switched with your wiring arrangement. That is the area I
would examine next after all the foregoing. If neither of these is the
problem, could it be a bad contactor?
Doug Windhorn
nuckollsr
Joined: 24 Mar 2009 Posts: 95 Location: Medicine Lodge, KS
Posted: Wed Jul 07, 2021 5:52 am Post subject: Re: Melted battery contractor ground wire |
At 09:08 PM 7/6/2021, you wrote:
--> AeroElectric-List message posted by: "n1dw" <n1deltawhiskey>
Frank,
between positive and negative battery voltages. Most likely candidates forthat occurrence is a mis-wired switch or contactor.
Question: did this contactor installation EVER work?
Q: What is the measured resistance of the contactor's
coil? . . . WITH ANY SPIKE SUPPRESSION DIODE
REMOVED.
Q: Is there ANY continuity between the any terminal
of contactor and it's case?
Q: What kind of contactor is this? 3-terminal, 4-terminal?
Q: Is there a spike suppression diode installed across
the contactor's coil terminals. Has this been checked
for proper polarity? (Banded end needs to fact the battery,
other end faces master switch). If this diode is BACKWARDS
or SHORTED it will cause failure of the contactor-to-master
switch wire. If a backwards diode is found to be root
cause of the burned wire, then replace BOTH diode
and wire. The current impressed on the diode during
wire-burning will have exceeded its ratings and
it's probably toast too.
frank3 Guest
Posted: Wed Jul 07, 2021 3:09 pm Post subject: Re: Melted battery contractor ground wire |
Folks, I posted some erroneous info. When I measured the resistance between the small contactor terminal and the larger terminal connecting to the battery (+) I did so with the diode in place. Hence, the "no resistance". (I'm still learning or at least trying to)
Today I removed the contactor, removed the diode from the contactor, and checked for resistance, again. This time I got 0.016 ohms. So, according to Joe's criteria, it's still a bad contactor. Guess we ended up at the same place using a different path?
Just for kicks, I did a bench test. I connected a 22 awg wire to the small terminal, terminating at the the master switch (2-10). Using a similar wire I connected to the switch terminating at neg side of contactor. I applied jumper cables to the large contactor terminals. I activated the switch and then connected the jumper cables to the battery. Same result--wires melted.
Tried to attach pic of the contactor on the firewall but unable to reduce the pic file size.
Joe asked what size wire I used. 18 awg contactor to master switch; 22 awg to field of tabs. I can not recall whay I used the 18 awg instead of 22 awg. The 18 awg survived the event. The 22 awg melted, as a fussible link for the 18 awg?
Bob, if you still want the contactor I'll gladly send it to you. Just let me know where to send.
Thanks everyone for you interest and advice. I have ordered a new contactor from our friends at B&C.
Ceengland
Posted: Wed Jul 07, 2021 3:47 pm Post subject: Melted battery contractor ground wire |
Frank McDonald
Kitfox S7 - sold
RV7 in progress
Acworth, GA
That doesn't 'sound' right. There should be 2 'fat' terminals and one
small terminal on a typical master contactor. With no voltage applied,
you should measure open circuit (infinite resistance) between the small
terminal and one of the fat terminals, some relatively low (but not
close to zero; see Joe's resistance number) resistance between the small
terminal and the other fat terminal, and infinite resistance between
the 2 fat terminals.
Measuring .016 ohms with a typical ohm meter sounds a little suspicious;
there's often more resistance than that in the leads and terminal
contact points.
Did you have it hooked up as shown in this video?
https://www.youtube.com/watch?v=7FSK1JblQaE
Near the end, he shows how to hook up a 4 terminal version (less common).
Charlie
_________________ Charlie |
user9253
Posted: Wed Jul 07, 2021 4:30 pm Post subject: Re: Melted battery contractor ground wire |
Frank, I interpreted your post to mean that you connected one jumper cable from battery positive to a fat terminal on the contactor,
and you connected another jumper cable from the negative battery terminal to the other contactor fat terminal.
If that is true, then you are lucky that the contactor is defective. There could have been flying molten metal.
The negative battery terminal should NOT be connected to a fat contactor terminal because something bad will happen.
frank3 Guest
Posted: Thu Jul 08, 2021 8:40 am Post subject: Re: Melted battery contractor ground wire |
Bob's questions answered:
1. Yes, the contactor has been functioning for a couple of months. I've been using jumper cables to connect a lawn tractor battery so I can test components as they are installed.
2. The measured resistance is 16.5 ohms, small terminal to battery side fat terminal with diode removed. (The 0.016 value reported and questioned by Charlie was using the wrong range).
3. There is no continuity between any of the terminals and the case.
4. This is a three terminal Cole Hersee provided by Vans Aircraft.
5. There was a spike supression diode installed, provided by Vans with terminals and shrink tube insulation already installed. I peeled back the insulation to ensure the diode was installed properly, with the band towards the fat terminal. As you suggested, the diode is now nonfunctional.
Bob, the contactor is in the mail.
As Doug suggested (6 Jul #11) I went through the suggested process to test the wiring and switch. Both were TRUE--both wiring and switch were proper.
BTW, I don't understand how a miss-wired switch could cause a direct short. My understand is the switch simply enables the circuit to conduct current or not. I can see the possibility of a short between the switch and the airframe but don't understand miss-wiring. Something I need educating about?
Jeff, I submitted the pic with contactor installed. We'll see if it gets published.
Joe (7 Jul #5), you interpreted my post correctly. After reviewing schematics I see I WAS lucky! (Might just as well connected the two jumper cables!!! Just talking to myself)
Charlie (7 Jul #4), thanks for suggesting the video on battery contractors. It was wired per the video. What you describe re: open circuits & resistance between the terminals is what I was getting. I must not have described clearly. And, as stated above, you were right to be suspicious of my #, I used the wrong range.
Again, thanks to all for their interest, questions, and suggestions.
frank3 Guest
Posted: Thu Jul 08, 2021 8:55 am Post subject: Re: Melted battery contractor ground wire |
Don't know if this is relevant but checked the fuses to all the circuits and found the 5amp fuse to the Dynon EFIS was blown. EFIS was only open circuit at the time of the incident. Evidence there must have been some kind of over voltage event, I guess.
New fuse and using EBUS circuit I found the EFIS is good to go.
Posted: Thu Jul 08, 2021 9:06 am Post subject: Melted battery contractor ground wire |
Is it possible that you inadvertently hooked-up the battery backwards that day?
On Thursday, July 8, 2021, 10:02:12 AM PDT, frank3 <frank3phyl(at)comcast.net> wrote:
Frank McDonald
Kitfox S7 - sold
RV7 in progress
Acworth, GA
http://forums.matronics.com/viewtopic.php?p=502753#502753
http://www.matronics.com/Navigator?AeroElectric-; - MATRONICS WEB FORUMS -
http://forums.matronbsp; - NEW MATRONICS LIST WIKI -
http://wiki.matronics.com
_-========================sp; - List Contribution Web Site -
http://www.matronics.com/contributi======================
Ceengland
Posted: Thu Jul 08, 2021 9:42 am Post subject: Melted battery contractor ground wire |
My 1st thought, as well. That would explain smoking the spike suppression diode on the contactor. Must have been God's Own suppression diode, though, to take the wire with it.
Charlie
user9253
Posted: Thu Jul 08, 2021 9:59 am Post subject: Re: Melted battery contractor ground wire |
I think that jluckey has solved the problem. Reverse battery polarity explains the melted wire and the blown fuse. Luckily the EFIS was not damaged.
I predict that Bob N will not find anything wrong with the contactor. An over voltage event is extremely unlikely without an alternator running.
It is pretty easy to reverse battery voltage when using jumper cables. One has a 50-50 chance of getting it wrong.
