fly4grins(at)gmail.com Guest
Posted: Thu Feb 04, 2021 12:29 am Post subject: RV-List Digest: 4 Msgs - 02/03/21 |
 Hi All- I was under the impression viton was not good for reciprocating applications, like brake pucks. Is there any experience out there to the contrary?
Thanks in advance!Â
Gary.A.Sobek
Posted: Thu Feb 04, 2021 5:15 am Post subject: RV-List Digest: 4 Msgs - 02/03/21 |
Been using Viton on the calipers for 10+ years. They last longer than the mil spec o-rings. They are higher temperature rated BUT the down side is they can leak and not seal as well as lower temperatures. I typically do not operate my RV at the lower temperature so it is not a big deal for me.
https://o-ring.info/en/materials/vitonr--fkm/vitonr-temperature-rating/
https://www.sealingdevices.com/temperature-ranges
Gary A. Sobek
"My Sanity" RV-6 N157GS O-320 Hartzell,
3,400+ Flying Hours NC25, USA
From: owner-rv-list-server(at)matronics.com <owner-rv-list-server(at)matronics.com> on behalf of GLEN MATEJCEK <fly4grins(at)gmail.com>
Sent: Thursday, February 4, 2021 8:28 AM
To: rv-list <rv-list(at)matronics.com>
Subject: Re: RV-List Digest: 4 Msgs - 02/03/21
Thanks in advance!
arplnplt(at)gmail.com Guest
Posted: Thu Feb 04, 2021 6:37 am Post subject: RV-List Digest: 4 Msgs - 02/03/21 |
I replaced the stock break seals on my RV10 with viton seals after they failed due to a long taxi at KOSH one year. Never a problem after that. Also used ATF for fluid due to higher flash point.
Dave Leikam
| Quote: | On Feb 4, 2021, at 2:32 AM, GLEN MATEJCEK <fly4grins(at)gmail.com> wrote:
Thanks in advance!
garyvanremortel(at)gmail. Guest
Posted: Thu Feb 04, 2021 7:50 am Post subject: RV-List Digest: 4 Msgs - 02/03/21 |
Very little reciprocation occurs in disk brake caliper piston. I replaced the original leaking Nitrile O-rings in mine with Viton 15 yrs ago and haven't had a problem since. If you are concerned with the poor low temp performance of Viton in your climate, go with Fluorosilicone.
-GV
On Thu, Feb 4, 2021 at 12:32 AM GLEN MATEJCEK <fly4grins(at)gmail.com (fly4grins(at)gmail.com)> wrote:
Thanks in advance!Â
