Faston Amp Rating
rparigoris
PostPosted: Mon Nov 16, 2020 1:50 pm    Post subject: Faston Amp Rating Reply with quote
Hi Group At 14.4 volts, what's the maximum continuous amperage rating for Red, Blue and Yellow 1/4" Faston Female connectors? Thx. Ron P.
user9253
PostPosted: Mon Nov 16, 2020 7:28 pm    Post subject: Re: Faston Amp Rating Reply with quote
I expect that the ampacity of a Faston is equal to that of the
largest wire size that will fit into the barrel of the Faston.
Joe Gores
johnbright
PostPosted: Tue Nov 17, 2020 8:08 am    Post subject: Re: Faston Amp Rating Reply with quote
Wikipedia has an article.
https://en.wikipedia.org/wiki/FASTON_terminal
John Bright, RV-6A, at FWF, O-360
N1921R links
rparigoris
PostPosted: Wed Nov 18, 2020 10:59 pm    Post subject: Re: Faston Amp Rating Reply with quote
Hi Group Thanks for reply. FWIW I did a quick test with a #12 wire and 1/4" Faston drawing 20 amps. I installed and wiggled it back and forth a bit (made connection looser) and after a few minutes connection was getting a little warm. I compressed with pliers and tried it at 30 amps and no significant warming. Tension is critical to achieve best results. Ron P.
