Posted: Fri Apr 03, 2015 8:57 am Post subject: Blue Mountain EFIS |
Does anyone by any chance know anything about correcting the altimeter read out on a Blue Mountain EFIS?
Regards, David Joyce, G-XSDJ
h&jeuropa
Posted: Sat Apr 04, 2015 3:23 am Post subject: Re: Blue Mountain EFIS |
David,
Here is a paragraph from an old EFIS 1 install manual. As I recall, the altimeter was not very stable. Best way to calibrate is to replace the EFIS with any current EFIS offering!
Jim & Heather
N241BW
 Download |
| Filename: |
Altimeter.docx |
10.95 KB |
| Downloaded: |
604 Time(s) |
rampil
Posted: Sat Apr 04, 2015 5:14 am Post subject: Re: Blue Mountain EFIS |
David,
Please tell us which BMA device you are using, and specifically what the problem is. Are you asking how to set the barometric pressure, or are you implying that once set, the altitude display is wrong?
I have a Gen4 now, and before that a Gen2 "gold box"
Never had an issue with the Altimeter. Never heard that anyone
had "stability" problems.
Posted: Sat Apr 04, 2015 8:19 am Post subject: Blue Mountain EFIS |
Ira, The EFIS has always worked superbly (& I am loath to change it,) but the altimeter has always been about 100ft out and as my steam age back up altimeter has just given up the ghost I would like to adjust the Blue Mountain one. The manual says ring the factory. Clearly I can open the altimeter tab and apply common sense, but that is not always the complete solution and I do not want to make it worse if you or anyone knows what the factory would have said!
Regards, David
On 2015-04-04 14:14, rampil wrote: [quote] | Quote: | --> Europa-List message posted by: "rampil" <ira.rampil(at)gmail.com (ira.rampil(at)gmail.com)>
David,
Ira N224XS
http://forums.matronics.com/viewtopic.php?p=440269#440269
ics.com
.matronics.com/contribution
| [b]
Posted: Sat Apr 04, 2015 8:24 am Post subject: Blue Mountain EFIS |
Jim, Mine is a Gen 4 so I think the EFIS 1 instructions do not apply sadly
Regards, David
On 2015-04-04 12:23, h&jeuropa wrote: [quote] [b]
rampil
Posted: Sat Apr 04, 2015 11:01 am Post subject: Re: Blue Mountain EFIS |
Hi David,
I believe this is the document you are searching for!
I am in contact with Greg from time to time, but his new ventures
are keeping him quite busy and it is very difficult for him to support
ten year products.
 Download |
| Filename: |
ALTCALG4.pdf |
143.16 KB |
| Downloaded: |
802 Time(s) |
Posted: Sat Apr 04, 2015 1:51 pm Post subject: Blue Mountain EFIS |
Ira, Many thanks for that. Regards, David
On 2015-04-04 20:01, rampil wrote: [quote] [b]
fasilpereira
Posted: Sun Mar 21, 2021 11:33 am Post subject: Re: Blue Mountain EFIS database |
Hi,
I'm looking for the database (terrain/airports) files to reload on my efis after a problem I had with it. I prefer data from 2008, if available, but please contact me and tell me what you have.
Thank you,
Fabricio
fasilpereira(at)yahoo(dot)com
_________________ Fabricio Pereira
Engineer / Pilot |
filiperosa
Posted: Sun May 22, 2022 2:29 pm Post subject: Re: Blue Mountain EFIS |
Hello,
I am looking for a G4 terrain and map files for Europe. If anyone has them please contact me on:
filiperosa / 360blue.org
Thanks!
Filipe
