Fwd: MR16 halogen lamp LED replacement: sanity check
ceengland7(at)gmail.com
PostPosted: Mon Aug 24, 2020 10:12 am    Post subject: Fwd: MR16 halogen lamp LED replacement: sanity check Reply with quote
On 8/24/2020 11:59 AM, user9253 wrote:
One statement caught my attention:
" As LED options are naturally a brighter option, the lumen count will typically be less."
That does not make sense. Isn't a lumen a unit of brightness?
This website will help to convert from halogen to LED:
https://www.rapidtables.com/calc/light/how-lumen-to-watt.html
I agree Charlie, it will take 2 or 3 of those LEDs to replace 1 halogen.
Joe Gores
Yeah; that was what prompted my 'somebody's crazy' comment.  Her
statement was the 1st time I've ever heard that LEDs can be brighter and
have lower lumens at the same time. Smile
rv8iator
PostPosted: Mon Aug 24, 2020 10:27 am    Post subject: Fwd: MR16 halogen lamp LED replacement: sanity check Reply with quote
Light ratings need explicit definition as they involve a number of variables as white light is defined in five dimensions.  The old watts rating along with is it a "bare bulb", a "flood" or a "spot" used to be good enough as these are all white black body radiators.
The link you provided has a conversion of radiant flux to luminous flux.  The wattage on filament bulb ratings is the input power, no direct relation to radiant flux.
Lumens describe luminous flux,  Simply how bright the source appears to the human eye.
Lux is unit of how much of that brightness will appear on a surface at a defined distance.  One lux = 1 lumen per square meter at one meter distant from the source.   1 footcandle = one lumen per square foot at one foot distant from the source.
1 candela = one lumen per steradian. (see below)
[img]cid:ii_ke8u4wr70[/img][img]cid:ii_ke8u6du11[/img]
White LEDs are typically rated in CD (candela) or Lm  (lumens) for radiant output..  They are also specified by CCT,  (correlated color temperature).  Roughly 5000°K = daylight,  2500°K= candle light (yellow/orange).  As CCT is a one dimensional characteristic which works well for a filament source it can produce very different results for an LED which is a cold light source.  The applicable color characteristic for LEDs is "chromaticity".
If all this is confusing it is because light is electromagnetic radiation and as such is multidimensional.
If anyone is interested I will provide my slide deck to my course "Intro to Illumination" course.  Contact me at chris dot stone(at)a-dec dot com.  (replace the "dot" with a .) to elude spammers.
.chris stone
On Mon, Aug 24, 2020 at 10:16 AM user9253 <fransew(at)gmail.com (fransew(at)gmail.com)> wrote:
Joe Gores
http://forums.matronics.com/viewtopic.php?p=497945#497945
 Filesize:  237.12 KB
 Viewed:  2740 Time(s)
 Filesize:  104.13 KB
C. Stone (RV8iator)
PostPosted: Mon Aug 24, 2020 2:13 pm    Post subject: Fwd: MR16 halogen lamp LED replacement: sanity check Reply with quote
Hi Chris,
As testament to my weak grasp of lighting specs, I have to 're-learn' about them every time I deal with lighting issues.
However, that salesperson's contention that LEDs are brighter, and therefor have lower lumen ratings for the same light level, makes no sense whatsoever to me. According to the interwebs, the definition of 'lumen' is:
the central cavity of a tubular or other hollow structure in an organism or cell.
"the stomach empties food into the lumen of the small intestine"
No, wait...Let's try this one:
the SI unit of luminous flux, equal to the amount of light emitted per second in a unit solid angle of one steradian from a uniform source of one candela.
So when is a lumen not a lumen? Unless that company is selling small intestines, they are feeding us the output of small intestines.
*That* was the reason for my post. They are certainly not alone in misleading claims; early on it was very rare to find a home LED bulb that truly had light output equal to its 'equivalent' incandescent or halogen version. Things are a bit better now, but too often, still not truly equivalent.
I obviously want to use LEDs; I just want honesty in their ratings just like I want honesty in ratings for any other product.
I'd love to have your presentation on lighting; it would be nice to have a reference document when I need to 're-learn' lighting from time to time. If you're going to send it to Bob, I can download it from the AEC site, so you won't have to send to multiple destinations.
Thanks!
[img]cid:part1.599BE7D6.D2076DA8(at)gmail.com[/img][img]cid:part2.9BDA031F.B394058E(at)gmail.com[/img]
.chris stone
Joe Gores
 Filesize:  237.12 KB
 Viewed:  2738 Time(s)
 Filesize:  104.13 KB
rv8iator
PostPosted: Mon Aug 24, 2020 2:35 pm    Post subject: Fwd: MR16 halogen lamp LED replacement: sanity check Reply with quote
Charlie et al...
I did see the magical art of illumination put forth by the inhabitant of
1000bulbs.com, or was it bulbs.com. I have had similar discussions with
the sales associate at superbrightleds.com In fairness it's a subject that
is a bit more complex than meets the eye. (no pun intended)
.chris
On Mon, Aug 24, 2020 at 3:21 PM Charlie England <ceengland7(at)gmail.com>
wrote:
[quote] Hi Chris,
or cell.
candela.
equivalent.
Thanks!
to radiant flux.
the human eye.
[image: image.png][image: image.png]
is "chromaticity".
.chris stone
> typically be less."
C. Stone (RV8iator)
