dlm34077(at)gmail.com Guest
Posted: Thu Oct 15, 2020 12:24 pm Post subject: Sky-Tec starters |
time to overhaul the starter; anybody got a good and economical shop recommendation for the overhaul?
partner14
Posted: Thu Oct 15, 2020 1:13 pm Post subject: Sky-Tec starters |
A few friends here in Granbury TX (pecan Plantation) used to own both Sky Tech (starters) and Plane Power (alternators), but were bought out by Hartzell.... and they don't repair anything.
On Thursday, October 15, 2020, 03:37:44 PM CDT, dlm <dlm34077(at)gmail.com> wrote:
40636 |
Kellym
Posted: Thu Oct 15, 2020 2:33 pm Post subject: Sky-Tec starters |
Dave,
Sorry, Skytec AFAIK has not released overhaul data, so only they can
overhaul. I last had one done about 10 years ago. Service was like 1 day
turnaround. At the time price was about $160. No clue what it is today.
IIRC, it was about 50% of price of new one for certified aircraft.
Kelly
On 10/15/2020 1:20 PM, dlm wrote:
| Quote: | time to overhaul the starter; anybody got a good and economical shop
KCHD |
dmasys2(at)gmail.com Guest
Posted: Fri Oct 16, 2020 6:45 am Post subject: Sky-Tec starters |
My OEM "flyweight" Skytec starter froze its front bearing and died in 2018, and I found as others have noted that no overhaul was available. The Skytec replacement design (called the 'high torque inline Lycoming starter') is fundamentally a better engineering solution and worth the price of admission. Make sure you know the number of teeth on your ring gear before ordering, since there are several different variants of the basic design.
I think that part of the no overhaul policy is just to get the older, seizure-prone design out of the installed base. The new design spins the IO-540 noticeably faster, and on my -10 that starter plus the SureFly electronic ignition makes for pretty much instant starts hot or cold. Even my Toyota is jealous.
-Dan Masys
N104LD 1200hrs TTSN
On Thu, Oct 15, 2020 at 1:29 PM dlm <dlm34077(at)gmail.com (dlm34077(at)gmail.com)> wrote:
| Quote: | time to overhaul the starter; anybody got a good and economical shop recommendation for the overhaul?
Coop85
Posted: Fri Oct 16, 2020 7:07 am Post subject: Sky-Tec starters |
I had a similar experience. After a kickback my initial starter sheared the protective shaft killing the start. I sent it in to upgrade to the high torque starter with kickback reset so that won’t happen again. It’s been excellent for a few years now, well worth it.
Marcus
40286 1060 hoursOn Oct 16, 2020, at 10:44 AM, Dan Masys <dmasys2(at)gmail.com (dmasys2(at)gmail.com)> wrote:
-Dan Masys
N104LD 1200hrs TTSN
_________________ Marcus Cooper
RV-10 since 2006 |
rjones560xl@gmail.com
Joined: 29 Jul 2015 Posts: 64 Location: Las Vegas, NV
Posted: Fri Oct 16, 2020 9:04 am Post subject: Sky-Tec starters |
It I had to buy a new one I would get he B&C starter. They take better care of their customers.
Robert Jones
| Quote: | On Oct 16, 2020, at 2:01 AM, Kelly McMullen <kellym(at)aviating.com> wrote:
Dave,
Sorry, Skytec AFAIK has not released overhaul data, so only they can overhaul. I last had one done about 10 years ago. Service was like 1 day turnaround. At the time price was about $160. No clue what it is today. IIRC, it was about 50% of price of new one for certified aircraft.
Kelly
_________________ Robert J Jones
702-521-1840 |
