intake/exhaust stack-to-cylinder rings... ?
draftsjust417(at)gmail.co
PostPosted: Sun May 16, 2021 2:53 pm    Post subject: intake/exhaust stack-to-cylinder rings... ? Reply with quote
All-Do we have the part number for the metal rings/donuts that fit between
the intake/exhaust stacks and the back if the cylinder heads?
I can't find it in the parts catalogs...
Thanks--
Justin/N280NC
pennington.construction.i
PostPosted: Mon May 17, 2021 3:06 am    Post subject: intake/exhaust stack-to-cylinder rings... ? Reply with quote
Justin
I am sure there are part numbers.   But I have purchased those from Doug and Richard.
The exhaust are called exhaust donuts in the US.
I think, correct me if I am wrong across the pond they call them exhaust olive gaskets.
The seals for the intake side are paper from the factory.  There is an upgrade to a red viton Oring seal that I installed 2 years ago.  Zero problems since then.  I completely cleaned out the gasket channel and installed two of the new paper gaskets then the viton ORing.   It seals perfectly. I took one of the orings out this last condition inspection and the paper gaskets were still clean and like new.  No oil seepage around the Oring.
I am sure Doug has all of this stuff.  I am running an M14P on my CJ.  The parts could be the same.
Reach out to Doug and Richard if need be.
Mark
N621CJ.
On Sun, May 16, 2021 at 6:57 PM Justin Drafts <draftsjust417(at)gmail.com (draftsjust417(at)gmail.com)> wrote:
Thanks--
Justin/N280NC
richard.goode(at)russiana
PostPosted: Mon May 17, 2021 4:47 am    Post subject: intake/exhaust stack-to-cylinder rings... ? Reply with quote
Yes, in Europe we call them exhaust "olives". The standard size is 10 mm thickness, but we realised that a certain number of people fail to tighten the exhaust nuts on a regular basis; the exhaust plus olive then "fret" against the cylinder head and wear it away, and in these cases we manufacture thick olives to any size people might want. So the standard olives are Euro 28 each and the thicker ones in any dimension (to order, since we manufacture them) are Euro 38 each.
And the intake tube gaskets are of course different – it is a rubber ring at the supercharger end, for which we charge Euro 4 per ring and at the cylinder end it is a paper gasket, but in order to get the appropriate thickness one needs three of them per intake tube. Cost is Euro 2 per gasket, so Euro 6 for the three and so a total of Euro 10 per intake tube!
All are in stock with Aerometal in Hungary, so let us know if anyone needs them.
Richard
RICHARD GOODE AEROBATICS
Rhodds Farm, Lyonshall, Hereford, HR5 3LW, UK
Tel: +44 (0)1544 340120 Fax: +44 (0)1544 340129
e-mail: richard.goode(at)russianaeros.com (richard.goode(at)russianaeros.com)
www.russianaeros.com
WORLD LEADERS IN RUSSIAN SPORTING AIRCRAFT & ENGINES
In partnership with Aerometal Kft, Hungary.
From: owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com) <owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com)> On Behalf Of Mark Pennington
Sent: 17 May 2021 12:05
Subject: Re: Re: intake/exhaust stack-to-cylinder rings... ?
Justin
Mark
N621CJ.
All-
Thanks--
Justin/N280NC
GeorgeCoy
PostPosted: Mon May 17, 2021 5:45 am    Post subject: intake/exhaust stack-to-cylinder rings... ? Reply with quote
The M14 part numbers are:
10-04-46 Intake gasket upper pipe to cylinder 3 per cylinder
14-04-542 Exhaust Gasket (doughnut)
10-04-26 Intake gasket lower pipe to supercharger case
George Coy
MotorstarNA
714 Airport Rd.
Swanton VT 05488
802-868-5633 off
802-363-5782 cell
george.coy(at)gmail.com (george.coy(at)gmail.com)
http://motorstarna.com/
SKYPE george.coy
From: owner-yak-list-server(at)matronics.com <owner-yak-list-server(at)matronics.com> On Behalf Of Richard Goode
Sent: Monday, May 17, 2021 8:47 AM
To: yak-list(at)matronics.com
Subject: RE: Re: intake/exhaust stack-to-cylinder rings... ?
Richard
Justin
Mark
N621CJ.
All-
Thanks--
Justin/N280NC
PostPosted: Mon May 17, 2021 7:15 am    Post subject: intake/exhaust stack-to-cylinder rings... ? Reply with quote
Great info all, thanks-I learn something every time I open the cowls.
Thought there were olives/rings on both intakes & exhausts, good to know just exhaust stacks and fewer req'd.
I'm running a Chinese Housai, any info on those ring p/n's?
Thanks again- Justin
On Mon, May 17, 2021, 6:49 AM George <george.coy(at)gmail.com (george.coy(at)gmail.com)> wrote:
George Coy
MotorstarNA
714 Airport Rd.
Swanton VT 05488
802-868-5633 off
802-363-5782 cell
SKYPE george.coy
From: owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com) <owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com)> On Behalf Of Richard Goode
Richard
Justin
Mark
N621CJ.
All-
Thanks--
Justin/N280NC
PostPosted: Mon May 17, 2021 8:44 am    Post subject: intake/exhaust stack-to-cylinder rings... ? Reply with quote
Excellent info, thanks Walt!Justin
On Mon, May 17, 2021, 9:39 AM Walter Lannon <wlannon(at)shaw.ca (wlannon(at)shaw.ca)> wrote:
Hi Justin:
The exhaust seals are identical for both the HS and M14 engines.
There are stainless steel units manufactured by one of the US exhaust manufacturers.  I have those on my engine but would caution any one considering same to be aware of the fact that as theses units are pressed in manufacture they leave a sharp protruding edge that will destroy the aluminum alloy cylinder seat.
If they are perfectly centered  they will work however I have yet to see an exhaust system made to perfectly align with all of the cylinder seats.
I have modified these for my own use but it is an extremely dangerous hand grinding operation.
Walt
Sent: Monday, May 17, 2021 8:14 AM
Great info all, thanks- I learn something every time I open the cowls.
George Coy
MotorstarNA
714 Airport Rd.
Swanton VT 05488
802-868-5633 off
802-363-5782 cell
SKYPE george.coy
Subject: RE: Yak-List: Re: intake/exhaust stack-to-cylinder rings... ?
Richard
Justin
Mark
N621CJ.
All-
Thanks--
Justin/N280NC
PostPosted: Mon May 17, 2021 8:48 am    Post subject: intake/exhaust stack-to-cylinder rings... ? Reply with quote
Walt.
I just had this education recently from Richard.
They make the exhaust olives in three thickness.
10, 12 and 14mm to help fit the flanges better.
Since I used these my exhaust fits very well and stays tight.  Grinding those would be difficult at best.
I have attached a photo of what Richard supplies.  I understand Richard uses these on a regular basis
On his side of the pond
[img]cid:1797b398a21599a0a211[/img]
On Mon, May 17, 2021 at 12:39 PM Walter Lannon <wlannon(at)shaw.ca (wlannon(at)shaw.ca)> wrote:
Hi Justin:
Walt
George Coy
MotorstarNA
714 Airport Rd.
Swanton VT 05488
802-868-5633 off
802-363-5782 cell
SKYPE george.coy
Richard
Justin
Mark
N621CJ.
All-
Thanks--
Justin/N280NC
 Filesize:  1.27 MB
 Viewed:  5879 Time(s)
PostPosted: Mon May 17, 2021 8:50 am    Post subject: intake/exhaust stack-to-cylinder rings... ? Reply with quote
Walt.
Mark
N621CJ
[img]cid:1797b3c3510599a0a211[/img]
Hi Justin:
Walt
George Coy
MotorstarNA
714 Airport Rd.
Swanton VT 05488
802-868-5633 off
802-363-5782 cell
SKYPE george.coy
Richard
Justin
Mark
N621CJ.
All-
Thanks--
Justin/N280NC
 Filesize:  1.27 MB
