Gilles
Posted: Tue May 11, 2021 3:56 pm Post subject: Canopy antenna? |
Hello all,
My buddy is building a light carbon fuselage airplane.
The mounting of the comm antenna is envisaged in the fiberglass fin, but
in order to save the 0.5 kg of RG 58 to the tail, we are wondering
whether some discreet antenna could be glued to the underside of the
cockpit canopy?
Or maybe some not-too-lossy lighter coaxial and connectors could be used?
Any advice appreciated,
Thanks in advance,
Best regards,
Gilles
http://contrails.free.fr
http://lapierre.skunkworks.free.fr
_________________ Best regards,
Gilles
http://contrails.free.fr |
Peter(at)sportingaero.com Guest
Posted: Wed May 12, 2021 12:22 pm Post subject: Canopy antenna? |
Everything is a compromise. Copper tape can be used to create an antenna, the more of the antenna that is vertical the better the performance. A BNC connector can be soldered on to the foot, not sure how the ground plane would work, perhaps it needs to be a dipole? I haven't been very close to anyone who has used a tape antenna, but my impression was always that they required more maintenance, and often have worse performance, than installed antennas. How important is a reliable radio against saving weight?
Peter
Gilles
Posted: Fri May 14, 2021 12:40 pm Post subject: Canopy antenna? |
Le 12/05/2021 à 22:21, Peter Pengilly a écrit :
Peter,
Thank you for your advice. Indeed the main point is having a reliable
radio, so the antenna (Bob Archer) will be in the glass fiber fin, as
originally intended.
I'll may be able to locate some quality smaller diameter coaxial with
acceptable performance as compared to our good old RG58.
Thanks for your help,
Best regards,
Gilles
Gilles
Posted: Fri May 14, 2021 3:16 pm Post subject: Canopy antenna? |
Quote: | Thank you for your advice. Indeed the main point is having a reliable radio, so the antenna (Bob Archer) will be in the glass fiber fin, as originally intended. |
good show
Quote: | I'll may be able to locate some quality smaller diameter coaxial with acceptable performance as compared to our good old RG58. |
RG174 See if you can get a supplier that offers prefab
cables. Putting connectors on this coax is NOT for the
novice wire slinger.
here is one supplier . . . there are no doubt others
https://tinyurl.com/yfgmx3z2
out of that stuff?"
