Getting ready for the panel
DJAV
PostPosted: Sun Mar 07, 2021 4:18 pm    Post subject: Getting ready for the panel Reply with quote
Here is what I got so far for the panel. I'm wafting on Approach Fast Stack Pro-X Hub for the harness connections to make it easy on me. You'll see the mock-up for the plan layout. Any suggestion greatly appreciated.
 Filesize:  296.22 KB
 Viewed:  4680 Time(s)
 Filesize:  1.05 MB
NavyDoc
gbrighton(at)skymesh.com.
PostPosted: Mon Mar 08, 2021 12:48 pm    Post subject: Getting ready for the panel Reply with quote
Hi NavyDoc,
Lots of Goodies there .. looks great .. no advice ..
but good luck .. and plz post progress .. as an aside ... i have a GRT Mini
installed in my TR1 .. i mounted the Magetometor out on the wing tip end
Rib .. Nav lite is near by .. but sweeping a hand held Compass around the
area of the mount location showed no Magnetic interference .. But my Mini is
not working correctly .. was hoping for a simple' plug and play' but so ..
need to focus in on what the bug is .. and sort it out .. other priorities
at present however !
Graham
