Ni-Cd Battery Safety Information Bulletin
cluros(at)gmail.com
PostPosted: Wed Nov 04, 2020 8:16 am    Post subject: Ni-Cd Battery Safety Information Bulletin Reply with quote
Interesting, I have never heard of this.
Aircraft Maintenance Manual Aircraft Parking Procedures usually require the physical disconnection of the aircraft batteries, and the periodic reconnection to carry out the parking or storage checks. A Type Certificate (TC) holder in conjunction with a battery manufacturer has identified that when a Nickel-Cadmium (Ni-Cd) battery is disconnected from the aircraft loads, it self-discharges due to an electrochemical phenomenon, thus inducing a reduction of battery capacity. When the battery is charged again from the aircraft, the battery does not recover 100% of its initial capacity. Therefore, after each cycle of battery self-discharge, the available battery capacity will decrease progressively.
EASA_SIB_2020-18_1.pdf
 Filename:  EASA_SIB_2020-18_1.pdf
 Filesize:  558.33 KB
 Downloaded:  527 Time(s)
Ceengland
PostPosted: Wed Nov 04, 2020 8:43 am    Post subject: Ni-Cd Battery Safety Information Bulletin Reply with quote
Interesting, but isn't it more of academic than practical interest, for most of us? I doubt that you could find a NiCd starting battery in a homebuilt these days.
stuart(at)stuarthutchison
PostPosted: Wed Nov 04, 2020 3:49 pm    Post subject: Ni-Cd Battery Safety Information Bulletin Reply with quote
Yes, few if any NiCd left in GA.  This is the ‘memory effect’ of NiCd, which grows larger crystals in the electrolyte over time.  These have a smaller interstitial surface area, therefore less chemical reaction can take place, so degraded capacity unless properly ‘deep-cycled’.
On 5 Nov 2020, at 3:38 am, Charlie England <ceengland7(at)gmail.com (ceengland7(at)gmail.com)> wrote:
Interesting, but isn't it more of academic than practical interest, for most of us? I doubt that you could find a NiCd starting battery in a homebuilt these days. Charlie Virus-free. www.avast.com [url=x-msg://1/#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2][/url]
