Switch Question
farmrjohn
PostPosted: Tue Nov 24, 2020 8:33 am    Post subject: Switch Question Reply with quote
My master switch is specified as an AN 3023-2. I have been unable to find any documentation on just what that is, other than some type of DPST switch. Is there a source for decoding the AN switch specifications?
PostPosted: Tue Nov 24, 2020 1:29 pm    Post subject: Re: Switch Question Reply with quote
That switch is available for $30 at Univair
https://www.univair.com/electrical-lighting/view-all/an3023-2-piper-switch/
Any snap action switch will work. The master contactor draws less than an amp.
Be sure to put a diode across the contactor coil to protect the switch from arcing.
The banded end of the diode connects to positive.
Joe Gores
PostPosted: Tue Nov 24, 2020 1:46 pm    Post subject: Switch Question Reply with quote
At 10:33 AM 11/24/2020, you wrote:
--> AeroElectric-List message posted by: "farmrjohn" <faithvineyard(at)yahoo.com>
That is a vintage switch dating back to the 40's or earlier.
It's reminiscent of the master switch in a Piper TriPacer
I took dual in wwwaayyy back when. BEEFY switch, no battery
master relay.
They're still available as you can see here . . .
https://tinyurl.com/y57x62bp
What's your application?
out of that stuff?"
PostPosted: Tue Nov 24, 2020 4:07 pm    Post subject: Switch Question Reply with quote
master relay.
P.S. I have confirmed that this switch was used on
Univair (ERCO) aircraft as the primary current
carrying device for ship's power. This IS a high
current switch . . . probably rated at 30A or more.
If that's how it's used in your application, suggest
you add a battery master contactor thus allowing
substitution of a friendlier toggle switch.
out of that stuff?"
farmrjohn
PostPosted: Tue Nov 24, 2020 7:47 pm    Post subject: Re: Switch Question Reply with quote
My airplane is an Alon Aircoupe that Univair now has the TCSD for. It does not have a battery master contactor, and the STC available to add one does not include the Alons due to a change in the battery box and location. I am working with my A&P/IA on a possible field approval, along with a lithium battery installation. I was curious about the AN switch and what its characteristics are.
PostPosted: Wed Nov 25, 2020 8:05 am    Post subject: Switch Question Reply with quote
I used to have some Cuttler-Hammer data from that
era but I'm unable to access it. But we can be
sure that this switch is not off your grandpa's
yard tractor. It's a beefy device used on many
small aircraft of the era as THE battery master.
Getting a field approval for battery and contactor
upgrade shouldn't be a big deal. It's a rudimentary
but significant performance upgrade.
out of that stuff?"
farmrjohn
PostPosted: Wed Nov 25, 2020 7:25 pm    Post subject: Re: Switch Question Reply with quote
out of that stuff?"
Totally agree, it's just a matter of finding someone at the local FSDO that has the same point of view. John
PostPosted: Fri Nov 27, 2020 8:33 am    Post subject: Switch Question Reply with quote
Are there any Type Clubs for your airplane?
It might be possible to got a copy of an
already approved 337 for doing this job.
Using that as foundation for your new
endeavor will go a long way toward assuaging
timidity on the part of individuals with
little or no familiarity with vintage aircraft.
Use the battery contactor installation on any later
version of that aircraft to create a narrative/
photo essay on a proposed modification to your
airplane.
Lacking that, find an STC for ANY such modification
to a vintage aircraft. Use it as a pattern to
create your own documentation.
Don't ASK 'em how to do it, TELL them how you're
going to do it on a foundation of prior
art.
When and if you're successful, preserve copies
of your approved paperwork and share with interested
owners. You can become a repository for a
knowledge-nugget of tribal knowledge.
out of that stuff?"
farmrjohn
PostPosted: Thu Dec 14, 2023 4:14 pm    Post subject: Re: Switch Question Reply with quote
Reviving an old thread, when the original generator was swapped out for an alternator they utilized only one pole of the two pole switch to connect the batter to the bus, leaving the other side unused. Would it be possible to utilize the unused poles to control a master contractor leaving the heavy wiring from the batter to the switch in place? That way when the switch was closed it would energize the contractor and allow the connection to the bus, and provide a backup method of disconnecting the battery should the contractor fail closed for any reason. This is in anticipation of pursuing a field approval for a contacor. Thanks, John
--> AeroElectric-List message posted by: "farmrjohn" <faithvineyard>
master relay.
out of that stuff?"
PostPosted: Thu Dec 14, 2023 4:29 pm    Post subject: Re: Switch Question Reply with quote
Contactors are unlikely to fail closed. I would remove existing cables
between the battery and main power bus. Then install a contactor
between the battery and bus.
Joe Gores
PostPosted: Fri Dec 15, 2023 9:05 am    Post subject: Switch Question Reply with quote
for an alternator they utilizedg only one pole of the two pole
Have you engaged an IA to assist in fabricating
an Form 337 likely to be summarily approved?
Find the maintenance manual drawings for the first
airplane of the series that replaced the
battery switch with a contactor. This is 'approved
data'. Duplicate the architecture of that
drawing in support of your 337 goes along way
to getting it approved.
Your risk of contactor-failure-by-sticking-
closed is more remote now than it was 70
years ago. I've never heard of a 'back up
battery disconnect' in any aircraft.
Imitation is a demonstrated form of flattery . . .
it's also a demonstrated prophylactic
against bureaucratic disapproval. What
airplane are we talking about? I may
have the drawings you need in my library.
(o o)
===========o00o=(_)=o00o=========
< Go ahead, make my day . . . >
< show me where I'm wrong. >
In the interest of creative evolution
of the-best-we-know-how-to-do based
on physics and good practice.
PostPosted: Fri Dec 15, 2023 9:37 am    Post subject: Re: Switch Question Reply with quote
His airplane is an Alon Aircoupe that Univair now has the TCSD for.
Joe Gores
PostPosted: Fri Dec 15, 2023 10:31 am    Post subject: Switch Question Reply with quote
Joe Gores
Okay, thanks Joe.
It' been 20 years since I was last involved in any
'certifiable' field work on a TC aircraft so I dug
back into some old files.
There were individuals certificated by the FAA
to accomplish various tasks. There are also
various levels of documentation needed to support
the project implementation.
As I recall, there are 'repairs' and 'alterations.'
They're also divided into 'major' and 'minor'
classifications. Minor alternations are those
that do not change performance of the airplane.
This generally defined as less than 1 pound
difference in empty weight of the aircraft
(hence no change to w/b). No changes needed
to the pilot's operating handbook. No alterations
to any structural component of the airframe
(like holes thru a spar).
The proposed swap from manual battery switch
to battery contactor could certainly fall in
the minor category (unless you want to drill
the spar carrythru to mount the contactor!)
Check with your local FAA certified talent
but waaayyy back when, I believe such a change
could be accomplished with a log book entry
by an appropriately qualified practitioner.
No 337 necessary.
(o o)
farmrjohn
PostPosted: Fri Dec 15, 2023 12:49 pm    Post subject: Re: Switch Question Reply with quote
Here is the original wiring diagram from the Alon maintenance manual (if I successfully added the attachment). The wiring has changed with the addition of an alternator in place of a battery. The circuit for field "F" on the regulator now comes via the alternator rather than the top pole of the switch as depicted.
Looking at the current definition for minor alteration the question is does the addition of a contractor constitute a change to the basic design of the system. My IA and myself don't think so but I'm a bit concerned looking forward to a pre-sale inspection and the buyer's inspector thinking otherwise. A 337 field approval should eliminate any doubt in that case. John
Aircoupe Electrical System.pdf
 Filename:  Aircoupe Electrical System.pdf
 Filesize:  1.12 MB
 Downloaded:  783 Time(s)
PostPosted: Fri Dec 15, 2023 4:03 pm    Post subject: Switch Question Reply with quote
That's an architecture 'cartoon' common to most
pilot's operating handbook for light aircraft.
Drew up lots of them at Cessna. 'Approved data'
would be from any 'hammer-n-tongs' document.
At Cessna, our factory wirebook drawings were
published in the maintenance manuals.
Aircraft of this era may not have enjoyed this
kind of documentation. I only have first hand
knowledge of Beech, Cessna and Lear . . . places
I've worked. That airplane may not ever
have been graced with a factory battery
contactor installation. It just means you don't
have an 'approved' factory document . . . doesn't
mean the drawing you attach to your 337 would
not be approved. An alternator swap would
always require a 337; it changes
weight and balance and might be need to be
tested for adequate cooling at best angle
of climb (depending on mood of the approving
authority).
Swapping a switch for a contactor is zero
risk and doesn't impact performance, w/b or
operating instructions i.e. MINOR . . .
no change of functionality.
You're asking 'hair dressers' about 'heart
surgery'. The authority resides with the
individual who signs off the installation.
If uncertain, that individual should/would
consult with the local FSDO.
A 337 adds to the FSDO workload . . . the
gotta file the thing. Have your IA check
it out with them . . . THEY are the
'surgeons'.
(o o)
