bobnoffs
Joined: 04 Jul 2012 Posts: 137 Location: northern wi.
Posted: Tue Nov 17, 2020 11:56 am Post subject: heat probe |
i am looking for a way to measure temp. of a gearbox from the outside [no threaded holes]. my eis already has a lead for a resistive type 1/8npt oil temp probe. there must be flat, glue on probes available but i drew a blank with mcmaster carr and have no idea where to look.
thanks, bob noffs
rv8iator
Posted: Tue Nov 17, 2020 12:50 pm Post subject: heat probe |
Snip...
Q: i am looking for a way to measure temp. of a gearbox from the outside [no threaded holes].
A: Thermocouple or thermistor ? Both are readily available. Thermocouples are of different types for specific temp ranges. They output a voltage proportional to the temperature at the junction.
Thermistors are resistors with a linear temp/resistance coefficient within a given range of temperature
From Wikipedia
Type E[edit]
Type E (chromel–constantan) has a high output (68 µV/°C), which makes it well suited to cryogenic use. Additionally, it is non-magnetic. Wide range is −50 °C to +740 °C and narrow range is −110 °C to +140 °C.Type J[edit]
Type J (iron–constantan) has a more restricted range (−40 °C to +750 °C) than type K but higher sensitivity of about 50 µV/°C.[2] The Curie point of the iron (770 °C)[9] causes a smooth change in the characteristic, which determines the upper temperature limit. Note, the European/German Type L is a variant of the type J, with a different specification for the EMF output (reference DIN 43712:1985-01[10]).Type K[edit]
Type K (chromel–alumel) is the most common general-purpose thermocouple with a sensitivity of approximately 41 µV/°C.[11] It is inexpensive, and a wide variety of probes are available in its −200 °C to +1350 °C (−330 °F to +2460 °F) range.
https://en.wikipedia.org/wiki/Thermocouple
A thermistor is a resistance thermometer, or a resistor whose resistance is dependent on temperature. The term is a combination of “thermal” and “resistor”. It is made of metallic oxides, pressed into a bead, disk, or cylindrical shape and then encapsulated with an impermeable material such as epoxy or glass. Much less mechanically robust than a thermocouple.
https://en.wikipedia.org/wiki/Thermistor
...chris
RV-8
On Tue, Nov 17, 2020 at 12:09 PM bobnoffs <icubob(at)gmail.com (icubob(at)gmail.com)> wrote:
| Quote: | --> AeroElectric-List message posted by: "bobnoffs" <icubob(at)gmail.com (icubob(at)gmail.com)>
thanks, bob noffs
http://forums.matronics.com/viewtopic.php?p=499409#499409
_________________ C. Stone (RV8iator) |
Ceengland
Posted: Tue Nov 17, 2020 1:07 pm Post subject: heat probe |
On Tue, Nov 17, 2020 at 2:09 PM bobnoffs <icubob(at)gmail.com (icubob(at)gmail.com)> wrote:
thanks, bob noffs
If I had the proper 1/8npt probe on hand, I'd seriously consider just threading a small block of aluminum with a 1/8npt tap, screwing the probe into the block, and securing it with a couple of hose clamps if the location lends itself to that, or clean the location & glue the block to the gearbox with hi-temp epoxy (or RTV) if the hose clamps aren't feasible. You can 'insulate' the adapter block with some silicone hose scrap, or just cover it with RTV. The interior will always be a bit hotter than the probe indicates, but that's the penalty for not having direct contact with the lube in the box.
Virus-free. www.avast.com [url=#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2][/url]
_________________ Charlie |
john(at)tipton.me.uk Guest
Posted: Wed Nov 18, 2020 1:18 am Post subject: heat probe |
When my friend pre flights his R22 helicopter he has to check various little stuck on ‘heat spot indicators’, would these be of any help as I presume you only want to know if the temperature is hotter than it should be ~
----x--O--x----
| Quote: | On 17 Nov 2020, at 9:22 pm, Charlie England <ceengland7(at)gmail.com> wrote:
thanks, bob noffs
bobnoffs
Posted: Wed Nov 18, 2020 4:30 am Post subject: Re: heat probe |
i really need to know the temp as the gearbox is lubed by engine oil. temp will be relative to engine oil temp
bob noffs
kjashton(at)vnet.net Guest
Posted: Wed Nov 18, 2020 5:23 am Post subject: heat probe |
I would think a cheap sparkplug CHT thermocouple tightly bolted to the gearbox and a CHT gauge would do it. It is also pretty easy to make a bayonet probe that could be screwed into your NPT hole. This will give you some links https://www.canardzone.com/forums/topic/33499-edm-sparkplug-gaskets-high-temps/?do=findComment&comment=63661
If you only need 6-8 feet of CHT wire, send PM-me your address and I’ll send you some. You just twist the ends together to get a CHT probe
-Kent
Ceengland
Posted: Wed Nov 18, 2020 6:09 am Post subject: heat probe |
On Wed, Nov 18, 2020 at 6:36 AM bobnoffs <icubob(at)gmail.com (icubob(at)gmail.com)> wrote:
bob noffs
| Knowing that makes the solution a lot simpler; I was working on the assumption that you couldn't tap the lube reservoir. If it's pressure-lubed by engine oil, just use a return line fitting in the case that's tapped 1/8npt for the sensor. You can buy them already drilled & tapped, or drill & tap one yourself. Attached is an image of one I drilled/tapped, with the 1st 1/8npt fitting that was handy. If the return line is a -4, then use a T fitting with the sensor tapped into one leg of the T. (Complete info is helpful to help find solutions.)
That method will tell you the oil temp *after* the gearbox heats it up. Be sure of the mfgr's specs; if they spec oil *inlet* temp (most common for engine oil temp specs), then you'll scare yourself unnecessarily. Ideally, I'd want both inlet and outlet temps, so I could see temp delta through the box. If you only have one sensor input available on the monitor, you could achieve that with a simple double throw switch in the sensor lines.
If you don't like those ideas, you could always tap the drain plug itself for the sensor (if it has one).
Hope that's useful,
191.3 KB |
17052 Time(s) |
bobnoffs
Posted: Wed Nov 18, 2020 6:21 pm Post subject: Re: heat probe |
thanks for all the ideas.
my gearbox has a drain line from the bottom of the box to the oil sump. engine oil is fed in the top of the box. my plan it to put a tee in the drainline and a temp. sender in the tee. i think with this setup i can watch for any changes in gearbox temps.
bob noffs
yellowduckduo(at)gmail.co Guest
Posted: Wed Nov 18, 2020 8:17 pm Post subject: heat probe |
After many years of monitoring a couple of aftermarket psru's I found
that temperature and real time vibration monitoring was of minimal use.
Filter residue told the story but it might be many hours between oil and
filter changes. A magnet that can easily be checked definitely saved my
bacon though. One was In a brass T fitting such as you describe for a
temperature sensor. Even better is a magnetic chip detector with a
cockpit warning light if there are significant concerns.
Ken
On 18/11/2020 9:21 PM, bobnoffs wrote:
bob noffs
http://forums.matronics.com/viewtopic.php?p=499427#499427
bobnoffs
Posted: Thu Nov 19, 2020 3:43 am Post subject: Re: heat probe |
the chip detector sounds like a much more positive way to go than a magnetic plug. i will look into that too. hopefully there are industrial ones that don't have the faa's million dollar stamp of approval. thanks.
bob noffs
glastar(at)gmx.net Guest
Posted: Thu Nov 19, 2020 4:41 am Post subject: heat probe |
Hi Bob,
a friend of mine had very positive results with EATON,Part No: B3225C,
5/8" x 18 UNF
He did add this on a Rotax where he had a catastrophic engine failure
(and no metal in the oil filter).
Thttp://www.experimental.ch/wp-content/uploads/2013/05/Viktorwings_Chip-Detector-%C3%96l-Schnellablass.pdf
<http://www.experimental.ch/wp-content/uploads/2013/05/Viktorwings_Chip-Detector-%C3%96l-Schnellablass.pdf>
On 19.11.2020 12:43, bobnoffs wrote:
bob noffs
http://forums.matronics.com/viewtopic.php?p=499431#499431
Posted: Thu Nov 19, 2020 5:38 am Post subject: heat probe |
At 01:56 PM 11/17/2020, you wrote:
| Quote: | --> AeroElectric-List message posted by: "bobnoffs" <icubob(at)gmail.com>
thanks, bob noffs |
That is a problem. Legacy pipe-thread temperatures
sensors are of the thermistor type . . . which is
CORE to the problem. Thermistors come in a constellation
of characteristics for temperature vs. resistance and
a host of non-linear curves.
Does your eis installation manual call out a
suggested part nu
out of that stuff?"
bobnoffs
Posted: Thu Nov 19, 2020 11:36 am Post subject: Re: heat probe |
i have looked into the temp sender and it appears to be a resistive single wire. i think these are very common. a cross reference # took me to one used in a cont. 0-200. sold by dynon so i think i have got that part. i was hoping for a flat, platelike sender compatable with my eis. i can make do with the 1/8'' npt type sender.
bob noffs
bobnoffs
Posted: Thu Nov 19, 2020 11:45 am Post subject: Re: heat probe |
i would be interested in reading about the chip detecter but the link didn't work. i can not find that part number.
bob
johnbright
Joined: 14 Dec 2011 Posts: 167 Location: Newport News, VA
Posted: Thu Nov 19, 2020 12:38 pm Post subject: Re: heat probe |
| bobnoffs wrote: | i would be interested in reading about the chip detecter but the link didn't work. i can not find that part number.
bob |
It had an errant T in front of it. Here it is without the T.
_________________ John Bright, RV-6A
Single battery, wound-field alternator on main bus, MZ-30 PM generator on engine/essential bus.
N1921R links |
bobnoffs
Posted: Fri Nov 20, 2020 3:31 am Post subject: Re: heat probe |
the chip detecter looks like a good idea but i don't have a place to mount it. it is way over my head to drill and tap a hole in the gearbox case.
maybe down the road it would be a job for someone competent when it is inspected.
bob
Posted: Fri Nov 20, 2020 7:54 am Post subject: heat probe |
Adding a pipe-thread hole in the casting is
probably the easiest of tasks. Straight thread
taps are not 'self aligning' and it's too easy
to have your tap start cutting on a slightly
axially mis-aligned orientation. Pipe threads are tapered
and they start cutting with a minimum of attention
to position and force . . . you can concentrate
on axial alignment and the tap takes care of the
rest.
This thread begs some questions:
Is this a flooded, pressurize gearbox?
Fed with engine oil?
Are there any instances of field failures due
to degraded gearing?
Were these judged to be conditions long-in-the-
making that MIGHT have telegraphed impending
failure by increased temperature, metal
chips in oil, noise, etc?
What are the recommendations of the manufacturer
for monitoring gear box condition?
If it is judged that addition of any sensors
by penetrating the gearbox case is a good thing
to do, where is the best place for locating
those sensors. There will be optimum locations
after consideration of structural issues, temperature
gradients, optimal chip-congregation points, etc.
If this box is lubricated with circulated engine
oil, then I'm skeptical of the value of adding
any single temperature sensor. You've got hot
oil coming in. You'll want to know TEMPERATURE
RISE attributable to gear box wear.
What is the experience of the user community
with respect to this topic? It naturally seems
like a cool thing to add such sensors but
before you venture forth, it would pay to know
if such sensors are KNOWN to be effective along
with protocols for interpreting what a temperature
gage is telling you.
I seem to recall a similar discussion many moons
ago on another forum . . . perhaps Compuserv AVSIG
. . . wherein a reader suggested that the best
harbinger of impending gearbox doom was a dial
indicator he could firmly affix to some part
of the airplane to measure backlash in the gearing.
The observed number would rise noticeably long
before the gearbox trashed.
out of that stuff?"
37.39 KB |
16929 Time(s) |
Bill Allen
Posted: Fri Nov 20, 2020 9:21 am Post subject: heat probe |
Most chip detectors fit where the drain plug goes. You can get them from
salvage yards where they break helicopters. That’s where I got mine
Posted: Fri Nov 20, 2020 10:00 am Post subject: heat probe |
A few folks have made their own chip detector. A pair of metal probes
with a magnet epoxied into a pipe plug. Where possible expose it to oil
flowing in a line going to a filter. It's important to catch bearing
failures before they progress too far and periodic oil and filter
changes may not be frequent enough.
Ken
On 20/11/2020 11:47 AM, Bill Allen wrote:
| Quote: | Most chip detectors fit where the drain plug goes. You can get them
from salvage yards where they break helicopters. That’s where I got mine.
On Fri, 20 Nov 2020 at 11:42, bobnoffs <icubob(at)gmail.com
<mailto:icubob(at)gmail.com>> wrote:
<icubob(at)gmail.com <mailto:icubob(at)gmail.com>>
gearbox case.
it is inspected.
bob
http://forums.matronics.com/viewtopic.php?p=499444#499444
Electric-List" rel="noreferrer"
target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
Sent from Gmail Mobile
bobnoffs
Posted: Fri Nov 20, 2020 4:29 pm Post subject: Re: heat probe |
I admit adding a chip detector is a stretch but I think a temp probe could be valuable. You are not looking for absolute temp but a trend compared to engine oil temp.
If I had a gearbox with a hx of failure I would probably be looking for another gearbox. Kind of like having an engine oil analysis. Maybe I will see something coming
