voltage monitor
Goto page 1, 2  Next
bobnoffs
PostPosted: Thu Oct 01, 2020 5:29 am    Post subject: voltage monitor Reply with quote
hi all,
i have earthx batteries and would like to install a voltage warning separate from my eis. the device must activate below 13.5 volts . does anyone have any recommendations? i would think something is out there but i haven't seen it.
thanks, bob noffs
ceengland7(at)gmail.com
PostPosted: Thu Oct 01, 2020 5:54 am    Post subject: voltage monitor Reply with quote
On Thu, Oct 1, 2020 at 8:39 AM bobnoffs <icubob(at)gmail.com (icubob(at)gmail.com)> wrote:
--> AeroElectric-List message posted by: "bobnoffs" <icubob(at)gmail.com (icubob(at)gmail.com)>
hi all,
 thanks, bob noffs
Hi Bob,
A friend of mine has been using this for years, to alert him of alternator loss since he's using electronic ignition on his Lyc:
https://www.tomtop.com/p-e1021.html
It can be programmed to alert for both over and under-voltage and output fed to whatever you choose; light, buzzer, etc.
I bought a couple, but they're still sitting in my 'toy box'; I haven't had an urgent need for one yet. FWIW, the guy who's using it has one of the nicest RV8s I've ever seen, and doesn't do anything 'half-way'. If it's good enough for him...
chaskuss(at)yahoo.com
PostPosted: Thu Oct 01, 2020 6:31 am    Post subject: voltage monitor Reply with quote
Here are two offerings with the ability to handle Lithium batteries, which actually run about 1 volt above AGM and standard flooded batteries. Both are small, rugged and inexpensive.
https://gammatronixltd.com/epages/bae94c71-c5b6-4572-89a1-e89006e78fbe.sf/en_GB/?ObjectPath=/Shops/bae94c71-c5b6-4572-89a1-e89006e78fbe/Categories/Category1
http://roadstercycle.com/Motorcycle%20voltage%20monitor.htm
Per Shorai's web site, their LiFe batteries are fully charged at 14.34 volts, as opposed to 13.2 volts for an AGM or flooded lead/acid battery. See web link below
https://shoraipower.com/faq
From that page, click on the question Q. Can I use Lead-Acid battery chargers or charger/tenders?
You will see Shorai's charging table.
Charlie K
On Thursday, October 1, 2020, 09:52:58 AM EDT, bobnoffs <icubob(at)gmail.com> wrote:
hi all,
thanks, bob noffs
http://forums.matronics.com/viewtopic.php?p=498614#498614
s.matronics.com" target="_blank">http://forums.matronics.com
_-= --> =   -Matt Dralle, List Admin.
rparigoris
PostPosted: Thu Oct 01, 2020 9:59 am    Post subject: Re: voltage monitor Reply with quote
Hi Bob I don't know what type of regulator you have, but I have a B&C LR3D that B&C calibrated the Low Voltage Warning for LiFe and also have a B&C AVC1 for Rotax 914 internal generator that you can select LiFe Low Voltage Warning. I'm using a Earth-X 680C. Ron P.
bobnoffs
PostPosted: Fri Oct 02, 2020 2:33 am    Post subject: Re: voltage monitor Reply with quote
i ordered the tom top unit. for $5 i gotta see how it works.
talked to perihelion and i believe they can build their ''idiot light'' to my specs.this is a panel light with the electronics self contained.
any more suggestions i would like to hear.
thanks, bob noffs
skywagon185(at)gmail.com
PostPosted: Sat Oct 03, 2020 12:38 pm    Post subject: voltage monitor Reply with quote
I personally like the idea of a panel light that will make you aware of Under and well as Over voltage conditions.
I have experienced an under voltage on start up. Caused by a defective main circuit breaker that opened, but did not show an indication that it had mysteriously opened.  Luckily, before beginning the taxi, I noted the amp/volt meter was amiss.
Tested the CB and could not get it to reset.  Installed new CB and had no additional problems.
On Fri, Oct 2, 2020 at 3:41 AM bobnoffs <icubob(at)gmail.com (icubob(at)gmail.com)> wrote:
  talked to perihelion and i believe they can build  their 'idiot light' to my specs.this is a panel light with the electronics self contained.
 thanks, bob noffs
http://forums.matronics.com/viewtopic.php?p=498628#498628
Electric-List" target="_blank" rel="noreferrer">http://www.matronics.com/Navigator?AeroElectric-List
_blank" rel="noreferrer">http://forums.matronics.com
lank" rel="noreferrer">http://wiki.matronics.com
target="_blank" rel="noreferrer">http://www.matronics.com/contribution
PostPosted: Sat Oct 03, 2020 1:05 pm    Post subject: voltage monitor Reply with quote
Then I take it that your system was not fitted
with active notification of low voltage. This
feature is the FIRST if not the ONLY voltage
sensing/indicating device NECESSARY for flight
operations.
Preferably, this light is bright (sunlight viewable)
and located well within peripheral vision of the pilot.
Further, it should flash at 2-3 times per second
(a legacy value for optimal attention getting
arrived at by numerous human factors studies ).
This light has been a no-extra-charge built in feature
of virtually all B&C alternator controllers. From
day-one (about 35 years ago). It was B&C's mission that
no customer would be without BOTH low volts and
over volts management.
Yes, there was an element of luck associated with
that experience. I'm pleased the event resolved
without a tense-day-in-the-cockpit.
Along with active notification of low volts, you
should plan on independent management of an over
voltage condition with a system that disables
the alternator within 500 milliseconds of having
exceeded 16 volts.
Depending on design parameters of the designer,
the ov event will be over very soon thus leaving
you with a low volts condition that will be
annunciated as cited above.
Fit your airplane with those two features and
all the other voltmeters, ammeters, beeps
and squawks from the panel mounted goodies
become mere icing on the cake.
bobnoffs
PostPosted: Sun Oct 04, 2020 3:42 am    Post subject: voltage monitor Reply with quote
since my first post perihelion design has let me know that their idiot
light can be made to any high/low settings. pretty slick fix. 2 leads [i
assume] and it all fits in a .55'' panel hole. light can be ordered
flashing or steady.
On Sat, Oct 3, 2020 at 4:11 PM Robert L. Nuckolls, III <
opened.
operations.
bobnoffs
PostPosted: Sun Oct 04, 2020 7:58 am    Post subject: Re: voltage monitor Reply with quote
the rub with low voltage indicators is that they set their low voltage for lead acid batteries. this is too low and useless for earthx lipo. low voltage warning must go on below 13.5 volts. when i started this post i talked to b and c about a warning system they had. the voltage was not adjustable and set for lead acid......no good for lipo. b and c said that most electronics is adjustable today and there was never a market for a higher low warning. my system is adjustable but i do not want to probe my ecu with my computer just to make a limit change.
earthx users....what's in your wallet? er i mean low voltage setting?
PostPosted: Sun Oct 04, 2020 9:26 am    Post subject: voltage monitor Reply with quote
At 10:58 AM 10/4/2020, you wrote:
--> AeroElectric-List message posted by: "bobnoffs" <icubob(at)gmail.com>
earthx users....what's in your wallet? er i mean low voltage setting?'
Not sure I understand this. Check out this family of
discharge plots on 3 brands of LiFePo4 batteries
including an EarthX.
https://tinyurl.com/y4nsp8lr
Looks to me like 13.5V is still a good number.
bobnoffs
PostPosted: Sun Oct 04, 2020 10:10 am    Post subject: Re: voltage monitor Reply with quote
without any mod the ''idiot light'' comes preset to warn below 13.0 volts. in a lead acid set up this would catch the alternator soon after it went off line and a lead acid would have most of its charge left. when a lipo drops below 13 volts a lot of its charge is already been used. the goal is to catch the alternator going out, not to monitor system voltage. my engine needs a battery or a working alternator to keep running.
PostPosted: Sun Oct 04, 2020 10:29 am    Post subject: voltage monitor Reply with quote
without any mod the 'idiot light' comes preset to warn below 13.0 volts. in a lead acid set up this would catch the alternator soon after it went off line and a lead acid would have most of its charge left. when a lipo drops below 13 volts a lot of its charge is already been used.
Can you confirm that assertion from the
data offered in the three plots I've
posted?
The testing I've done suggests that
there MIGHT be a bit of delay in the
LV WARN response . . . but it's minimal.
An LV condition is not a high pucker-factor
event. After the alternator
quits you can finish your cup of coffee
and sandwich, fold the map (if you still use one)
and then proceed to implement plan-b.
Conducting a lightning-fast response to the
light would have no measurable effect on
the outcome of your flight.
This is true of what ever type of battery
chemistry is on board. This is why I've
advised against numerous schemes for automatic
responses to low voltage. Such features only
add complexity that demands pre-flight testing
while failing to reduce risk.
PostPosted: Sun Oct 04, 2020 11:09 am    Post subject: voltage monitor Reply with quote
--> AeroElectric-List message posted by: "bobnoffs" <icubob(at)gmail.com> (icubob(at)gmail.com)
  posted?
I think I see his point. If the 'stock' alert point is 13V, the EarthX chart shows that to be at about the 3 AH point of the curve with total AH capacity of about 11AH when looking at the higher discharge rates you'd expect from an electronic injection system. Not a big deal if there's a backup alternator, but being down roughly 1/3 before notification could be a big deal if you're depending on battery for backup.
PostPosted: Sun Oct 04, 2020 11:23 am    Post subject: voltage monitor Reply with quote
I suggest to view Shorai's FAQ page linked below.
Scroll down and click on the question: Q. Can I use Lead-Acid battery chargers or charger/tenders?
View the chart on the right side of the page. Note that at 13.0 volts, these LiFe batteries have less than 40% charge left.
Charlie K
On Sunday, October 4, 2020, 02:45:15 PM EDT, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com> wrote:
--> AeroElectric-List messageposted by: "bobnoffs" <icubob(at)gmail.com>
without any mod the 'idiot light' comes preset to warn below 13.0 volts.in a lead acid set up this would catch the alternator soon after it wentoff line and a lead acid would have most of its charge left. when a lipodrops below 13 volts a lot of its charge is already been used.
posted?
the goal is to catch thealternator going out, not to monitor system voltage. my engine needs abattery or a working alternator to keep running.
PostPosted: Sun Oct 04, 2020 1:21 pm    Post subject: voltage monitor Reply with quote
Don't know where the 13.0 point comes from. Both
AEC and B&C have used 13.5 for a couple of decades.
But okay, let's assume 13.0
See tabular data text file. The ETX36 with a 5A
load on it will fall to 13.0 in about 40 seconds.
The image file is from plotred data of the same
test:
Kinda hard to zero in on the finer details of a
couple hour run but it shows that at 67 seconds,
the battery was down to 12.99 with an expenditure
of approx 0.1 AH
Keep in mind that voltage monitoring at
the bus is always tens of millivolts HIGHER
than battery voltage . . . with a similar
departure to the LOWER side during DISCHARGE
conditions.
So assuming one had a LV reporting system that
was not adjustable but accurate to 100 millivolts
or so at 13.0, the resulting delay between
alternator failure and annunciation is still
timely and 'wasted' energy is trivial.
 Filesize:  43.59 KB
 Viewed:  17069 Time(s)
First_40_Seconds.txt
 Filename:  First_40_Seconds.txt
 Filesize:  2.63 KB
 Downloaded:  439 Time(s)
PostPosted: Sun Oct 04, 2020 1:33 pm    Post subject: voltage monitor Reply with quote
At 02:18 PM 10/4/2020, you wrote:
That's an open circuit, no-load voltage that speaks
to state of charge. That's not a milestone voltage
for a fully charged battery under load.
Two completely different conditions
bobnoffs
PostPosted: Sun Oct 04, 2020 1:50 pm    Post subject: Re: voltage monitor Reply with quote
hi all,
according to the graph posted bob is right about the very small current drained.
this is not at all how earthx describes their batteries. earthx recommends that low voltage monitors light up below 13.5 volts.
on the b and c web site they sell an over/under voltage sensor model bc207. the low voltage light trips at 12.5 volts according to their description.
everything i have learned about the lipo batteries has said they hold their voltage while discharging. i have always seen a much larger % drop advertised.time for me to call earthx.
PostPosted: Sun Oct 04, 2020 2:17 pm    Post subject: voltage monitor Reply with quote
On Sun, Oct 4, 2020 at 4:28 PM Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
  test:
  of approx 0.1 AH
  conditions.
I think he's using the EarthX PC680 relacement battery. I used EarthX's chart for their PC680 replacement, here:
https://earthxbatteries.com/earthx_manual.pdf
and assumed ~12-14 A load, which is typical for full electronic engine control with electronic injection. According to EarthX the 680 replacement hovers around 13 V until around 3 AH has been depleted.
You'd know a lot better than me where the LoVolts setpoint is with B&C stuff; that's why I said 'if'. Smile
PostPosted: Sun Oct 04, 2020 2:33 pm    Post subject: voltage monitor Reply with quote
hi all,
Can you point us to the download for
information that gives you concern?
B&C and I both have promoted that lv setpoint
value for decades . . .
That device was originally crafted
for ultralights about 30 years ago.
In fact, it was the first, stand-alone
monitor device produced there.
It was never intended for installation
in 'real' airplanes. I really wish
they didn't sell that any more but
I think Aircraft Spruce shows it in
their catalog. NOT RECOMMENDED FOR
NEW DESIGN.
And in what way does the data I've posted
argue with that?
The AeroVoltz plot shows a working range
on the order of 13.2 to 12.5 volts.
Miady 13.2 to about 12.0
EarthX from 13.2 to 12.5
Where are you going to find anything
flatter for a discharge curve? All three
deliver power within a 5% or smaller
window.
I have always seen a much larger % drop advertised.time for me to call earthx.
. . . and ask what? Help me understand
your question. Before you seek verbal
guidance, let us examine data-in-print
and data-measured so that disconnects can
be clearly articulated. I'd be happy
to call them myself if there are real
points of contention.
I've talked to both EarthX and Shorai
numerous times but a considerable time
ago . . . wouldn't mind renewing some
contacts.
kenryan
PostPosted: Sun Oct 04, 2020 2:51 pm    Post subject: voltage monitor Reply with quote
From: Technical Manual for Model No. LR3D-14 and LR3D-28 Linear RegulatorWith Over-Voltage Protection, Low-Voltage Sensing, And Field-Adjustable Charging Voltage
"The LV warning light will begin to flash when the voltage sensed at terminal 3 drops to approximately 12.7V and below"
Disregard if this is not relevant to this discussion.
On Sun, Oct 4, 2020 at 2:26 PM Charlie England <ceengland7(at)gmail.com (ceengland7(at)gmail.com)> wrote:
  test:
  of approx 0.1 AH
  conditions.
Goto page 1, 2  Next
Page 1 of 2
