Clutch for warp drive prop
mibear117(at)gmail.com
PostPosted: Fri Apr 02, 2021 5:59 pm    Post subject: Clutch for warp drive prop Reply with quote
Hello fellow flyers:
I recently had leaking from a C-box and took it off and put new gasket and seals in it.I was in the process of reinstalling it on my kolb2 but stopped after noticing part of the clutch for the prop that is covered by the c-box had some damage to it.can I buy the part separately (who sells it)or do I have to buy the whole clutch?the photos show the worst of it.Thanks for any input🙂
Dana,Bear Lake ,Mi.
 Filesize:  85.51 KB
 Viewed:  4146 Time(s)
 Filesize:  1.32 MB
 Filesize:  1002.06 KB
PostPosted: Sat Apr 03, 2021 6:17 am    Post subject: Clutch for warp drive prop Reply with quote
I will try a photo again.
Thanks Dana, Bear Lake, Mi.
 Filesize:  316.44 KB
 Viewed:  4135 Time(s)
williamtsullivan(at)att.n
PostPosted: Sat Apr 03, 2021 8:19 am    Post subject: Clutch for warp drive prop Reply with quote
All photos came through. I can't help, but perhaps Richard Pike or John Hauck can. You might also try cross-posting to the Rotax List.
Good luck
Bill Sullivan
On Saturday, April 3, 2021, 10:17:49 AM EDT, Dan Ried <mibear117(at)gmail.com> wrote:
roy.spangler(at)kirtland.
PostPosted: Sat Apr 03, 2021 8:30 am    Post subject: Clutch for warp drive prop Reply with quote
I would check with Steve Henry - he has been using clutches
for quite some time.
roy
On Sat, Apr 3, 2021 at 12:21 PM william sullivan <williamtsullivan(at)att.net (williamtsullivan(at)att.net)> wrote:
Good luck
Bill Sullivan
On Saturday, April 3, 2021, 10:17:49 AM EDT, Dan Ried <mibear117(at)gmail.com (mibear117(at)gmail.com)> wrote:
