AdventureD
Posted: Fri Jan 15, 2021 7:53 pm Post subject: Antenna Ground Planes |
Here is a dumb question about ground planes. Does the ground plane serve to direct the signal to the antenna irrespective of whether the antenna is "connected" to the ground plane, or must the antenna itself be electrically connected to the ground plane?
I am asking because the tech says the best approach to the ground plane in my e-glass composite is conductive paint on the belly. what I am wondering is how, after the conductive paint is painted over, one ensures that the antenna is "grounded" to the conductive paint ground plane. I think it may be the case that the ground plane has nothing to do with "grounding" the antenna to the ground plane, but rather that the purpose of the ground plane is to absorb signal for the antenna located in the middle of it (whether or not the antenna "touches" the ground plane.
As you can see, I obviously don't know how antenna ground planes work.
Appreciate your help,
Dan
Posted: Fri Jan 15, 2021 8:33 pm Post subject: Re: Antenna Ground Planes |
The ground plane does not have to be connected to the aircraft ground.
But it does have to be connected to the coax shield at the antenna base.
I doubt very much that conductive paint will work. Test the paint with an ohmmeter.
Consider an internal antenna:
http://www.aeroelectric.com/articles/Antennas/Morris_Com_Loop_Antenna.pdf
There are other designs for internal antennas on fiberglass aircraft.
Bob's book has a chapter on antennas.
http://www.aeroelectric.com/Books/Connection/
_________________ Joe Gores |
bob.verwey(at)gmail.com Guest
Posted: Fri Jan 15, 2021 11:34 pm Post subject: Antenna Ground Planes |
Dan there are no dumb questions...even though i dont know the answer to your question...lol
On Sat, 16 Jan 2021, 06:05 AdventureD, <dobrien(at)microfoundations.com (dobrien(at)microfoundations.com)> wrote:
| Quote: | --> AeroElectric-List message posted by: "AdventureD" <dobrien(at)microfoundations.com (dobrien(at)microfoundations.com)>
Dan
http://forums.matronics.com/viewtopic.php?p=500260#500260
alec(at)alecmyers.com Guest
Posted: Sat Jan 16, 2021 4:10 am Post subject: Antenna Ground Planes |
A ground plane works the same way as a mirror: the boundary condition for the electric field at the surface of an infinite (or ground connected) ground plane is that no electric field component can exist parallel to the surface of the ground plane. To enforce this electric currents are induced in the ground plane to produce a cancelling field - equivalent to a reflected antenna mirrored in the plane. If the ground plane is small or not connected to the transmitter circuit then those currents are impeded to a greater or lesser extent.
The effectiveness of a ground plane is improved if it is electrically connected to the circuit that’s connected to the antenna so those currents flow more easily. But it will still have some effect even if it’s not.
The higher the frequency the more effective a floating ground plane will be: at light frequencies a smooth metal surface is an almost perfect ground plane (mirror) even when not electrically connected to anything else.
Bob - how did I do?
Dan
AdventureD
Posted: Sat Jan 16, 2021 9:00 am Post subject: Re: Antenna Ground Planes |
I think you’re saying that around an antenna will work to some degree even if it is not electrically connected to the antenna. If that is true, conductive paint will work to some degree even if sealed over by actual paint. To make it even better, should the inside of the hole drilled to accept the antenna be coated with the conductive paint so there is a connection between the ground plane and the antenna. From what you are saying, it appears that that would make the ground plane work even better.
Ceengland
Posted: Sat Jan 16, 2021 9:47 am Post subject: Antenna Ground Planes |
On Sat, Jan 16, 2021 at 11:10 AM AdventureD <dobrien(at)microfoundations.com>
_________________ Charlie |
Posted: Sat Jan 16, 2021 10:11 am Post subject: Antenna Ground Planes |
At 06:06 AM 1/16/2021, you wrote:
<snip>
<snip>
Bob - how did I do?
Very good!
At a hammer-n-tongs level I like to envision
ground planes from two perspectives. The common
terrestrial version utilizes what I would
call a 'resonant' ground plane.
The goal of a ground plane is to
provide a minimal loss (lowest practical
metallic resistance) non-radiating
conductor to concentrate radiation
energy in the vertical element.
Consider a vertical dipole antenna with
a feedline attached to the center. You
have two elements in the same plane
that share energy management tasks for
emitting and receiving energy.
Now, fold the bottom element 90 degrees
to horizontal. Intuitively, one can see
that this element is now in vigorous argument
with the vertical element for squirting
energy off into the ether.
Each element has a load impedance on the order
of 30 ohms. Suppose we added a second horizontal
element opposite the first. Now we have TWO
radiating elements with a combined load impedance
of 15 ohms . . . now we can calculate that
energy fed to the base will have a 15:30 division
ratio with most of energy going to the 'good
guy'.
Okay, let's add two more radials elements disposed
90 degrees from the first two. Now we have a
load impedance of 30/4 or 7.5 ohms for the
combination of bad guys . . . and 80% of the
energy at the end of the feedline goes to the
'good guy'. 4-radials is a practical place to
stop adding . . . the difference between 80
and 100% of energy going to the 'good guy' is
not observable in practice.
But we don't need to stop there. If you droop
the radials at about 45 degrees, you increase
the theoretical feed point impedance of 30
ohms (close but not quite 1:1 swr for 50
ohm feedline) the match is a bit better and
one of several potential losses in the system
is reduced. Drooping also reduces the radiation
angle of the antenna so as to focus more attention
at the horizon as opposed to the Andromeda
galaxy.
On the other hand, you can add an infinite number
of radials forming a solid disk. Now the theoretical
load impedance of the plane approaches zero
ohms . . . a good thing you can do to improve
performance.
Now, here comes those pesky machines known as
airplanes . . . with envelopes and structures
that are not very friendly for seeking an
optimal antenna installation.
In a plastic airplane, you can choose to go the
enhanced or optimized route for achieving a
suitable ground plane. At ADSB/XPNDR frequencies
the optimized route is pretty easy. The disk
is relatively small. At VHF frequencies, the disk
is unmanageably larger so optimization with
4 or more 'radials' becomes the technique of
choice.
The short answer is that mounting antennas
on the outside of a metal airplane offers
a perfectly satisfactory ground plane although
the infinite number of radials are not resonant.
No big deal. In a plastic airplane, the ground
plane needs to be fabricated and going the
resonant mode with either a disk (optimal)
or radials (enhanced) works good, last a long time.
The native conductive qualities of materials
in composite airplanes whether carbon-fiber,
paint or any spray on coatings don't even
begin to approach the much-desired quest
for close-to-zero-ohms qualities of the
optimized ground plane.
out of that stuff?"
216.74 KB |
11950 Time(s) |
121.1 KB |
11950 Time(s) |
283.95 KB |
11950 Time(s) |
Posted: Sat Jan 16, 2021 11:10 am Post subject: Re: Antenna Ground Planes |
| Quote: | | I think you’re saying that around an antenna will work to some degree even if it is not electrically connected to the antenna. If that is true, conductive paint will work to some degree even if sealed over by actual paint. To make it even better, should the inside of the hole drilled to accept the antenna be coated with the conductive paint so there is a connection between the ground plane and the antenna. From what you are saying, it appears that that would make the ground plane work even better. |
Nobody above said that conductive paint will work as an antenna ground plane
except the OP's misinformed tech. Yes, conductive paint does have some conductive properties.
It also has high resistance, too high to make an effective ground plane.
After installing the com antenna, check its SWR with a meter.
AdventureD
Posted: Sat Jan 16, 2021 5:05 pm Post subject: Re: Antenna Ground Planes |
| Quote: | | Nobody above said that conductive paint will work as an antenna ground plane except the OP's misinformed tech. Yes, conductive paint does have some conductive properties. It also has high resistance, too high to make an effective ground plane. After installing the com antenna, check its SWR with a meter. |
Funny thing is a bunch of Lancair guys believe (and say they have experienced) that conductive paint works.
Let's suppose it doesn't work. Does the existence of the conductive paint over e-glass do any harm when the antenna is put on the outside of the plane? If one put 4 or 6 or 8 copper strips radiating out from the coax attach point on the inside of the eglass plane, that would still work as well as if the conductive paint weren't there, would it not? On the other hand, if I wanted to put a strikefinder antenna on the bottom of the inside of the fuselage, I assume that conductive paint could interfere with the signal to the strikefinder antenna on the inside of the plane, yes? In that sense, would the conductive paint actually do harm? [/quote]
Posted: Sat Jan 16, 2021 6:37 pm Post subject: Re: Antenna Ground Planes |
An antenna will work without a ground plane. But how well? The opinion of others is subjective.
The best way to know how well an antenna works is with a SWR meter.
Conductive paint will not do any harm at all to the performance of an exterior antenna.
It will not do much good either. Use whatever paint looks good.
Use a ground plane consisting of 4 wires or copper strips inside of the fuselage.
I am not knowledgeable about a strikefinder.
Posted: Sun Jan 17, 2021 12:34 pm Post subject: Antenna Ground Planes |
At 08:37 PM 1/16/2021, you wrote:
The opinion of others is subjective. |
Antenna's come in a variety of flavors that
have different demands for optimal performance.
Some antennas do not require nor do they
have provisions for including a ground plane.
Such antennas include dipole glideslope, vor and
Archer transponder antennas for composite aircraft.
Loran are e-field 'probes' of exceedingly small
length/frequency ratio . . . like the AM radio antenna
for automobiles.
Bottom line calls for following the manufacturers
recommendations closely . . . just 'cause it's
a radio-gizmo on the far end of a piece of
coax does not automatically give it broad
commonality with other antennas.
| Quote: | | The best way to know how well an antenna works is with a SWR meter. |
Yeah . . . kind of. SWR is a measurement
of the complex impedance peeking into the feed point
of an antenna . . . or looking at an antenna at
the other end of a feedline. It's the first
place to start when you looking for a gross
failure of a previously working antenna.
With respect to performance, the qualities that
affect radiation efficiency and pattern have
an equal if not greater effect on performance
and cannot be quantified by evaluating impedance
of the power feed path (SWR).
These qualities need analysis by computer prediction
at least . . . or at best, measurements on the
antenna test range. Fortunately, our antenna
needs are simple and most designs and installations
have been demonstrated for decades. When in doubt,
check with someone who's been-there-done-that.
| Quote: | Conductive paint will not do any harm at all to the performance of an exterior antenna.
Use a ground plane consisting of 4 wires or copper strips inside of the fuselage. |
Exactly. Greg Richter and I had some discussion
about spray-on conductors about 17 years ago.
See page 24 of https://tinyurl.com/y6ejr33s
I worked a custom black box design for LearJet
that was housed in a vacuum formed, plastic
housing. We THOUGHT we'd mitigate a slight
sensitivity to radiated RF by spraying the
inside surface of the cover. That idea was
one of several in my career that blew current
accumulation of "ataboys" away and delayed
delivery by a month or so.
The spray on coating had only the slightest
benefit to the shielding task. Retooling
the enclosure in metal was out of the question.
Had to beef up robustness of the electronics.
| Quote: | | I am not knowledgeable about a strikefinder. |
StrikeFinder antennas are H-field receptors but they
do perform best working against a ground plane. In this
case, the ground plane carries no RF current but
acts more like the 'mirror' alluded to earlier in this
thread. The conductive plane under a StrikeFinder
antenna serves to smooth the azimuth variations in
reception pattern.
out of that stuff?"
Posted: Sun Jan 17, 2021 12:51 pm Post subject: Re: Antenna Ground Planes |
AdventureD,
Read these two threads about the necessity of a ground plane:
http://forums.matronics.com/viewtopic.php?t=16775765
http://forums.matronics.com/viewtopic.php?t=16775667
My friend was in the same situation as you are.
Someone told him that their radio worked fine without a ground plane in the tail of their Kitfox.
And it probably did as far as the pilot could tell. He probably did not try transmitting a long distance.
And the pilot was not aware of the reflected power which was not doing his radio any good.
The SWR in my friend's Kitfox was 3.8 without a ground plane. After installing another antenna in
a better location and installing ground plane wires, the SWR improved to an average of 1.57
AdventureD
Posted: Fri Jan 22, 2021 6:30 pm Post subject: Re: Antenna Ground Planes |
Thank you Bob, Joe, all, for all this advice. Happy and safe flying, Dan
