Europa pitot tube piping and connections
kjburns(at)btinternet.com
PostPosted: Tue Jan 12, 2021 4:16 pm    Post subject: Europa pitot tube piping and connections Reply with quote
Chris,
Check your static probe under the wing still has the black “plug” in place , can get knocked of easily, result is ineffective asi ... ( you need a pressure differential and this effectively cancels it out ) ..symptom is taxi test that shows extreme asi lag ..
disconnecting static line restores asi ... ( removes the balancing air stream ) ...
Slight air leaks in asi feed do not create the same ( massive ) effect.
The actual flow when you try to blow through is also relatively high resistance in normal operation .
Kevin Burns
Sent from my iPad
On 7 Dec 2020, at 20:36, Chris Callicott <c.callicott1(at)btinternet.com> wrote:
Evening All, I am preparing a UK built (2007) Europa XS tri-gear which I purchased last year for a permit check flight. The aircraft has not flown for 7 years. I believe I have a leak in the pitot tube system. Pitot and static lines passing through the fuselage to the instrument panel seem to be made of semi-opaque hard plastic tubing approx 7.5mm OD and use 'push-fit' connectors. An adaptor connects the push-fit connector to standard ?6mm flexible clear tubing to the flight instruments.
Is this a typical arrangement in Europas and where would I source the larger tubing and push-fit connectors? Many thanks, Chris
http://forums.matronics.com/viewtopic.php?p=499625#499625
PostPosted: Tue Jan 12, 2021 4:38 pm    Post subject: Europa pitot tube piping and connections Reply with quote
Chris,
Kevin Burns
Sent from my iPad
 Filesize:  392.38 KB
 Viewed:  3255 Time(s)
Chris Callicott
PostPosted: Tue Mar 30, 2021 4:55 am    Post subject: Re: Europa pitot tube piping and connections Reply with quote
A very belated thanks for your reply Kevin.
Problem now sorted.
Test flight very soon!
Chris
