david(at)carter.net Guest
jluckey(at)pacbell.net Guest
Posted: Fri Sep 25, 2020 8:04 am Post subject: Butt Splice on Main Alt B Lead |
David,
I classify those kind of connectors as "cheap automotive" wire terminals and would not recommend them for use is aircraft.
Do a search for AMP (is Manufacturer) PIDG (Pre Insulated Diamond Grip) butt splice for something that looks like this:
[img]cid:3c50c1ed-d948-e161-0bcd-39a0b1f17789(at)yahoo.com[/img]">
Jeff Luckey
On Friday, September 25, 2020, 08:48:29 AM PDT, David Carter <david(at)carter.net> wrote:
A couple of questions on this connection. Z101 calls for a 12-gauge FLW butt spliced onto the 10-gauge main alt B-lead wire.
I didn't see any this large at Spruce, but it appears that both Amazon & AutoZone have the Dorman splices in 8 gauge. Is this a satsifactory product for our needs?
https://www.autozone.com/miscellaneous-non-automotive/electrical-wire-connector/dorman-conduct-tite-8-gauge-butt-connectors/422502_0_0
Also, are there any special techniques required to ensure that the smaller wire is propertly gripped in the slice when crimped? Do I need to put some extra wire strands in there to fill the connector & snip off any excess?
Thanks!
David
David Carter
david(at)carter.net (david(at)carter.net)
117.99 KB |
6949 Time(s) |
Posted: Fri Sep 25, 2020 8:22 am Post subject: Butt Splice on Main Alt B Lead |
At 09:56 AM 9/25/2020, you wrote:
| Quote: | | A couple of questions on this connection. Z101 calls for a 12-gauge FLW butt spliced onto the 10-gauge main alt B-lead wire. |
There should be a 4AWG spread between the protected feeder
and the fusible link stock. So the 10AWG feeder from the aux
alternator gets a 14AWG FLW. That's the case in the
last iteration of Z101 (rev B).
The 'yellow' series PIDG terminals are indicated
for 10-12AWG wires.
https://tinyurl.com/y4njsbmt
This splice would work with our favorite po' boy's
crimp tool.
Keep in mind that 'gas tightness' of the interface
between wire and splice is the holy-grail. Folks
like AMP, Molex, C-H, have spent untold bux researching
and qualifying proven combinations of crimp dies, terminals
and wire stranding to achieve those goals.
Now comes wire, terminals and tools from a variety of
sources NOT tested for playing nice in the same
sandbox. Here are some references from the
'Connection
https://tinyurl.com/kfk6jss
http://aeroelectric.com/articles/terminal.pdf
Field history on this series of tools with PIDG has
been favorable
https://tinyurl.com/yy6wlbv2
You might look into this alternative. The heat-shrink
terminals and butt splices have been around for awhile
https://tinyurl.com/y26la2p6
. . . but no tools that produced a elegant upset of the
wire grips without mangling the insulation . . . until
now.
https://tinyurl.com/y3kzobsx
I'm ordering one of these in to take a look and try
it out.
| Quote: | | Also, are there any special techniques required to ensure that the smaller wire is propertly gripped in the slice when crimped? Do I need to put some extra wire strands in there to fill the connector & snip off any excess? |
You betcha. Strip the 14AWG wire back about 1/2
and fold it so as to double the strands
in the wire grip.
Alternatively, you could consider a soldered lap
joint like this
https://tinyurl.com/yxq7c5d9
BUT NO MATER WHICH TECHNIQUE YOU CHOSE TO EXPLORE,
BUY EXTRA TERMINALS AND EXPERIMENT WITH THE
PROPOSED TOOL(S) AND WIRE. DO A PULL TEST TO INSURE
THAT YOUR WIRE/TOOL/TERMINAL COMBINATIONS ARE
COMING TOGETHER IN BLISSFUL EMBRACE.
Posted: Fri Sep 25, 2020 8:46 am Post subject: Butt Splice on Main Alt B Lead |
I made a mistake in my question. The main alt lead is 8 gauge & joins to a 12 gauge fusible link. That's the size butt connector I'm not seeing at Spruce. The yellow amp goes up to 10.
On Fri, Sep 25, 2020 at 12:25 PM Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
| Quote: | A couple of questions on this
for 10-12AWG wires.
crimp tool.
'Connection
been favorable
now.
it out.
| Quote: | Also, are there any special
in the wire grip.
joint like this
David Carter
Flyitnow
Posted: Fri Sep 25, 2020 8:52 am Post subject: Butt Splice on Main Alt B Lead |
Aircraft Spruce # 320570
On Friday, September 25, 2020, 09:34:01 AM PDT, Jeff Luckey <jluckey(at)pacbell.net> wrote:
David,
[img]cid:QnZ7yPtZMT5FlqyPCsTE[/img]">
Jeff Luckey
Thanks!
David
---David Carterdavid(at)carter.net (david(at)carter.net)
117.99 KB |
6948 Time(s) |
Posted: Fri Sep 25, 2020 11:15 am Post subject: Butt Splice on Main Alt B Lead |
David,
See if this meets your needs....
Heat Shrink, Crimp Seal Butt Connectors
<![endif]--><![endif]-->$7.73
<![endif]-->Heat Shrink, Crimp Seal Butt Connectors
On Friday, September 25, 2020, 10:38:51 AM PDT, David Carter <david(at)carter.net> wrote:
| Quote: | At 09:56 AM 9/25/2020, you wrote: | Quote: | | A couple of questions on thisconnection. Z101 calls for a 12-gauge FLW butt spliced onto the 10-gaugemain alt B-lead wire. | There should be a 4AWG spread between the protected feeder and the fusible link stock. So the 10AWG feeder from the aux alternator gets a 14AWG FLW. That's the case in the last iteration of Z101 (rev B). The 'yellow' series PIDG terminals are indicated for 10-12AWG wires.https://tinyurl.com/y4njsbmt This splice would work with our favorite po' boy's crimp tool. Keep in mind that 'gas tightness' of the interface between wire and splice is the holy-grail. Folks like AMP, Molex, C-H, have spent untold bux researching and qualifying proven combinations of crimp dies, terminals and wire stranding to achieve those goals. Now comes wire, terminals and tools from a variety of sources NOT tested for playing nice in the same sandbox. Here are some references from the 'Connectionhttps://tinyurl.com/kfk6jsshttp://aeroelectric.com/articles/terminal.pdf Field history on this series of tools with PIDG has been favorablehttps://tinyurl.com/yy6wlbv2You might look into this alternative. The heat-shrinkterminals and butt splices have been around for awhilehttps://tinyurl.com/y26la2p6. . . but no tools that produced a elegant upset of thewire grips without mangling the insulation . . . untilnow.https://tinyurl.com/y3kzobsxI'm ordering one of these in to take a look and tryit out. | Quote: | | Also, are there any specialtechniques required to ensure that the smaller wire is propertly grippedin the slice when crimped? Do I need to put some extra wire strands inthere to fill the connector & snip off any excess? | You betcha. Strip the 14AWG wire back about 1/2 and fold it so as to double the strands in the wire grip. Alternatively, you could consider a soldered lap joint like thishttps://tinyurl.com/yxq7c5d9 BUT NO MATER WHICH TECHNIQUE YOU CHOSE TO EXPLORE, BUY EXTRA TERMINALS AND EXPERIMENT WITH THE PROPOSED TOOL(S) AND WIRE. DO A PULL TEST TO INSURE THAT YOUR WIRE/TOOL/TERMINAL COMBINATIONS ARE COMING TOGETHER IN BLISSFUL EMBRACE.
-- ---David Carterdavid(at)carter.net (david(at)carter.net)
Posted: Fri Sep 25, 2020 11:31 am Post subject: Butt Splice on Main Alt B Lead |
At 11:41 AM 9/25/2020, you wrote:
| Quote: | I made a mistake in my question. The main alt  lead is 8 gauge & joins to a 12 gauge fusible link.Â
That's the size butt connector I'm not seeing at Spruce. The yellow amp goes up to 10.  |
Crimp tools in that size are not commonly
available. I think I'd go for a soldered lap-joint
for that one.
Posted: Fri Sep 25, 2020 1:03 pm Post subject: Butt Splice on Main Alt B Lead |
Yes, I was leaning toward the soldered lap joint approach. I considered crimping ring terminals on each wire end & joining them with a 1/4" bolt/nut assembly, but the 8-gauge crimper again becomes a problem.
Thanks to all for the advice & ideas.
David Carter
On Fri, Sep 25, 2020 at 3:37 PM Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
for that one.
DougW
Posted: Fri Sep 25, 2020 3:50 pm Post subject: Butt Splice on Main Alt B Lead |
Don’t know if these butt connectors would be of use here, but I am curious what Bob thinks. This URL goes to a Summit Racing site and shows that application. Looks pretty slick to me.
https://tinyurl.com/y374wd4m
Doug Windhorn
From: owner-aeroelectric-list-server(at)matronics.com <owner-aeroelectric-list-server(at)matronics.com> On Behalf Of Robert L. Nuckolls, III
Sent: Friday, September 25, 2020 10:02 AM
Subject: Re: Butt Splice on Main Alt B Lead
for that one.
