Any ideas where to get electric motor brushes?
rparigoris
PostPosted: Sun Jan 03, 2021 8:43 pm    Post subject: Any ideas where to get electric motor brushes? Reply with quote
Hi Group
I need some brushes for the exciter on my Monarch EE lathe. Was making some aeroplane parts and it quit.
Sizes needed:
3/8" x 3/8" and worn out length is 1.060", it has a shunt and terminal (need 4, will buy eight)
1/2" x 1/4" and worn out length is .495", it has a shunt and terminal (need 2, will buy four)
Any ideas where I can purchase from?
Ron P.
JB Soar
PostPosted: Mon Jan 04, 2021 9:38 am    Post subject: Any ideas where to get electric motor brushes? Reply with quote
McMaster-Carr has a nice selection of brushes available.
On Mon, Jan 4, 2021 at 11:29 AM Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
At 10:43 PM 1/3/2021, you wrote:
--> AeroElectric-List message posted by: "rparigoris" <rparigor(at)hotmail.com (rparigor(at)hotmail.com)>
Hi Group
Sizes needed:
3/8" x 3/8" and worn out length is 1.060", it has a shunt and terminal (need 4, will buy Cool
1/2" x 1/4" and worn out length is .495", it has a shunt and terminal (need 2, will buy 4)
   About 40 years ago I had ready access to
   a stockroom of brushes that would probably
   have yielded something that would cut-down
   to suitable profiles. Alas, no more.
   There are listings on eBay (40,000+) that
   might produce useful candidates but most
   come out of China . . . so it depends on your
   urgency.
   I've cut down many a brush on a mill. In
   your case, avoid brushes destined for use
   in h9gh current, intermittent motors like
   starter and winch motors.
   There are hundreds of 'recipes' for brush
   make-up . . . unless you order spares from
   the original manufacturer of you motor,
   finding an exact replacement for size and
   content is problematic.
   However, for anything less then high duty
   cycle applications, optimization of recipe
   will have little significance on service
   life of your substitution.
   You might research DC motor overhaul
   services on the 'net. They may have
   spares suitable for modification if not
   okay as-is. Keep your old springs if they're
   not obviously compromised.
   1" is pretty long for a worn brush . . . 1/2"
   values are quite common. Is that in a 4-pole
   motor? What are the nameplate sizes for these
   motors?
  out of that stuff?"
Ceengland
PostPosted: Mon Jan 04, 2021 9:54 am    Post subject: Any ideas where to get electric motor brushes? Reply with quote
Have you tried Monarch?
On Mon, Jan 4, 2021 at 11:43 AM John B <jbsoar(at)gmail.com (jbsoar(at)gmail.com)> wrote:
Hi Group
Sizes needed:
   urgency.
   motors?
  out of that stuff?"
ventura(at)brandeis.edu
PostPosted: Mon Jan 04, 2021 10:25 am    Post subject: Any ideas where to get electric motor brushes? Reply with quote
There is a small one man shop near work who's main business for the last 35 years has been  repairing and rebuilding electric motors, generators, and alternators.  Whenever I need brushes, I go to him.  If it is automotive, he looks it up and sells me what I need.  If it is not automotive, I bring him the brushes, and/or the device and he has always been able to come up with a replacement from his stocks.   He told me that brushes come in different hardnesses.  Hard brushes will last a long time, but wear the slip ring or commutator faster, so you may be in for a ring turning or replacement eventually.  Softer brushes don't last as long, and need replacement more often, but you will get more ring life out of your device with them.  I usually go softer, since it is much easier to replace several sets of brushes than dismantle a motor and turn or replace the commutator once.
My local Home depot also carries a selection of brushes, but you may have to surreptitiously scratch them to get an idea of their hardness. The salesmen have no idea.  Some large hardware stores also carry a selection of brushes.  If they don't have exactly what you need, they can be filed or milled to fit.
--Joel
On Sun, Jan 3, 2021 at 11:52 PM rparigoris <rparigor(at)hotmail.com (rparigor(at)hotmail.com)> wrote:
Hi Group
Sizes needed:
Ron P.
http://forums.matronics.com/viewtopic.php?p=499971#499971
