Poor Man's Battery Tester
Goto page 1, 2  Next
revenson3(at)gmail.com
PostPosted: Fri Jan 29, 2021 8:20 pm    Post subject: Poor Man's Battery Tester Reply with quote
I built Bob's "Poor Man's Battery Capacity Tester".
Somehow I got the impression the relay would 'drop' out and thus turn off the lamp and clock when the battery reached about 10V.   But after re-reading "Battery Replacement: A Plan for Throwing in the Towel", that expectation is not written there.   My experience has been that it turns off when the battery reaches about 4V.
Odyssey Load Test Procedure and Reconditioning Procedures recommend ending the test at 10V.   I've done this, but it requires my presence when the battery nears 10V.
Is there a way to modify this circuit so that it will 'turn off' when the battery reaches 10V?
Or, is there a commercially available tester that would load a battery at 4 amps and record the time required until the battery reaches 10V?
Roger.
PostPosted: Sat Jan 30, 2021 5:17 am    Post subject: Re: Poor Man's Battery Tester Reply with quote
Bob's Poor Man's Battery Tester http://www.aeroelectric.com/articles/battest.pdf
is supposed to shut off automatically at 10 volts. Did you change any parts values?
Did you use a 10 volt zener?
Joe Gores
PostPosted: Sat Jan 30, 2021 5:38 am    Post subject: Re: Poor Man's Battery Tester Reply with quote
Trouble shooting the battery tester:
Is the zener diode installed backwards?
If one end of the zener diode is disconnected, does the relay drop out?
If not, has the correct transistor been used?
Has the transistor been connected correctly?
Joe Gores
Eric Page
PostPosted: Sat Jan 30, 2021 8:38 am    Post subject: Re: Poor Man's Battery Tester Reply with quote
It sounds like your circuit may be shutting off at the natural dropout voltage of the relay, which suggests that full battery voltage is reaching the relay's coil.
In addition to Joe's suggestions, check that the Zener diode is actually a 10V device, and not something near 3V, and that it hasn't failed (diodes can fail short circuit).
PostPosted: Sat Jan 30, 2021 5:12 pm    Post subject: Poor Man's Battery Tester Reply with quote
Bought new resistors and 10V zener. Rewired carefully on a test board. This time it kicked off, but at a higher voltage than I wanted (12V).
The zener was a NTE5019A, 10.0V +/-5%, 1/2 watt. Isn't that more like +/-20%? Cost all of $0.79.
I'll go back Monday, see if I can get a +/-1% zener, and ask about a higher quality brand.
Thanks for your comments. One more question...does the wattage make a difference in this circuit?
Roger.
On Fri, Jan 29, 2021, 9:23 PM Roger Evenson <revenson3(at)gmail.com (revenson3(at)gmail.com)> wrote:
Roger.
PostPosted: Sat Jan 30, 2021 5:33 pm    Post subject: Re: Poor Man's Battery Tester Reply with quote
The problem is not the tolerance of the zener.
The resistors affect the dropout voltage too.
Try a 9 volt zener. They are cheap. Buy a few different values to experiment with.
Wattage does not affect the circuit very much. 1/2 watt is good.
Joe Gores
charlesdavis(at)iuncapped
PostPosted: Sat Jan 30, 2021 9:02 pm    Post subject: Poor Man's Battery Tester Reply with quote
You may have better luck getting 2x5v 1% zeners than a 10v 1% - just
wire them in series
Charles
Roger.
PostPosted: Sun Jan 31, 2021 8:10 pm    Post subject: Poor Man's Battery Tester Reply with quote
At 10:24 AM 1/31/2021, you wrote:
--> AeroElectric-List message posted by: Dick Tasker <dick(at)thetaskerfamily.com>
Unfortunately they don't make 5V zeners - only 4.7V or 5.1V.
The turnoff voltage is also affected by the actual dropout current of the relay as well. The less current it takes to hold in the relay, the lower the voltage it drops out at. And conversely, the higher the current it takes to hold the relay on, the higher the voltage it drops out at.
My apologies guys . . . I intended to update that
article years ago for just problems you're wrestling
with. I sat down today and finished an update that I
started some time ago.
https://tinyurl.com/y44wl64t
The 'sloppy' zener is replaced with a precision
adjustable zener. The test set's trip point is
calibrated by one of two methods. Use precision,
1% resistors to bias up the reference port of the
zener -OR- you can use 5% resistors and a potentiometer
to fabricate an adjustable trip point feature.
Either technique yields a predictable and stable
set point for disconnecting the test load. Again,
please forgive my tardiness.
I'll also remind readers of a sophisticated
battery test option in the form of West Mountain
Radio's CBA series, computer driven battery
testers.
https://tinyurl.com/mas7ea9
The one I have right now is probably the 4th
in a series that I've owned over the last 20
years, give or take. They are versatile and
accurate.
But for most of our brother's need to peek
into Conditions for Continued Airworthiness,
the Po' Man's battery-runner-downer is of
excellent value.
out of that stuff?"
jluckey(at)pacbell.net
PostPosted: Sun Jan 31, 2021 10:18 pm    Post subject: Poor Man's Battery Tester Reply with quote
Is that the correct symbol for the 1N4001? Is it a zener?
-Jeff
On Sunday, January 31, 2021, 08:24:34 PM PST, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com> wrote:
testers.
accurate.
excellent value.
out of that stuff?"
PostPosted: Sun Jan 31, 2021 10:28 pm    Post subject: Poor Man's Battery Tester Reply with quote
and do you need the second 470 ohm resistor between the transistor base & the LM431?
-Jeff
On Sunday, January 31, 2021, 10:18:10 PM PST, Jeff Luckey <jluckey(at)pacbell.net> wrote:
-Jeff
--> AeroElectric-List message posted by: Dick Tasker <dick(at)thetaskerfamily.com> Unfortunately they don't make 5V zeners - only 4.7V or 5.1V. The turnoff voltage is also affected by the actual dropout current of the relay as well. The less current it takes to hold in the relay, the lower the voltage it drops out at. And conversely, the higher the current it takes to hold the relay on, the higher the voltage it drops out at.
My apologies guys . . . I intended to update that article years ago for just problems you're wrestling with. I sat down today and finished an update that I started some time ago. https://tinyurl.com/y44wl64t The 'sloppy' zener is replaced with a precision adjustable zener. The test set's trip point is calibrated by one of two methods. Use precision, 1% resistors to bias up the reference port of the zener -OR- you can use 5% resistors and a potentiometer to fabricate an adjustable trip point feature. Either technique yields a predictable and stable set point for disconnecting the test load. Again, please forgive my tardiness. I'll also remind readers of a sophisticated battery test option in the form of West Mountain Radio's CBA series, computer driven battery testers. https://tinyurl.com/mas7ea9 The one I have right now is probably the 4th in a series that I've owned over the last 20 years, give or take. They are versatile and accurate. But for most of our brother's need to peek into Conditions for Continued Airworthiness, the Po' Man's battery-runner-downer is of excellent value.
Bob . . . Un impeachable logic: George Carlin asked, "If black boxes survive crashes, why don't they make the whole airplane out of that stuff?"
yellowduckduo(at)gmail.co
PostPosted: Mon Feb 01, 2021 3:26 am    Post subject: Poor Man's Battery Tester Reply with quote
I just use a 12 volt automotive inverter to drive 120 volt lamps as a
load.  The cigarette lighter inverters that I have automatically shut
down right around 10 volts input.  Close enough for me.
Ken
> drops out at.
https://tinyurl.com/y44wl64t <https://tinyurl.com/y44wl64t>
  testers.
https://tinyurl.com/mas7ea9 <https://tinyurl.com/mas7ea9>
  accurate.
  excellent value.
  out of that stuff?"
PostPosted: Mon Feb 01, 2021 6:00 am    Post subject: Re: Poor Man's Battery Tester Reply with quote
Bob, clocks that run off from 120 VAC are rare.
I suggest that the AC clock be replaced by a 1.5 volt battery operated clock.
Some experimenters might prefer to power a Mini Quartz Clock Movement
by the 12 volt battery that is being tested (with voltage reduced to 1.5)
The clock and relay and circuit board could all be contained in one enclosure.
Joe Gores
rd2(at)dejazzd.com
PostPosted: Mon Feb 01, 2021 6:30 am    Post subject: Poor Man's Battery Tester Reply with quote
How about a (readily available) AC hour meter? Admittedly, it could give up to 1/10 (6 min) less reading.
Rumen
n233ee(at)gmail.com
PostPosted: Mon Feb 01, 2021 6:50 am    Post subject: Poor Man's Battery Tester Reply with quote
I wonder if something like this would be useful?
https://www.mpja.com/02-01-21.asp?r=326752&s=39
On Jan 31, 2021, at 10:20 PM, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com> wrote:
testers.
accurate.
excellent value.
out of that stuff?"
PostPosted: Mon Feb 01, 2021 6:56 am    Post subject: Poor Man's Battery Tester Reply with quote
Is it right that the clock only runs when the battery is charging ?
Charles
On 01/02/21 08:18 am, Jeff Luckey wrote:
-Jeff
On Sunday, January 31, 2021, 08:24:34 PM PST, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com> (nuckolls.bob(at)aeroelectric.com) wrote:
--> AeroElectric-List message posted by: Dick Tasker <dick(at)thetaskerfamily.com> (dick(at)thetaskerfamily.com)
  testers.
  accurate.
  excellent value.
  out of that stuff?"
rnjcurtis(at)charter.net
PostPosted: Mon Feb 01, 2021 7:04 am    Post subject: Poor Man's Battery Tester Reply with quote
Joe,
A mere 50 years, we all had one of these clocks on our bedside night stand. Walmart still sells them.
Roger
Sent: Monday, February 1, 2021 9:05 AM
Subject: Re: Poor Man's Battery Tester
Joe Gores
http://forums.matronics.com/viewtopic.php?p=500490#500490
<= Use the Matronics List Features Navigator to browse
PostPosted: Mon Feb 01, 2021 7:33 am    Post subject: Poor Man's Battery Tester Reply with quote
At 08:55 AM 2/1/2021, you wrote:
discharging
out of that stuff?"
PostPosted: Mon Feb 01, 2021 7:34 am    Post subject: Poor Man's Battery Tester Reply with quote
Absolutely. Good eye!
out of that stuff?"
PostPosted: Mon Feb 01, 2021 7:35 am    Post subject: Poor Man's Battery Tester Reply with quote
At 08:29 AM 2/1/2021, you wrote:
--> AeroElectric-List message posted by: rd2 <rd2(at)dejazzd.com>
Rumen
Sure . . . unless the meter is resetable to zero,
you would have to calculate the discharge time
but yes, as a timekeeping device it would be
a good candidate.
out of that stuff?"
PostPosted: Mon Feb 01, 2021 7:36 am    Post subject: Poor Man's Battery Tester Reply with quote
How do you start/stop the thing without it
going brain dead?
out of that stuff?"
Goto page 1, 2  Next
Page 1 of 2
