Where to buy Gear leg Airfoils?
nickc(at)mtaonline.net
PostPosted: Wed Dec 02, 2020 3:47 pm    Post subject: Where to buy Gear leg Airfoils? Reply with quote
Hello Kolbrers,
I am wondering if one of you knows where I can buy plastic Airfoils for my gears legs. I bought my kit “third hand” and I have a lot of extra tubing and other odds and ends that seem to have not relation to the kit. I have enough Airfoil for my wing struts, but the pieces for my gear legs are 10’’ short. Aircraft Spruce only seems to have Aluminum Airfoils available.
Thanks for the help…
Nick Cassara
Palmer Alaska
N607AK almost finished
Pfatchantz(at)protonmail.
PostPosted: Wed Dec 02, 2020 4:28 pm    Post subject: Where to buy Gear leg Airfoils? Reply with quote
Dennis Carley...in Fla...Advertises on the Kolb postings at Barnstormers...
http://www.uflyit.com/streamline_fairings.htm
Herb
Sent with ProtonMail Secure Email.
‐‐‐‐‐‐‐ Original Message ‐‐‐‐‐‐‐
On Wednesday, December 2, 2020 5:45 PM, Nick Cassara <nickc(at)mtaonline.net> wrote:
Hello Kolbrers,
Nick Cassara
Palmer Alaska
Ceengland
PostPosted: Wed Dec 02, 2020 5:02 pm    Post subject: Where to buy Gear leg Airfoils? Reply with quote
On 12/2/2020 5:45 PM, Nick Cassara wrote:
Hello Kolbrers,
Nick Cassara
Palmer Alaska
I used to have a link, but can't find it now. How about:
https://dragonplate.com/streamlined-symmetrical-airfoil-carbon-fiber-tube-237-id-x-095-id-x-24?gclid=Cj0KCQiAk53-BRD0ARIsAJuNhpuI11I0O0Clqwo5Xw3OeOOgrvXt54TmodeWnsMcfpC_1FLm5BoL7PsaAvtKEALw_wcB
If those aren't big enough, you could try Van's Aircraft; they have a
couple of different fiberglass versions, and a wrapped aluminum version:
https://shop.vansaircraft.com/cgi-bin/shop.cgi?ident=1606957087-166-687&browse=misc&product=leg-fair
Ceengland
PostPosted: Wed Dec 02, 2020 5:04 pm    Post subject: Where to buy Gear leg Airfoils? Reply with quote
> Hello Kolbrers,
> Nick Cassara
> Palmer Alaska
Wups; just read a bit farther down my google search.
https://www.uflyit.com/streamline_fairings.htm
Ceengland
PostPosted: Wed Dec 02, 2020 5:09 pm    Post subject: Where to buy Gear leg Airfoils? Reply with quote
>> Hello Kolbrers,
>> Nick Cassara
>> Palmer Alaska
> Charlie
And:
http://www.ultralightnews.ca/streamlinedfairings/1.html
neilsenrm(at)gmail.com
PostPosted: Thu Dec 03, 2020 8:10 am    Post subject: Where to buy Gear leg Airfoils? Reply with quote
Nick
I considered the air foil plastic but did the following. I used an insulating foam from a can called Great Stuff. I sprayed the foam on the back side of the gear legs and let it set up. Then added additional foam to get the basic shape. When it dried I took a small hand saw to it to get it closer to the shape I wanted. Then I block sanded to a more refined shape. Don't be afraid to add more foam as needed but be careful to cover areas that you don't want it because it sticks like crazy. Wear disposable gloves. You can do SOME shaping after it expands and skins over. Next I mixed up some epoxy with microballoons to fill all the holes and imperfections. Then a final thin epoxy coat for a paintable finish.  My gear leggs are the Kolb solid spring steel legs which flex quite a bit and these gear leg fairings have survived app. 15 years so far.
Again worth what you paid for it.
Rick Neilsen
Redrive VW Powered MKIIC
On Wed, Dec 2, 2020 at 6:50 PM Nick Cassara <nickc(at)mtaonline.net (nickc(at)mtaonline.net)> wrote:
--> Kolb-List message posted by: Nick Cassara <nickc(at)mtaonline.net (nickc(at)mtaonline.net)>
Hello Kolbrers,
Nick Cassara
Palmer Alaska
byoungplumbing(at)gmail.c
PostPosted: Tue Dec 08, 2020 4:05 pm    Post subject: Where to buy Gear leg Airfoils? Reply with quote
I found these if anyone is still looking.
 Filesize:  130.58 KB
 Viewed:  25964 Time(s)
 Filesize:  380.79 KB
