jonboede(at)hotmail.com Guest
Posted: Sat Jun 19, 2021 6:13 pm Post subject: Oil temp still too high |
My oil temperature continues to be too high during engine break-in despite attempts to mitigate it.
Engine: zero-time overhaul M-14P, standard compression Barrett pistons, auto harness, no other engine mods (on a stock CJ-6A)
Does have Criag's oil filter kit. Oil cooler recently overhauled by Pacific Coast.
Previously I had very high oil temps and high CHTs so I went from a 1.4mm suction jet to a 1.3mm suction jet and switched from Aeroshell 100 straight mineral to Aeroshell 120 straight mineral (which is quite hard to find!)
Ambient air temperature 36C/97F. Field elevation 500 MSL.
Engine start showed oil pressure at 5 bar with inlet temp 35C.
Take-off at 2900 RPM and full throttle resulted in CHTs climbing to 210C and oil inlet temp to 65C, outlet climbing to 85C, oil pressure 5 bar.
Settled in a little lower than pattern altitude due to high CHT then CHT came back to 160-170C at 650-700mm MAP. Oil pressure 4 bar at 2400 rpm.
Oil temp continued to climb to 75C inlet temp, 100-110C outlet temp, while CHT 160C, oil pressure 4 bar at 2400 rpm.
Two circuits in the pattern at ~650mm MAP, oil inlet temp stabilizes at 75-80C, outlet 110C, CHT 160C, oil pressure a little below 4 bar at 2400 rpm.
Landed, CHT now dropping, oil inlet still 75C outlet 100C, approximately 1000 rpm, oil pressure now below 1 bar.
Ideas?
Jon
heaysr(at)telus.net Guest
Posted: Sun Jun 20, 2021 9:20 am Post subject: Oil temp still too high |
Are the gills confirmed to remain open in flight?
Royden
On Sat, Jun 19, 2021 at 7:23 PM Jon Boede <jonboede(at)hotmail.com (jonboede(at)hotmail.com)> wrote:
| Quote: | My oil temperature continues to be too high during engine break-in despite attempts to mitigate it.
Engine start showed oil pressure at 5 bar with inlet temp 35C.Â
Ideas?
Jon
n13472(at)aol.com Guest
Posted: Sun Jun 20, 2021 9:53 am Post subject: Oil temp still too high |
Have you checked the bypass relief valve to see if it is
correctly installed after the cooler was cleaned ?
Tom Elliott
CJ-6A NX63727
777 Quartz Ave
PMB 7004
Sandy Valley NV.
89019
Cell 541-297-5497
N13472(at)AOL.COM
From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of Royden Heays
Sent: Sunday, June 20, 2021 10:20 AM
To: yak-list(at)matronics.com
Subject: Re: Yak-List: Oil temp still too high
Royden
Ideas?
Jon
Virus-free. www.avg.com [url=#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2] [/url]
Posted: Sun Jun 20, 2021 12:17 pm Post subject: Oil temp still too high |
Yes, in fact I pulled the bypass out and put a few extra turns on the spring tension just to make sure. At this point I doubt it would open at an oil pressure less than 10 Kg/cm^2.
And the gill shutters are wide open. Changing the suction jet got the CHT under control but the oil temp remains a mystery.
| Quote: | On Jun 20, 2021, at 12:58 PM, Tom Elliott <n13472(at)aol.com> wrote:
 <![endif]--> <![endif]-->
Tom Elliott
CJ-6A NX63727
777 Quartz Ave
PMB 7004
Sandy Valley NV.
89019
Cell 541-297-5497
N13472(at)AOL.COM
Royden
Ideas?
Jon
Virus-free. www.avg.com [url=#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2][/url]
Posted: Sun Jun 20, 2021 12:55 pm Post subject: Oil temp still too high |
Who overhauled the engine and have you discussed the problem with them?Dennis
| Quote: | On Jun 20, 2021, at 1:22 PM, Royden Heays <heaysr(at)telus.net> wrote:
Royden
Ideas?
Jon
Posted: Sun Jun 20, 2021 1:54 pm Post subject: Oil temp still too high |
Richard Goode / Aerometal. Still scratching our collective head. They sent the smaller suction jets which helped the CHT. Richard thinks that since the engine is making much more power than a Chinese engine perhaps the Chinese oil cooler is struggling to get rid of the extra heat.
| Quote: | On Jun 20, 2021, at 4:00 PM, Anthony Savarese <dsavarese0812(at)bellsouth.net> wrote:
 Who overhauled the engine and have you discussed the problem with them? Dennis
Royden
Ideas?
Jon
pennington.construction.i Guest
Posted: Sun Jun 20, 2021 2:28 pm Post subject: Oil temp still too high |
Jon
I fly and M14P powered CJ. It has a Chinese oil cooler. I replaced mine with a new one from Doug. Mine was leaking. Â
The new cooler is very efficient. Cools very well. I flew this week on a 90 degree day. Had the cooler door closed completely to get the temperature up. Â
Chinese cooler is not a problem. Â
Call anytime.Â
Mark Pennington
N621CJ. Â
804 399 4224
On Sun, Jun 20, 2021 at 5:59 PM Jon Boede <jonboede(at)hotmail.com (jonboede(at)hotmail.com)> wrote:
| Quote: | Richard Goode / Aerometal. Still scratching our collective head. They sent the smaller suction jets which helped the CHT. Richard thinks that since the engine is making much more power than a Chinese engine perhaps the Chinese oil cooler is struggling to get rid of the extra heat.Â
| Quote: | On Jun 20, 2021, at 4:00 PM, Anthony Savarese <dsavarese0812(at)bellsouth.net (dsavarese0812(at)bellsouth.net)> wrote:
| Quote: | On Jun 20, 2021, at 1:22 PM, Royden Heays <heaysr(at)telus.net (heaysr(at)telus.net)> wrote:
Royden
Ideas?
Jon
Posted: Sun Jun 20, 2021 2:32 pm Post subject: Oil temp still too high |
Could be. I know Richard’s/Aerometal’s engines are outstanding engines and Richard always takes care of his customers.
| Quote: | On Jun 20, 2021, at 5:56 PM, Jon Boede <jonboede(at)hotmail.com> wrote:
Royden
Ideas?
Jon
Posted: Sun Jun 20, 2021 2:37 pm Post subject: Oil temp still too high |
Jon
Call when you a minuteÂ
Mark Pennington
N621CJ. Â
804 399 4224
On Sun, Jun 20, 2021 at 6:36 PM Anthony Savarese <dsavarese0812(at)bellsouth.net (dsavarese0812(at)bellsouth.net)> wrote:
| Quote: | Could be. I know Richard’s/Aerometal’s engines are outstanding engines and Richard always takes care of his customers. Â
| Quote: | On Jun 20, 2021, at 5:56 PM, Jon Boede <jonboede(at)hotmail.com (jonboede(at)hotmail.com)> wrote:
Royden
Ideas?
Jon
Posted: Sun Jun 20, 2021 2:42 pm Post subject: Oil temp still too high |
Richard’s customer service is fantastic. I’m very happy with him and with the engine.
I’ve sent an order to Doug for a new cooler. Perhaps Pacific Coast didn’t do as great a job on my overhaul as I’d hoped.
Jon
| Quote: | On Jun 20, 2021, at 5:36 PM, Anthony Savarese <dsavarese0812(at)bellsouth.net> wrote:
Royden
Ideas?
Jon
hill(at)doctor-hill.com Guest
Posted: Sun Jun 20, 2021 3:34 pm Post subject: Oil temp still too high |
I fly a CJ with a low time M-14P. In June here in central Arizona we’re seeing temps around 110°F on a routine basis. Bought a new, stock CJ oil cooler from Doug. Oil temps have been fine.
Warren
| Quote: | On Jun 20, 2021, at 3:42 PM, Jon Boede <jonboede(at)hotmail.com (jonboede(at)hotmail.com)> wrote:
Jon | Quote: | On Jun 20, 2021, at 5:36 PM, Anthony Savarese <dsavarese0812(at)bellsouth.net (dsavarese0812(at)bellsouth.net)> wrote:  Could be. I know Richard’s/Aerometal’s engines are outstanding engines and Richard always takes care of his customers. Sent from my iPhone
| Quote: | On Jun 20, 2021, at 5:56 PM, Jon Boede <jonboede(at)hotmail.com (jonboede(at)hotmail.com)> wrote:  Richard Goode / Aerometal. Still scratching our collective head. They sent the smaller suction jets which helped the CHT. Richard thinks that since the engine is making much more power than a Chinese engine perhaps the Chinese oil cooler is struggling to get rid of the extra heat. | Quote: | On Jun 20, 2021, at 4:00 PM, Anthony Savarese <dsavarese0812(at)bellsouth.net (dsavarese0812(at)bellsouth.net)> wrote:  Who overhauled the engine and have you discussed the problem with them? Dennis Sent from my iPhone
| Quote: | On Jun 20, 2021, at 1:22 PM, Royden Heays <heaysr(at)telus.net (heaysr(at)telus.net)> wrote:  Are the gills confirmed to remain open in flight?
Royden
Ideas?
Jon
richard.goode(at)russiana Guest
Posted: Sun Jun 20, 2021 11:26 pm Post subject: Oil temp still too high |
As I think it is clear, we – that is Aerometal, my partner in Hungary – overhauled Jon’s engine. As I think people know, we have a proper dynamometer, and every engine on which we work undergoes a formal test programme in which it is run for a minimum of three hours and every parameter recorded, and provided to the customer. Certainly, everything was absolutely normal in terms of oil temperature and pressure. As I believe Jon will confirm, we have been doing everything we can to help him – since he clearly has a problem, and my view is that those temperatures are definitely too high. But of course we are inevitably in the dark since we have no idea of what modifications were done to the Nanchang oil system to accommodate the M 14 engine. It would seem from what Jon has told us, everything is as it should be, but of course there is always potential if one is deviating from original, of something being strange.
In particular I was concerned about the oil cooler – I'd emphasise that we know very little about the Chinese oil cooler, but I do know that in the Russian cooler, which originally were fitted with a thermostatic valve, but this was very prone to sticking, and has been removed from virtually all aircraft. I understand that the Chinese oil cooler has a bypass valve operating on pressure, not temperature. But given that Jon has an engine delivering a lot more power than 285 hp, and so that much more heat, I suggested that he should remove all bypass aspects of the cooler, ensuring that all oil would have to go through the cooler.
But we are obviously in touch with him and will do what we can to sort out the issues.
Richard Goode
RICHARD GOODE AEROBATICS
Rhodds Farm, Lyonshall, Hereford, HR5 3LW, UK
Tel: +44 (0)1544 340120 Fax: +44 (0)1544 340129
e-mail: richard.goode(at)russianaeros.com (richard.goode(at)russianaeros.com)
www.russianaeros.com
WORLD LEADERS IN RUSSIAN SPORTING AIRCRAFT & ENGINES
In partnership with Aerometal Kft, Hungary.
From: owner-yak-list-server(at)matronics.com <owner-yak-list-server(at)matronics.com> On Behalf Of W LANNON
Sent: 21 June 2021 04:51
Subject: Re: Oil temp still too high
Jon;
The temperature numbers you listed are pretty much what one should expect for the initial stages of break-in. The oil pressure, on the other hand, is not. Can you tell me the total time on the cylinders and whether they installed new cylinder barrels. If indeed the overhaul facility is a reputable organization you should have a multi page overhaul report detailing all new components and details of all the inspection, repair and restoration procedures complied with.
Best;
Walt
From: "Jon Boede" <jonboede(at)hotmail.com (jonboede(at)hotmail.com)>
Sent: Sunday, June 20, 2021 3:42:25 PM
Jon
Dennis
Royden
Ideas?
Jon
Harv
Posted: Thu Jun 24, 2021 2:00 am Post subject: Re: Oil temp still too high |
Jon
Interesting issue.
With the stock Housai 285hp engine I find the stock oil cooler way too effective (although I would like a nice lightweight version that fits in the stock location as this one weighs 25kg!) and find its hard to maintain temps in the green even in the summer when we see 25degC (UK based).
Agree with Richard to disable the stock cooler bypass function (I wouldn't remove the bypass internals to do that as the oil likely to take the path of least resistance and go through the by-pass line and not through the cooling section) test the flow on the bench.
Are you still using the Chang's stock CHT and oil temp senders and gauges or a mix of bits from the YAK and Chang?
Couple of other things come to mind generally (you may have done these)
Are you able to do a infrared heat tester check on the CHT and oil cooler temps on the ground to see if they correlate to what the gauges are reading?
Do you have a way to test if the engine is running lean or not (rig up a basic stoichiometric tester and observe readings at different rpm points on a ground run?)
Cheers
Harv
