glastar(at)gmx.net Guest
Posted: Sun Sep 06, 2020 4:37 am Post subject: Z101 has been released under Rev A |
Dear Bob,
is the Z101 source as well available as dwg file so I can taylor it to
my new project (SDS/emag/no brownout).
Thanks a lot for your help, BTW will the next edition of your book
include these new diagrams? Would love to update my edition 10 (which
was still paper to a new edition with all your updates.
Cheers Werner (Glastar Z11 and now RV-10 with Z101)
On 26.05.2020 02:57, Robert L. Nuckolls, III wrote:
<nuckolls.bob(at)aeroelectric.com>
I've combed Z101 several times and I think
the major 'nits' have been eliminated. I removed
'preliminary' status and published as Rev -A-
at:
https://tinyurl.com/yavoutjh
Doesn't mean it's 'carved in stone' . . . just
ready for some serious builder consideration.
Error call outs and suggestions always welcome.
Posted: Mon Sep 07, 2020 5:56 am Post subject: Z101 has been released under Rev A |
At 07:34 AM 9/6/2020, you wrote:
| Quote: | --> AeroElectric-List message posted by: Werner Schneider <glastar(at)gmx.net>
Dear Bob,
is the Z101 source as well available as dwg file so I can taylor it to my new project (SDS/emag/no brownout). |
Yes, both files of RevB are posted.
The next upgrade to the Z-Figures will probably
'retire' most if not all of the legacy figures
applicable to aircraft engines (lyc, cont). Z101
iterations cover all previous variations on the
theme.
Posted: Mon Sep 07, 2020 1:16 pm Post subject: Z101 has been released under Rev A |
Thanks Bob,
I downloaded the 101B but my Intellicad says that it was created with an
unsupported version of Autocad and can not open it.
Any chance you can save a version with an older Autocad version
Z14P from 2013 still works up to Z34 ( 11/2014) from Z11P (2016 upwards
it fails)
Thanks Werner
On 07.09.2020 15:54, Robert L. Nuckolls, III wrote:
> Dear Bob,
theme.
Posted: Mon Sep 07, 2020 2:54 pm Post subject: Z101 has been released under Rev A |
Thanks Bob,
Any chance you can save a version with an older Autocad version |
try this one
[url=http://www.aeroelectric.com/PPS/ACAD_Architecture_Dwgs/Z101B(R14).dwg] http://www.aeroelectric.com/PPS/ACAD_Architecture_Dwgs/Z101B(R14).dwg[/url]
rickofudall
Posted: Mon Sep 07, 2020 4:01 pm Post subject: Z101 has been released under Rev A |
Werner, Try the free trial version of Draftsjght. It works all rhe way back to Acad 13.
Rick
Virus-free. www.avg.com [url=#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2][/url]
On Mon, Sep 7, 2020 at 4:21 PM Werner Schneider <glastar(at)gmx.net (glastar(at)gmx.net)> wrote:
| Quote: | --> AeroElectric-List message posted by: Werner Schneider <glastar(at)gmx.net (glastar(at)gmx.net)>
Thanks Bob,
it fails)
Thanks Werner
>> Dear Bob,
> theme.
> Bob . . .
“Blessed are the cracked, for they shall let in the light.” Groucho Marx
Posted: Mon Sep 07, 2020 9:20 pm Post subject: Z101 has been released under Rev A |
Woked perfectly, many thanks!!
Cheers Werner
On 08.09.2020 00:49, Robert L. Nuckolls, III wrote:
> Thanks Bob,
try this one
Posted: Mon Sep 07, 2020 9:22 pm Post subject: Z101 has been released under Rev A |
Thanks Richard, might give it a try, it's just after 17 years and fluent
working with Intellicad
Cheers Werner
On 08.09.2020 01:58, Richard Girard wrote:
| Quote: | Werner, Try the free trial version of Draftsjght. It works all rhe way
back to Acad 13.
Rick
<http://www.avg.com/email-signature?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=webmail>
<mailto:glastar(at)gmx.net>> wrote:
<glastar(at)gmx.net <mailto:glastar(at)gmx.net>>
Thanks Bob,
with an
upwards
it fails)
Thanks Werner
>> Dear Bob,
taylor it to
> theme.
> Bob . . .
Electric-List" rel="noreferrer"
target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
Marx <http://www.goodreads.com/author/show/43244.Groucho_Marx>
wsimpso1
Posted: Mon Aug 09, 2021 6:27 am Post subject: Re: Z101 has been released under Rev A |
I was following along loosely on the Z101, but then a chapter colleague asked me to look in some detail at it and check a few things. We discovered the same issues...
Depending upon variant, start sequence involves:
1 - Close Cl Del or Aux Bus switch;
2 - Program route, obtain clearance, etc;
3 - Close DC Master switch;
4 - Open Cl Del or Aux Bus switch;
5 - Start engine
This allows use of the Cl Del/Brownout Bus continuously. It also appears to have a couple drawbacks. Please check us on this:
If you open the Cl Del or Aux Bus switch before closing the DC Master switch, your route evaporates during start up. Sounds like a good reason to checklist this exact sequence and rehearse it a little...
Once you are flying, something causes you to need to drop back to min electrical power in the airplane. This could be anything from alternator/regulator faults to an electrical fire. Your sequence to keep the EFIS, attitude reference, and #1 Com online (very important if IMC or smoke is obscuring view outside) must be to turn on the Cl Del or Aux Bus before turning off the DC Master. Do them out of order and your ability to keep the airplane upright and heading toward a safe spot to put down just evaporated until you get through the reboots and some scratching for the center freq. So, using this scheme seems to drive us to checklist this exact sequence too, and rehearse it a bunch.
If I was more clever I suppose I could come up with a way to prevent inadvertent shut down of the Clearance/Brownout Bus. Anybody have any way to help out our very human pilot from these very human failures?
Billski
Ceengland
Posted: Mon Aug 09, 2021 5:39 pm Post subject: Z101 has been released under Rev A |
On 8/9/2021 9:28 AM, wsimpso1 wrote:
5 - Start engine
This allows us of the Cl Del/Brownout Bus continuously. It also appears to have a couple drawbacks. Please check us on this:
Billski
Hi Billski,
I haven't followed Z101 development closely, since I'd already finished
my architecture & wiring. But here's my take.
IIRC, the dual alts are supposed to eliminate the need for load
shedding. The Clrnc/BO bus is not an endurance bus.
'Smoke in the cockpit' traditionally means making the entire cockpit
cold; not just the stuff we think we can do without in the moment (it
could be the EFIS that's on fire). The engine bus staying hot is a
required concession to an electrically dependent engine.
My alternative to the brownout bus, relay, etc is to simply wire a boost
converter's input to the EFIS's main power input, and it's output to one
of the EFIS's diode-isolated aux power inputs. In my particular
installation, it works fine to prevent brownout rebooting, and the
parasitic load from the boost converter running all the time is a few
tenths of an amp. I don't need the clearance delivery feature in my type
of flying.
(rv7charlie on HBA)
_________________ Charlie |
wsimpso1
Posted: Tue Aug 10, 2021 2:38 pm Post subject: Re: Z101 has been released under Rev A |
| Ceengland wrote: | | IIRC, the dual alts are supposed to eliminate the need for load shedding. The Clrnc/BO bus is not an endurance bus. |
Does not seem that way...
Bob has talked about how the Aux Alt and its Ford regulator are standby devices, not normally used and so do not need to be the nice electrically quiet linear amplifiers we use on our primary alternators. Sounds to me like it is not powered up normally.
Then on to function. If you power up the Aux Bus to program your flight and collect your clearance, but do not open its switch before your attempt to start, the brownout booster is not connected to the Cl Del/ Brownout Bus, and your preparation evaporates in the reboot. I have to believe that the Aux Aux Bus switch is usually only Closed pre-start.
| Quote: | 'Smoke in the cockpit' traditionally means making the entire cockpit
required concession to an electrically dependent engine. |
Unless the smoke is from an engine fire... then you would want to keep some electronics and make the engine bus cold.
| Quote: | My alternative to the brownout bus, relay, etc is to simply wire a boost converter's input to the EFIS's main power input, and it's output to one
of the EFIS's diode-isolated aux power inputs. In my particular installation, it works fine to prevent brownout rebooting, and the parasitic load from the boost converter running all the time is a few tenths of an amp. I don't need the clearance delivery feature in my type of flying. |
I have thought about that approach too, good to hear that it works. It will remove the dependance upon specific sequences of switch throwing to keep programmed routes, etc on engine start, but we still have to remember to close the Aux Switch if we want to keep the EFIS and GPS/NAV/COM in an emergency where we would be opening the DC Master.
I guess nobody else is watching old threads on here...
Billski
Ceengland
Posted: Tue Aug 10, 2021 4:19 pm Post subject: Z101 has been released under Rev A |
On 8/10/2021 5:38 PM, wsimpso1 wrote:
Not my interpretation of what he's said; any properly functioning
automotive alternator & regulator (internal or external), installed
correctly, will be just as quiet as the B&C. (I can testify.) My
interpretation of what he said is that the backup alt/reg doesn't need
all the bells&whistles of the (expensive) B&C regulator (OV protection,
auto-activation), because it's a backup, and manual activation is easy
if we're notified of low (less than normal charging) voltage.
Auto-switching was developed for FAA certification, making them usable
in certified a/c. Having an OV failure of the backup regulator, after
some failure mode of the primary charging system, strains even
lightning-strike odds. Loss of primary isn't an emergency; you can pour
yourself a cup of coffee, and after a casual troubleshooting session,
bring the backup on line. The battery handles the load for the few
seconds or minutes it takes to bring up the backup.
Everything's a compromise. Ex: remembering to leave the non-impulse mag
off during start is important switchology compromise, but we've done it
for so long we don't think of it as a special requirement. Hot starting
a Bendix injected Lyc is a strenuous exercise in stupidity, but we've
learned to live with it for so long it's 'normal'.
You *could* substitute one make-before-break DP3T (on-on-on) switch for
the clrnc del & master switches, to automate the process. But then you
need a rather specialized switch which isn't going to be available in
East Podunk if it fails, *and* it becomes a single point of failure for
the entire airplane. Compromises...
So you open the engine control & pump switches (downstream of the bus),
instead of flipping two mag switches and moving the fuel valve to 'off'.
New switchology for new technology. Compromises...
For me, with my components. Don't trust; verify (with your components).
| Quote: | It will remove the dependance upon specific sequences of switch throwing to keep programmed routes, etc on engine start, but we still have to remember to close the Aux Switch if we want to keep the EFIS and GPS/NAV/COM in an emergency where we would be opening the DC Master.
Yes. But what cockpit emergency would cause you to want to keep the EFIS
online, but take everything else off? If there's smoke in the cockpit,
if we know where the smoke's coming from we can just turn that component
off. As already mentioned, load shedding shouldn't be needed in most
circumstances when a backup alternator is available, or could be
accomplished by individually powering down a couple of devices. If you
really need an endurance bus because normal loads exceed the capacity of
the backup alt + the battery, then one of the other drawings might be a
better choice as a starting point. Or maybe add the endurance bus to
this one.
Billski
Bob has always said that the drawings are guides; not schematics. I took
the brownout bus ideas, decided I wanted to simplify *if I could*, and
it worked out for me, remembering that clearance delivery wasn't in my
requirements list.
Please remember that these are my thoughts/opinions; not Bob's. Weigh
them as you see fit.
AmandaGrey Guest
Posted: Thu Jul 13, 2023 12:52 am Post subject: Re: Z101 has been released under Rev A |
Thanks a lot for information, was searching for similar one
nuckollsr
Joined: 24 Mar 2009 Posts: 95 Location: Medicine Lodge, KS
Posted: Fri Aug 11, 2023 4:58 pm Post subject: Re: Z101 has been released under Rev A |
Dear Bob,
Sorry for the relative silence. My email service has been
on the fritz (on account of new Google 'security' features)
for several weeks. I think we're close to resolving the issues.
So for you folks that are missing replies from me . . . especially
those with gmail accounts . . . I expect to be up and running
shortly.
The latest diagrams on on the website. Z101B is current
at http://aeroelectric.com/PPS/ACAD_Architecture_Dwgs/Z101B.dwg
The z-figures folders
are where upgrades take place to be included in future
editions. Rev 12 is current. You can download a .pdf copy
of the print edition following links on the website.
