Wire stripper
Argonaut36
PostPosted: Fri Oct 09, 2020 3:32 pm    Post subject: Wire stripper Reply with quote
I would like to replace my wire stripper that has recently failed. I am interested in a tool that can strip wires in the range 10-22 AWG and possibly smaller wires as the ones sometimes used in avionics and instruments. I would buy 2 strippers, if necessary.
Could somebody make a recommendation for a good quality, reliable tool?
rlborger(at)mac.com
PostPosted: Fri Oct 09, 2020 3:57 pm    Post subject: Wire stripper Reply with quote
Argonaut36,
The Ideal Stripmaster 45-097 from B&C (bandc.com) is an excellent wire stripper. As received it strips wire from 16-26 AWG. The stripper blades are replaceable and an adjustable wire stop is available for it. I’m sure similar strippers are available at other electronics site.
Blue skies & tailwinds,
Bob Borger
Europa XS Tri, Rotax 914, Airmaster C/S Prop.
Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP, Hercules Prop.
3705 Lynchburg Dr.
Corinth, TX 76208-5331
Cel: 817-992-1117
rlborger(at)mac.com
http://forums.matronics.com/viewtopic.php?p=498730#498730
ceengland7(at)gmail.com
PostPosted: Fri Oct 09, 2020 4:44 pm    Post subject: Wire stripper Reply with quote
Do you want basic strippers, or an 'automatic' version? Auto is faster
(and a lot more expensive), but I find them harder to use when I need to
strip an exact amount for things like subD terminals. Ideal makes
automatic versions, if that's what you want.
Klein can almost always be counted on to make good tools; just google
'Klein wire strippers' to see what's available.
 I've got an Ideal automatic, a Klein, and several other variations,
but to be honest, my go-to stripper is one I bought from a surplus goods
mail order company over 30 years ago. It might be worthwhile to take a
few wire scraps to a local hardware store, or even a 'big box' store, &
play with their selection of strippers. Pick one you're comfortable with
& go with it.
Argonaut36
PostPosted: Sat Oct 10, 2020 8:22 am    Post subject: Re: Wire stripper Reply with quote
Thanks to All for the help.
I placed an order for the Ideal Stripmaster 45-097.
Ceengland
PostPosted: Tue Mar 29, 2022 5:36 am    Post subject: Wire stripper Reply with quote
Sir Spamalot?
On Tue, Mar 29, 2022 at 5:12 AM jameslandry <jameslandry454(at)gmail.com (jameslandry454(at)gmail.com)> wrote:
--> AeroElectric-List message posted by: "jameslandry" <jameslandry454(at)gmail.com (jameslandry454(at)gmail.com)>
WGGE is one of the electrical wire stripping tools I’ve previously worked with. It can cut and strip solid copper and aluminum wires from 10 to 22 AWG. I can also use its serrated nose to grip, pull, shape, and bend wires, negating the need for me to use and carry an extra pair of pliers.
Read more here: https://www.galvinpower.org/best-wire-strippers/
http://forums.matronics.com/viewtopic.php?p=506423#506423
="noreferrer" target="_blank">https://matronics.com/contribution
PostPosted: Tue Mar 29, 2022 7:30 am    Post subject: Wire stripper Reply with quote
At 08:32 AM 3/29/2022, you wrote:
Sir Spamalot?
On Tue, Mar 29, 2022 at 5:12 AM jameslandry <jameslandry454(at)gmail.com (jameslandry454(at)gmail.com) > wrote:
--> AeroElectric-List message posted by: "jameslandry" <jameslandry454(at)gmail.com (jameslandry454(at)gmail.com) >
Correct. This poster is not a registered
List subscriber.
out of that stuff?"
PostPosted: Tue Mar 29, 2022 8:27 am    Post subject: Re: Wire stripper Reply with quote
Yes, jameslandry is a spammer. He has been reported to Matt and deleted.
Joe Gores
