Constant Speed Propeller
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Lom-List
mike(at)vision499.com
PostPosted: Tue May 25, 2021 8:01 pm    Post subject: Constant Speed Propeller Reply with quote
Hello
I have a LOM constant speed propeller that is leaking a small amount of
oil from the base of the boss that the prop blade is mounted in where it
rotates on the prop hub.
Is the leak significant and should it be repaired?
If it needs to be repaired is it something I can do myself?
Mike
- The Matronics Lom-List Email Forum -
http://www.matronics.com/Navigator?Lom-List
 Filesize:  89.78 KB
 Viewed:  11593 Time(s)
Untitled_attachment_00114.txt
Download
 Filename:  Untitled_attachment_00114.txt
 Filesize:  25 Bytes
 Downloaded:  763 Time(s)
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Lom-List All times are GMT - 8 Hours
