jay-dub
pennington.construction.i Guest
Posted: Sat Oct 31, 2020 3:44 pm Post subject: Swagelok |
Jay
I use the all stainless steel valves the Doug supplies.
The photo is from a Yak list post from before.
I hung onto it in the event I couldn’t get a Chinese stainless valve. This is the valve for the main and emergency valves.
Mark
N621CJ
[img]cid:175810a6162a44d93281[/img]
[img]cid:175810a6bcd40077f272[/img]
On Sat, Oct 31, 2020 at 7:31 PM jay-dub <flyjnw(at)gmail.com (flyjnw(at)gmail.com)> wrote:
| Quote: | --> Yak-List message posted by: "jay-dub" <flyjnw(at)gmail.com (flyjnw(at)gmail.com)>
Please could someone tell me the spec of the Swagelok valves to replace the normal and emergency air valves.
Also, the snot valves.
Thanks from Lockdown, UK. [Rolling Eyes]
CJ and Yak-52 owner
http://forums.matronics.com/viewtopic.php?p=499045#499045
373.14 KB |
9776 Time(s) |
285.26 KB |
9776 Time(s) |
jay-dub
Posted: Sat Oct 31, 2020 3:46 pm Post subject: Re: Swagelok |
Perfect, thanks.
_________________ CJ owner |
wamflight(at)gmail.com Guest
Posted: Sat Oct 31, 2020 3:54 pm Post subject: Swagelok |
And the sizes we need to tap the threads? | Quote: | On Nov 1, 2020, at 8:42 AM, Mark Pennington <pennington.construction.inc.1(at)gmail.com (pennington.construction.inc.1(at)gmail.com)> wrote:
Jay
Mark
N621CJ
<IMG_4522.jpg>
<IMG_4521.jpg>
k7wx
Here is a picture of my CJ emergency on-off valve with adaptors that duplicate the original line positions. The Yak-52 probably requires different adaptors. The black handle valve for the main air is Swagelok part number SS-42GF2-A-WN2 and the emergency air red handle part number is SS-42GF2-A-RD-WN2. I suggest placing about 4 turns of nylon tape on the threads to lessen the likelihood of leaks. Replace and forget.
Warren Hill
N464TW
Mesa, AZ
[img]cid:EAE9B400-E834-43EA-9F8E-4560C6ABBEC3(at)Home[/img]
244.06 KB |
9766 Time(s) |
Posted: Sat Oct 31, 2020 4:02 pm Post subject: Swagelok |
did you tap the new valve? size?
| Quote: | On Nov 1, 2020, at 8:53 AM, Warren Hill <k7wx(at)earthlink.net (k7wx(at)earthlink.net)> wrote:
Warren Hill
N464TW
Mesa, AZ
<Swagelok.jpg>
hill(at)doctor-hill.com Guest
Posted: Sat Oct 31, 2020 4:10 pm Post subject: Swagelok |
Both the Chinese adaptors and the Swagelok valves are ⅛-27 NPT pipe thread.
| Quote: | On Oct 31, 2020, at 5:01 PM, William Geipel <wamflight(at)gmail.com (wamflight(at)gmail.com)> wrote:
Warren Hill
N464TW
Mesa, AZ
<Swagelok.jpg>
Posted: Sun Nov 01, 2020 2:27 am Post subject: Swagelok |
Jay
Here is a photo I saved of the snot valve with a swagelock valve.
At the time the post did not give a part number.
Maybe someone will recognize the valve and share the part number
Mark
N621 CJ
[img]cid:1758357376d6cd9bb2a1[/img]
On Sat, Oct 31, 2020 at 8:14 PM Warren Hill <hill(at)doctor-hill.com (hill(at)doctor-hill.com)> wrote:
| Quote: | Both the Chinese adaptors and the Swagelok valves are ⅛-27 NPT pipe thread.
Warren Hill
N464TW
Mesa, AZ
<Swagelok.jpg>
301.16 KB |
9741 Time(s) |
hkgibby(at)yahoo.com Guest
Posted: Sun Nov 01, 2020 5:56 am Post subject: Swagelok |
See RPA Library...click on CJ-6 Nanchang; it’s there.
| Quote: | On Nov 1, 2020, at 2:40 AM, Mark Pennington <pennington.construction.inc.1(at)gmail.com> wrote:
Jay
Mark
N621 CJ
<IMG_4524.jpg>
Warren Hill
N464TW
Mesa, AZ
<Swagelok.jpg>
k7wx
Posted: Sun Nov 01, 2020 7:05 am Post subject: Swagelok |
Hello Mark,
For the Yak-52, it's the Swagelok SS-43GM4-S4.
For the CJ, a typical install requires a right angle adaptor and a different right angle Swagelok valve. If you need this part number I’ll get it later today.
Attached are some images.
Warren
N464TW
[img]cid:509517C5-0E6C-409C-9782-356E707CC9F2[/img] [img]cid:B8602EEA-ACEA-4B48-8640-02C3B6906E5B[/img]
| Quote: | On Nov 1, 2020, at 3:26 AM, Mark Pennington <pennington.construction.inc.1(at)gmail.com (pennington.construction.inc.1(at)gmail.com)> wrote:
Jay
Mark
N621 CJ
<IMG_4524.jpg>
Warren Hill
N464TW
Mesa, AZ
<Swagelok.jpg>
357.51 KB |
9726 Time(s) |
384.2 KB |
9726 Time(s) |
k7wx
Posted: Sun Nov 01, 2020 8:49 am Post subject: Swagelok |
One additional item. If not already done. The bottom thread of the snot bottle will need to be tapped to accept the input side of the Swagelock valve, which I believe is ¼-inch NPT. After completing the tap, be sure to completely wash out the many small metal fragments produced. It’s helpful to do the tap a little less than you think is needed and then screw int the Swagelock valve until it is tight. If a ¼ to ½ turn more is needed to properly align the value, run the tap just a little more. This way the final valve position will not end up at some odd angle.
Hello Mark,
Warren
N464TW
Jay
Mark
N621 CJ
<IMG_4524.jpg>
Warren Hill
N464TW
Mesa, AZ
<Swagelok.jpg>
357.51 KB |
9720 Time(s) |
384.2 KB |
9720 Time(s) |
Posted: Sun Nov 01, 2020 8:58 am Post subject: Swagelok |
Thank you Mr. Hill
On Sun, Nov 1, 2020 at 11:55 AM Warren Hill <k7wx(at)earthlink.net (k7wx(at)earthlink.net)> wrote:
| Quote: | One additional item. If not already done. The bottom thread of the snot bottle will need to be tapped to accept the input side of the Swagelock valve, which I believe is ¼-inch NPT. After completing the tap, be sure to completely wash out the many small metal fragments produced. It’s helpful to do the tap a little less than you think is needed and then screw int the Swagelock valve until it is tight. If a ¼ to ½ turn more is needed to properly align the value, run the tap just a little more. This way the final valve position will not end up at some odd angle.
Hello Mark,
Warren
N464TW
[img]cid:17584bd5436ef8af8151[/img] [img]cid:17584bd54367a877b712[/img]
Jay
Mark
N621 CJ
<IMG_4524.jpg>
Warren Hill
N464TW
Mesa, AZ
<Swagelok.jpg>
384.2 KB |
9718 Time(s) |
357.51 KB |
9718 Time(s) |
