Posted: Fri Aug 28, 2020 2:11 pm Post subject: Rotax ignition coil faston size |
Does anyone know the size of the faston for the rotax ignition connectors?
Willl
William Daniell
+1 786 878 0246
rparigoris
Posted: Sat Aug 29, 2020 8:19 am Post subject: Re: Rotax ignition coil faston size |
Hi William I have a 914 and am close to installing the grounding cut off pins on the ignition connector. It's a round crimp on pin that has a rubber seal. I purchased an extra set from Rotax to do a practice crimp or two. Is this the pin that you want a dimension for? Rotax wants you to use shielded wire and shield it at both ends. If this is not the connector, where is the faston located? Ron P.
